I am preparing to spin up a second instance of ADBTuner and would like a confirmation of my thinking.
A little background. I recently switched from Hulu Live to DirecTV stream. Before I made the switch I decided to start with a clean slate thanks to @bnhf and his wonderful OliveTin project. I deleted everything including Portainer. I reinstalled Portainer and OliveTin via the OliveTin EZ-Start. I then reinstalled ADBTuner. After reading about @spammedeeper use of DirecTV Osprey devices I purchased 3 of them to replace the Onn 4k Pros I was using with Hulu. The Ospreys are working well with DTV. I want to spin up a second instance of ADBTuner to use the Onn devices I replaced with Ospreys. The Osprey deep link URL format is different from the Onn format so I can't use them in the same ADBTuner instance.
Q. Can I use the Project One-Click Action to create a ADBTuner instance using the following Env Vars -
HOST_PORT: 5593
HOST_VOLUME: adbtuner_config2
Sorry for the length of this post and thank you to the users of this resource who are so willing to help.
