Like several have noticed, our local NBC affiliate (Chicago, WMAQ) has moved to the streaming with DRM. As such, I've looked to explore options with an antenna and HDHomeRun or alternate.
Any recommendations or pointers to the best setup? Would an Indoor antenna be perfectly sufficient or is it substantially better to get an outdoor antenna? Any suggestions on product?
Also it looks like the recommendations on HDHomeRun on the Channels FAQ are dated. I see their Flex 4K model that is out now. I also see ZapperBox M1 and curious if that works with Channels?
