And another one
2018-04-16 20:02:08.071 device: Bedroom - AppleTV5,3 - Version 11.3 (Build 15L211)
2018-04-16 20:02:08.075 locale: en_US - America/Los_Angeles (PDT) offset -25200 (Daylight)
2018-04-16 20:02:08.077 version: 3.1.13 (3.24.318)
2018-04-16 20:02:08.341 [cplayer] v: Setting option ‘opengl-hwdec-interop’ = “auto” (flags = 64) -> 0
2018-04-16 20:02:08.345 [cplayer] v: Setting option ‘opengl-early-flush’ = “no” (flags = 64) -> 0
2018-04-16 20:02:08.348 [cplayer] v: Setting option ‘vo’ = “opengl-cb” (flags = 64) -> 0
2018-04-16 20:02:08.351 [cplayer] v: Setting option ‘hwdec-codecs’ = “hevc” (flags = 64) -> 0
2018-04-16 20:02:08.354 [cplayer] v: Setting option ‘hwdec’ = “videotoolbox” (flags = 64) -> 0
2018-04-16 20:02:08.357 [cplayer] v: Setting option ‘sub-margin-y’ = “75” (flags = 64) -> 0
2018-04-16 20:02:08.362 [cplayer] v: Setting option ‘demuxer-lavf-probesize’ = 5000000 (flags = 64) -> 0
2018-04-16 20:02:08.366 [cplayer] v: Setting option ‘demuxer’ = “+lavf” (flags = 64) -> 0
2018-04-16 20:02:08.369 [cplayer] v: Setting option ‘sub-border-size’ = “0” (flags = 64) -> 0
2018-04-16 20:02:08.372 [cplayer] v: Setting option ‘sub-back-color’ = “#bf000000” (flags = 64) -> 0
2018-04-16 20:02:08.374 [cplayer] v: Setting option ‘demuxer-readahead-secs’ = “95” (flags = 64) -> 0
2018-04-16 20:02:08.376 [cplayer] v: Setting option ‘demuxer-lavf-o’ = “probesize=131072” (flags = 64) -> 0
2018-04-16 20:02:08.378 [cplayer] v: Setting option ‘deinterlace’ = “no” (flags = 64) -> 0
2018-04-16 20:02:08.386 [cplayer] v: Setting option ‘user-agent’ = “Channels tvOS” (flags = 64) -> 0
2018-04-16 20:02:08.389 [cplayer] v: Setting option ‘cache-secs’ = “95” (flags = 64) -> 0
2018-04-16 20:02:08.392 [cplayer] v: Setting option ‘sub-font-size’ = “32” (flags = 64) -> 0
2018-04-16 20:02:08.393 [cplayer] v: Setting option ‘vd-lavc-software-fallback’ = “no” (flags = 64) -> 0
2018-04-16 20:02:08.395 [cplayer] v: Setting option ‘sub-font’ = “Monaco” (flags = 64) -> 0
2018-04-16 20:02:08.398 [cplayer] v: Setting option ‘vf’ = “lavfi=[fastdeint=linear]” (flags = 64) -> 0
2018-04-16 20:02:08.403 [cplayer] v: Setting option ‘vd-lavc-o’ = “” (flags = 64) -> 0
2018-04-16 20:02:08.407 [cplayer] v: Setting option ‘audio-channels’ = “auto” (flags = 64) -> 0
2018-04-16 20:02:09.575 Devices: (
“<HRDevice:0x1c41adc80 id=1070F186 host=192.168.50.87 model=HDHR5-4US firmware=20180327 channels=205>”
2018-04-16 20:02:09.578 DVR: <LTPlusClient:0x1c41e6b00 version=(null) arch=(null) os=(null) url=(null) username=(null)>
2018-04-16 20:02:09.626 Guide Loaded: {
Filter = All;
Source = “On Now”;
2018-04-16 20:02:09.645 Startup Tab: {
Tab = LTGuideViewController;
2018-04-16 20:02:09.669 Guide Loaded: {
Filter = “HD Channels”;
Source = Guide;
2018-04-16 20:02:09.676 Device Found: {
DRM = false;
DRMChannels = 0;
DVB = false;
FirmwareUpToDate = true;
FirmwareVersion = 20180327;
FriendlyName = “HDHomeRun CONNECT Quatro”;
Legacy = false;
ModelNumber = “HDHR5-4US”;
TunerCount = 4;
2018-04-16 20:02:09.894 Guide View (Main View/GuideView): (null)
2018-04-16 20:02:12.563 Play Channel: {
Source = “Guide View Item Cell”;
2018-04-16 20:02:12.872 [cplayer] v: Run command: stop, flags=0, args=[]
2018-04-16 20:02:12.877 Updating playState from LTVideoPlayerPlayStateStopped to LTVideoPlayerPlayStateStopped
2018-04-16 20:02:12.883 [cplayer] v: Set property: pause=false -> 1
2018-04-16 20:02:13.015 Updating playState from LTVideoPlayerPlayStateStopped to LTVideoPlayerPlayStateLoading
2018-04-16 20:02:13.020 set streaming buffer to 128 segments (free bytes: 22147534848)
2018-04-16 20:02:13.049 streamer sent request to 192.168.50.87: tuner 3, channel <HRChannel:0x1c4174880 number=7.1 name=ABC (KABC-DT)> []
2018-04-16 20:02:13.516 [cplayer] v: Setting option ‘start’ = “none” (flags = 64) -> 0
2018-04-16 20:02:13.522 event: start-file
2018-04-16 20:02:13.527 Updating playState from LTVideoPlayerPlayStateLoading to LTVideoPlayerPlayStateLoading
2018-04-16 20:02:13.536 [cplayer] v: Setting option ‘rebase-start-time’ = “no” (flags = 64) -> 0
2018-04-16 20:02:13.539 [cplayer] v: Run command: loadfile, flags=0, args=[cb://1523934133015, replace, ]
2018-04-16 20:02:13.542 [global] v: config path: ‘watch_later’ -> ‘-’
2018-04-16 20:02:13.546 [cplayer] info: Playing: cb://1523934133015
2018-04-16 20:02:13.549 [stream_callback] v: Opening cb://1523934133015
2018-04-16 20:02:13.553 [stream_callback] v: Stream opened successfully.
2018-04-16 20:02:13.556 [demux] v: Trying demuxers for level=force.
2018-04-16 20:02:13.596 Video View (Main View/VideoView): (null)
2018-04-16 20:02:13.758 streamer started receiving data
2018-04-16 20:02:13.790 [lavf] v: Found ‘mpegts’ at score=50 size=2048.
2018-04-16 20:02:13.793 [lavf] v: avformat_open_input() finished after 0 bytes.
2018-04-16 20:02:13.798 event: tracks-changed
2018-04-16 20:02:13.802 event: tracks-changed
2018-04-16 20:02:13.806 event: tracks-changed
2018-04-16 20:02:13.810 event: metadata-update
2018-04-16 20:02:13.814 event: audio-reconfig
2018-04-16 20:02:13.817 event: file-loaded
2018-04-16 20:02:13.820 [lavf] v: avformat_find_stream_info() skipped
2018-04-16 20:02:13.823 [demux] v: Detected file format: mpegts (libavformat)
2018-04-16 20:02:13.826 [cplayer] v: Opening done: cb://1523934133015
2018-04-16 20:02:13.829 [cplayer] info: (+) Video --vid=1 (mpeg2video)
2018-04-16 20:02:13.832 [cplayer] info: (+) Audio --aid=1 --alang=eng (ac3)
2018-04-16 20:02:13.835 [cplayer] info: Audio --aid=2 --alang=spa (ac3)
2018-04-16 20:02:13.838 [vd] v: Container reported FPS: 0.000000
2018-04-16 20:02:13.842 [vd] v: Codec list:
2018-04-16 20:02:13.847 [vd] v: mpeg2video - MPEG-2 video
2018-04-16 20:02:13.851 [vd] v: mpegvideo (mpeg2video) - MPEG-1 video
2018-04-16 20:02:13.855 [vd] v: Opening video decoder mpeg2video
2018-04-16 20:02:13.859 [vd] v: Not trying to use hardware decoding: codec mpeg2video is not on whitelist, or does not support hardware acceleration.
2018-04-16 20:02:13.863 [vd] v: Using software decoding.
2018-04-16 20:02:13.867 [vd] v: Detected 2 logical cores.
2018-04-16 20:02:13.872 [vd] v: Requesting 3 threads for decoding.
2018-04-16 20:02:13.875 [vd] v: Selected video codec: mpeg2video (MPEG-2 video)
2018-04-16 20:02:13.878 [vf] info: Opening video filter: [lavfi graph=fastdeint=linear]
2018-04-16 20:02:13.881 [lavfi] v: Setting option ‘graph’ = ‘fastdeint=linear’ (flags = 0)
2018-04-16 20:02:13.884 [ad] v: Codec list:
2018-04-16 20:02:13.887 [ad] v: ac3 - ATSC A/52A (AC-3)
2018-04-16 20:02:13.889 [ad] v: ac3_fixed (ac3) - ATSC A/52A (AC-3)
2018-04-16 20:02:13.891 [ad] v: ac3_at (ac3) - ac3 (AudioToolbox)
2018-04-16 20:02:13.893 [ad] v: Opening audio decoder ac3
2018-04-16 20:02:13.896 [ad] v: Requesting 1 threads for decoding.
2018-04-16 20:02:13.899 [ad] v: Selected audio codec: ac3 (ATSC A/52A (AC-3))
2018-04-16 20:02:13.903 [cplayer] v: Starting playback…
2018-04-16 20:02:13.909 [lavf] v: Detected program change for 1: (pcr=0,nb=0) -> (pcr=49,nb=3)
2018-04-16 20:02:13.915 [vd] warn: Error while decoding frame (-1094995529)!
2018-04-16 20:02:13.923 [vd] warn: Error while decoding frame (-1094995529)!
2018-04-16 20:02:13.927 [vd] warn: Error while decoding frame (-1094995529)!
2018-04-16 20:02:13.930 [vd] warn: Error while decoding frame (-1094995529)!
2018-04-16 20:02:13.932 [vd] warn: Error while decoding frame (-1094995529)!
2018-04-16 20:02:13.937 [ao] v: Trying audio driver ‘audiounit’
2018-04-16 20:02:13.940 event: audio-reconfig
2018-04-16 20:02:13.942 [ao/audiounit] v: requested format: 48000 Hz, 5.1(side) channels, floatp
2018-04-16 20:02:13.950 [ao/audiounit] v: using soft-buffer of 9600 samples.
2018-04-16 20:02:13.951 [cplayer] v: Remix: 5.1(side) -> stereo
2018-04-16 20:02:13.953 [cplayer] info: AO: [audiounit] 48000Hz stereo 2ch floatp
2018-04-16 20:02:13.956 event: video-reconfig
2018-04-16 20:02:13.959 event: tracks-changed
2018-04-16 20:02:13.962 event: video-reconfig
2018-04-16 20:02:13.965 [cplayer] v: AO: Description: AudioUnit (iOS)
2018-04-16 20:02:13.968 [vd] v: Using software decoding.
2018-04-16 20:02:13.973 [vd] v: Decoder format: 1280x720 yuv420p auto/auto/auto/limited CL=mpeg2/4/h264 (auto 0.000000/0.000000/0.000000)
2018-04-16 20:02:13.977 [ffmpeg] v: src: w:1280 h:720 pixfmt:yuv420p tb:1/1000000 fr:0/1 sar:1/1 sws_param:
2018-04-16 20:02:13.981 [lavfi] v: lavfi: create graph: ‘fastdeint=linear’
2018-04-16 20:02:13.983 [vf] v: Video filter chain:
2018-04-16 20:02:13.985 [vf] v: [in] 1280x720 yuv420p bt.709/bt.709/bt.1886/limited SP=1.000000 CL=mpeg2/4/h264
2018-04-16 20:02:13.988 [vf] v: [lavfi] “lavfi.00” 1280x720 yuv420p bt.709/bt.709/bt.1886/limited SP=1.000000 CL=mpeg2/4/h264
2018-04-16 20:02:13.991 [vf] v: [out] 1280x720 yuv420p bt.709/bt.709/bt.1886/limited SP=1.000000 CL=mpeg2/4/h264
2018-04-16 20:02:13.993 [cplayer] info: (+) Video --vid=1 (mpeg2video)
2018-04-16 20:02:13.995 [cplayer] info: (+) Audio --aid=1 --alang=eng (ac3)
2018-04-16 20:02:13.997 [cplayer] info: Audio --aid=2 --alang=spa (ac3)
2018-04-16 20:02:13.999 [cplayer] info: Subs --sid=1 (eia_608)
2018-04-16 20:02:14.002 [cplayer] info: VO: [opengl-cb] 1280x720 yuv420p
2018-04-16 20:02:14.005 [cplayer] v: VO: Description: OpenGL Callbacks for libmpv
2018-04-16 20:02:14.009 [cplayer] v: first video frame after restart shown
2018-04-16 20:02:14.557 [cplayer] v: starting audio playback
2018-04-16 20:02:14.757 event: playback-restart
2018-04-16 20:02:14.776 Updating playState from LTVideoPlayerPlayStateLoading to LTVideoPlayerPlayStatePlaying
2018-04-16 20:02:14.788 [cplayer] v: playback restart complete
2018-04-16 21:48:48.086 read got (54) Connection reset by peer
2018-04-16 21:48:48.091 read got (0) Undefined error: 0
2018-04-16 21:48:48.094 read got (0) Undefined error: 0
2018-04-16 21:48:48.100 read got (0) Undefined error: 0
2018-04-16 21:48:48.104 read got (0) Undefined error: 0
2018-04-16 21:48:48.107 read got (0) Undefined error: 0
2018-04-16 21:48:48.111 read got (0) Undefined error: 0
2018-04-16 21:48:48.113 read got (0) Undefined error: 0
2018-04-16 21:48:48.116 read got (0) Undefined error: 0
2018-04-16 21:48:48.118 read got (0) Undefined error: 0
2018-04-16 21:48:48.121 read got (0) Undefined error: 0
2018-04-16 21:48:48.123 read got (0) Undefined error: 0
2018-04-16 21:48:48.125 read got (0) Undefined error: 0
2018-04-16 21:48:48.127 read got (0) Undefined error: 0
2018-04-16 21:48:48.129 read got (0) Undefined error: 0
2018-04-16 21:48:48.132 read got (0) Undefined error: 0
2018-04-16 21:48:48.136 read got (0) Undefined error: 0
2018-04-16 21:48:48.140 read got (0) Undefined error: 0
2018-04-16 21:48:48.146 read got (0) Undefined error: 0
2018-04-16 21:48:48.148 read got (0) Undefined error: 0
2018-04-16 21:48:48.152 streamer stopping after 6032800 packets and 20 timeouts (114613 waits)
2018-04-16 21:48:48.482 [ffmpeg/audio] error: ac3: incomplete frame
2018-04-16 21:48:48.671 [cplayer] v: audio EOF reached
2018-04-16 21:48:49.275 [ffmpeg/video] error: mpeg2video: ac-tex damaged at 36 28
2018-04-16 21:48:49.280 [ffmpeg/video] error: mpeg2video: Warning MVs not available
2018-04-16 21:48:49.286 [ffmpeg/video] v: mpeg2video: concealing 1360 DC, 1360 AC, 1360 MV errors in B frame
2018-04-16 21:48:49.322 event: audio-reconfig
2018-04-16 21:48:49.327 [cplayer] v: video EOF reached
2018-04-16 21:48:49.331 event: video-reconfig
2018-04-16 21:48:49.339 [cplayer] v: EOF code: 1
2018-04-16 21:48:49.347 [ad] v: Uninit audio decoder.
2018-04-16 21:48:49.351 [ffmpeg] v: src: w:1280 h:720 pixfmt:yuv420p tb:1/1000000 fr:0/1 sar:1/1 sws_param:
2018-04-16 21:48:49.354 event: audio-reconfig
2018-04-16 21:48:49.369 event: tracks-changed
2018-04-16 21:48:49.377 event: end-file
2018-04-16 21:48:49.393 Updating playState from LTVideoPlayerPlayStatePlaying to LTVideoPlayerPlayStateError
2018-04-16 21:48:49.412 event: video-reconfig
2018-04-16 21:48:49.419 [lavfi] v: lavfi: create graph: ‘fastdeint=linear’
2018-04-16 21:48:49.425 [vd] v: Uninit video.
2018-04-16 21:48:49.431 [cplayer] v: finished playback, success (reason 0)
2018-04-16 21:48:49.467 [cplayer] info:
2018-04-16 21:48:49.481 [cplayer] v: Set property: aid=1 -> 1
2018-04-16 21:48:49.486 [cplayer] v: Set property: audio=1 -> 1
2018-04-16 21:48:49.490 [cplayer] v: Set property: sid=0 -> 1
2018-04-16 21:48:49.494 [cplayer] v: Set property: sub=0 -> 1
