must not have gotten wsl2 installed completely or something. getting this multiple times after reboot
[2026-08-16 21:23:05.140] [INFO] [Install] Install requested for 1 selected package(s) using preference: Winget
[2026-08-16 21:23:05.219] [INFO] [Install] Install selected package(s): WSL2 (no package id)
[2026-08-16 21:23:05.975] [INFO] [Install] Install package manager split: winget=0, choco=0, direct=0, github=0, npm=0, wslFeature=1, wslDistro=0, wslCommand=0, streamLinkManager=0
[2026-08-16 21:23:07.079] [INFO] [Package] Enabling WSL2 (WSL2)
[2026-08-16 21:23:27.643] [INFO] [Package] Still enabling WSL2 (20s elapsed) - this can take a while.
[2026-08-16 21:23:47.910] [INFO] [Package] Still enabling WSL2 (40s elapsed) - this can take a while.
[2026-08-16 21:24:08.175] [INFO] [Package] Still enabling WSL2 (60s elapsed) - this can take a while.
[2026-08-16 21:24:28.440] [INFO] [Package] Still enabling WSL2 (80s elapsed) - this can take a while.
[2026-08-16 21:24:48.700] [INFO] [Package] Still enabling WSL2 (100s elapsed) - this can take a while.
[2026-08-16 21:25:08.894] [INFO] [Package] wsl: WSL installation appears to be corrupted (Error code: Wsl/CallMsi/Install/REGDB_E_CLASSNOTREG).
Press any key to repair WSL, or CTRL-C to cancel.
This prompt will time out in 60 seconds.
Class not registered
[2026-08-16 21:25:16.929] [WARN] [Package] WSL2: WSL2 does not appear usable yet - if this is the first time it's been enabled on this machine, a restart is likely required.
but that install was on the older version. I'll have to try uninstalling it
