Strange.
Works on my Synology.
DVR at /volume1/arkives/ChannelsDVR
Movie Imports at /volume1/arkives/testMovies
TV Imports at /volume1/arkives/testTV Shows
Latest Alpha 2020.09.20.1902
is still not sorting imported episodes correctly by air date when asked. And therefore not mixing correctly when combined with recorded episodes in same season.
Sort by date recorded does not work with imported episodes at all as they are not imported in order of episode number when imported in large groups.
Would it not be easier just to have a sort by episode number within a season?
When an imported show (multiple seasons) is included in UpNext and set up to show the oldest recording, its not working and choosing a season and episode out of order. The older season and episodes are not marked watched. In my case its the show 'The Ranch' which I had to manually match every episode as the season and episode numbers from zap2it are bonkers compared to other sources of meta data. I matched every episode to its title, one by one and the end result has the show in the correct play order in the list but upnext is not choosing the correct one to play next.
Wasn't The Ranch 8 Seasons with 10 Episodes each?
Maybe the Original Air Dates plus gracenote mixup of Season and Episode is causing the issue.
I think Wikipedia matches up with Netflix on the OAD.
Of course for 'Official' Season(Part)#, Episode# and EpisodeTitle, nothing beats the 'Official' source
IMDB and theTVDB both show 4 seasons of 20 episodes each. zap2it shows 7 seasons of 10 each with season 8 not detailed. Its a mess
I manually matched all 80 episodes using title in Channels since channels could not match them up even though my files contain the episode title. Even once done, it seems to be sorting on something pulled in with the meta data (air date?) that has bad data since it wants to play season 5 before season 4. Channels is not sorting on episode number nor the episodic order zap2it provides so not exactly sure what is going on. Diagnostics sent so hopefully tmm1 will figure out what's up.
Question... When you import something, does it copy the file into the ChannelsDVR folder? Or does it just point to the original location of the recording? (I can imagine use-cases for either behavior, so wondering what you chose)
Something weird seems to be happening when episodes are individually matched. I have a show called Bugs with 40 episodes across 4 seasons which all matched correctly though I had to match them one by one. They are correctly stored and named in season folders etc. But in the app they just appear as a bag of 40 episodes with no seasons listed.
Ah ok I see now. The metadata for the matching episodes contains the correct title and description but no episode or season number. I guess that’s a gap in the metadata service provider’s data?
For example season 1 episode 10 is called Pulse and the matching episode is just listed as Pulse with no season or episode number.
Files
./Farming the Wild (2018)/Farming the Wild (2018) - 2019-01-04 - Roasted Rack with a Side of Fangs.ts
./Farming the Wild (2018)/Farming the Wild (2018) - 2019-01-11 - Stalking the Elusive Fallow Deer for a T-bone Treat.ts
./Farming the Wild (2018)/Farming the Wild (2018) - 2019-01-18 - Stalking the Right Roe Buck Before a Gourmet Breakfast.ts
./Farming the Wild (2018)/Farming the Wild (2018) - 2019-01-25 - Midsummer Rabbits on the Menu.ts
./Farming the Wild (2018)/Farming the Wild (2018) - 2019-02-01 - Marinated Muntjac Management.ts
./Farming the Wild (2018)/Farming the Wild (2018) - 2019-02-08 - Crayfish on the Menu.ts
./Farming the Wild (2018)/Farming the Wild (2018) - 2019-02-22 - Harvesting Roe Deer Venison for the Family Table.ts
./Farming the Wild (2018)/Farming the Wild (2018) - 2019-04-12 - Blizzard Stalk Fallow Deer.ts
./Farming the Wild (2018)/Farming the Wild (2018) - 2020-06-29 - Stalking Fallow Prickets 1.ts
./Farming the Wild (2018)/Farming the Wild (2018) - 2020-07-06 - Pigeon.ts
./Farming the Wild (2018)/Farming the Wild (2018) - 2020-07-13 - Stalking Red Deer Hinds in Scotland.ts
./Farming the Wild (2018)/Farming the Wild (2018) - 2020-07-20 - Wildfowl, Goose and Mallard.ts
./Farming the Wild (2018)/Farming the Wild (2018) - 2020-07-27 - Woodcock & Snipe.ts
./Farming the Wild (2018)/Farming the Wild (2018) - 2020-09-14 - Stalking Fallow Prickets 2.ts
./Farming the Wild (2018)/Farming the Wild (2018) - 2020-09-21 - Invasive Species 1.ts
I've tried putting the files in a Season 0 and Season 1 folder, but nothing works to match them.
Have to match using tmsID SH030187620000
And also have to match each episode manually.
Found the Season and Episode numbers at Outdoor Channel
and renamed my files to match.
I contacted zap2it and gave them the Outdoor Channel website so they can fix their listings.
