does youtube tv still work with this? I can't seem to get them to stream.
YTTV works great.
The Onn boxes just do what is needed.
What happens when you try to play a stream?
I'mhappyto pass along any kind of link to help out if needed.
the preview just spins
Do you have your tuners setup and connected and streaming endpoints urls setup? That would be the only thing I can think of why it just spinning and not showing the test stream. I would also check the box below that window.
could the channel number be wrong? Does that matter?
Have you tried checking the "compatibility" box for your channels. I see you are running an older Firestick. I didn't have as much luck with my older Firesticks, and ended up going with new Chromecasts.
Yeah. It's checked. I wonder if I just have the wrong information. Does anyone have a westcoast list for yttv
This is what I have for YouTube TV USA West, https://tv.youtube.com/watch/DJ7m0fdLKEY
I am not sure if they are the same for everyone or specific to each login.
I found the links through the youtube tv website. And I posted a full .json file for importing into ADBTuner. However, it only contains east coast streams and doesn't contain locals as they are geolocated.
Its not user specific.
how can I remove the channels all at once?
here is what my logs give me.. not sure what i am doing wrong.
2023-11-15 21:02:20.098 - server - Tuner: Tuning to CBS on Fire TV Max
2023-11-15 21:02:20.101 - lib.adb - ADB: Connecting to device (attempt 1).
2023-11-15 21:02:20.304 - lib.adb - ADB: Connected.
2023-11-15 21:02:20.304 - lib.adb - ADB: 192.168.6.101 - dumpsys display
2023-11-15 21:02:20.422 - lib.adb - ADB: 192.168.6.101 - getprop ro.build.version.release
2023-11-15 21:02:20.451 - lib.adb - ADB: Android Version: 9.0.
2023-11-15 21:02:20.451 - lib.adb - ADB: 192.168.6.101 - input keyevent KEYCODE_WAKEUP
2023-11-15 21:02:21.164 - lib.adb - ADB: 192.168.6.101 - pm list packages -3
2023-11-15 21:02:21.331 - lib.adb - ADB: 192.168.6.101 - pidof com.amazon.firetv.youtube.tv
2023-11-15 21:02:21.552 - lib.adb - ADB: Stopping media playback.
2023-11-15 21:02:21.553 - lib.adb - ADB: 192.168.6.101 - input keyevent KEYCODE_MEDIA_STOP
2023-11-15 21:02:22.456 - lib.adb - ADB: 192.168.6.101 - am start -a android.intent.action.VIEW -d "https://tv.youtube.com/watch/D1vdtklRyHg" com.amazon.firetv.youtube.tv
2023-11-15 21:02:22.581 - server - Tuner: Waiting 5 seconds to allow sleeping device to setup.
2023-11-15 21:02:34.278 - server - Tuner: Compatibility Mode - Stream released after 14.18 seconds. Display was off, application (com.amazon.firetv.youtube.tv) was closed.
2023-11-15 21:02:34.278 - lib.adb - ADB: Closing connection - 192.168.6.101
2023-11-15 21:02:34.280 - uvicorn.access - 174.218.117.107:1177 - "GET /stream/1/118 HTTP/1.1" 200
2023-11-15 21:02:34.287 - root - Tuner: Stream open (attempt 1).
When I type in this URL https://tv.youtube.com/watch/M2YyNsA47Lw it tries to show me Law and Order:SVU. Maybe your links are wrong.
does this stream only tv everywhere?
No, any channel that has a link, can be tuned and streamed. That's one of the great things about these solutions, is you can pull channels into the ChannelsDVR that never had TVE.
does the app have to be on or just installed on the device?
