WDMyCloud Single Drive
Third log out and log in worked. Thanks for the help again!
Login is only for remote access. If you are at home you should not be using the login option.
Without logging in the DVR does not show up
I think im really close to getting this done…however (after copy/paste of the command ā€œwget -O /tmp/channels_dvr.bin https://channels-dvr.s3.amazonaws.com/wd/WDMyCloud_ChannelsDVR_1.0.5.bin upload_apkg -d -s 1 -p /tmp/channels_dvr.binā€
I get - ā€œUsage: wget [OPTION]… [URL]ā€¦ā€
I am using SSH via Putty
Make sure you run each command separately. First this one:
Then this one:
Thanks!!! I got the file to Download, but after running ā€œupload_apkg -d -s 1 -p /tmp/channels_dvr.binā€
I get
ā€œ-bash: upload_apkg: command not foundā€
Sorry, im terrible w Linux. im on Firmware Version 04.05.00-327
This was my output:
WDFAKENAME:~# wget -O /tmp/channels_dvr.bin https://channels-dvr.s3.amazonaws.com/wd/WDMyCloud_ChannelsDVR_1.0.5.bin
–2018-10-06 13:40:20-- https://channels-dvr.s3.amazonaws.com/wd/WDMyCloud_ChannelsDVR_1.0.5.bin
Resolving channels-dvr.s3.amazonaws.com (channels-dvr.s3.amazonaws.com)… 52.216.106.3
Connecting to channels-dvr.s3.amazonaws.com (channels-dvr.s3.amazonaws.com)|52.216.106.3|:443… connected.
HTTP request sent, awaiting response… 200 OK
Length: 11169 (11K) [application/octet-stream]
Saving to: `/tmp/channels_dvr.bin’
100%[======================================>] 11,169 --.-K/s in 0.003s
2018-10-06 13:40:25 (3.92 MB/s) - `/tmp/channels_dvr.bin’ saved [11169/11169]
WDFAKENAME:~# upload_apkg -d -s 1 -p /tmp/channels_dvr.bin
Hmmm weird.
Try:
/usr/sbin/upload_apkg -d -s 1 -p /tmp/channels_dvr.bin
WDFAKENAME:~# /usr/sbin/upload_apkg -d -s 1 -p /tmp/channels_dvr.bin
-bash: /usr/sbin/upload_apkg: No such file or directory
No luck…
Weird it’s like they got rid of that command.
What model and firmware version?
2015 Western Digital Corporation. All Rights Reserved
Its the WD Mycloud from 2015
Ah that’s why. See:
AH! Dangit! I thought I installed an app a while ago. Guess not.
Thanks for your help…time for an upgrade :slight_smile:
Does this mean mycloud home doesn't work at all?
If you have the right model, it will work. That is what I started with, but it was too slow for me.
Thanks. I had already returned it lol... I am just using for live tv. I will worry about DVR later. Now I cant get it to stop trying to access that drive so I cant watch anything
Uncheck DVR box in the Web UI.
Got this installed and its working.
The MYCloud is on firmware 2.41.116 But there is an update available to 5.11.112
Do I dare update? Anyone working with 5.11.112?
