Just setting up channels for the first time. I'm a current subscriber to Verizon Preferred TV HD. When I attempt to set up a DVR Channel using my Verizon Preferred TV HD credentials. I get an error "no login form found" as well as a "you must have Preferred HD or above" error. Screenshot attached.
Researching the boards, I saw the being able to access nbc.com/live is important for some reasons. I attempted to connect to nbc.com/live which failed two times but on the third attempt, I was successful. Accessing nbc.com/live now works everytime.
Any help on where I should go from here on troubleshooting?
Thanks
