Seems like there's a bug with the filter then. You're stuck using the full xmltv file.
Got it. Thanks for the time.
p.s. are the end-points and parameters documented anywhere that I can refer to?
No, because they are not officially supported.
But this thread does a good job:
Ah ...under forum section [Playground] > [Hacks].
Thanx!
