Chronix10, Nice router. I really like the Asus routers and am on my second Asus model. However, based on my experience with Asus and Channels, don’t be too quick to rule out the router/network.
I currently have a Asus RT-AC68P, which is a step down from your RT-AC86u. Different router but I found there are situations where I could max out the router and cause problems for the Channels app. For example, I used to have an Apple TV with a network connection right into the router. I found that when I ftp’d a large file to a router USB drive, the Channels app would skip and freeze. When I connected the same AppleTV to my core switch the problem stopped. The HD mpeg2 OTA files from channels are some of the highest bandwidth files you will use so it will stress your network and expose any shortcomings.
Good Luck. Scott
