I pushed a new :development build this morning (20260808-1).
It adds two new features to custom channel configurations, conditional operations, and number input sequences. They are both represented in this example:
"ADB_NUMBER_INPUT_SEQUENCE": {
"number": "||TARGET_URL_OR_IDENTIFIER||",
"input_delay_seconds": 0.25
"condition": {
"check": "||TARGET_URL_OR_IDENTIFIER||",
"cast": "number",
"greater_than": "100"
ADB_NUMBER_INPUT_SEQUENCE would generally be used with a channel number. This command will input each digit, in sequence, with the specified delay between each input.
Conditional operations, the condition block above, provide the ability to execute, or skip, a specific command based on the specified conditions.
Conditions can be applied to any command:
"ADB": {"command": "input keyevent KEYCODE_DPAD_CENTER"},
"condition": {
"cast": "string",
"equals": "banana",
"not_equals": "cookie"
The available operators are: equals, not_equals, greater_than, less_than, at_least, and at_most.
There is a small amount of documentation for this at /ui/configurations/documentation in the web interface.
I'm still working on some bigger things, but I took some time to add these features to address some limitations that configuration authors were running into. Please let me know if you run into any issues.
