Up Next artwork different from library managed art
Hello, curious why the “Up Next” art for my shows is different from the art I manually selected. I also can’t seem to change this art? For example in these images Battlestar Galactica and Doctor Who do not match.
On the subject of this art I noticed it’s cropped on the top row of my Apple TV. Is this normal?
You’re comparing the art for the individual episodes to the art for the show. They are different.
You can change this art too. You can even batch update multiple episodes at once. Read up on the Art Picker documentation.
That's different. I wouldn't have considered that individual episode art-- I would consider an episode thumbnail to be the episode art. This is an image that's been applied to every episode of the show that as far as I can tell I'm only seeing when it's on up next. It's so generic I would expect it might as well have been the same art as the show. I'll play around with the art picker.
I think the artwork you're talking about is the season artwork for a show.
Each episode in a season will have the same artwork, and it changes from season to season.
I believe it has always been that way.
