Channels Carbon Theme
updated to 103.30.2255
update 104.8.2059
minor change. the button backgrounds have been darkened and the selected button background lightened. now the button selected will be the lighter color, rather than darker (the way it was)
I decided to try this out on my Android tablet because it was so easy to download and install on this device. Pretty freaking cool! Thank you for sharing this with the community.
Thank you. Please let me know if you experience any issues with that layout at all.
update to 104.14.30
update to 104.16.149
updated banner / icon
channels
Just downloaded on my Shield. Great work! Love it! Thank you
Thanks for the update. May want to update the first post with the latest version number.
Google Drive seems to be blocking or preventing me from downloading your .apk to my phone. It gives a connection error. open in browser option don't do anything either than say open with package installer, sits for a few secs, than shows the same error.
I always use the GDrive app to get files from my computer to phone, just upload file to Gdrive via web, and download it on the phone.
This has been a issue for a while...i don't update the app on my phone often.
I just kept forgetting to mention it here.
Have to transfer the .apk via usb c cable.
Other .apks work fine.
Weird
I've had that issue on my phone too and it's something to do with the default apps, it sees an .apk and wants to open the package installer instead of downloading it. What I do is open the link in chrome desktop box checked and not the drive app.
@speedingcheetah
The button at the top, left of the hamburger, I clicked that and it downloaded.
My menus and options appear to be different.
3 dot menu download, or open with option, it does engage Download Manager, but "Unknown error".
EDIT: Not sure what the deal is with the GDrive app, it even blocks it when i put the apk in a .zip.
Whatever, i just set a bookmark to the download webpage in my Browser and just use that.
This makes me want to devise a better way to get the .apk downloaded other than a drive link. The logical way would be to hijack their update thing in the settings to have it point to the link, it wouldn't matter it it's the same version. I don't have the skills for that.
Another way I think easier downloading would be X-Plore. It has support for linking your Drive, and you can save that file into your drive. Not the actual file, just the link. I'll look into it.
@speedingcheetah
So, using the computer, I was able to add a shortcut into Drive for an .apk and it showed up in X-Plore on my SHIELD where I could click on it to install, at which point I received this friendly message. Apparently X-Plore is looking at the signing certificate of the .apk, which of course is bogus, cause I'm not a developer. Maybe you could try and have different results.
