Channels DVR authentication to Hulu Fails | Captcha grayed out also
....And back to being stuck at the email verification screen for TVE
Screenshot 2023-06-25 215006
Is there any way that an option can be made for the 2FA Hulu has to enter the code when prompted?
I recently did some scanning with Hulu and received a pile of verification requests.
I use. Hulu for ABC, CBS fox when it works and TBS/TNT/TCM etc.
I use Philo to grab the rest of the channels becuase it is cheap with my discount.
I'm using ADBTuner along with my ONN Android box and video encoder to grab what i want off Hulu and Philo that isn't on TVE.
Turns out my Video encoder is doing some slight pixelating so going to move over to another unit that is known to work here.
I'm expecting more channels to move to DRM so getting familiar with settings up these tuners.
Here we go again.. Not able to add Hulu back as a source. Did the same sequence as I used several times in the past - with no luck this time after 2 days of trying. Changing passwords, deleting devices, Chrome up to date, restarting DVR - no dice this time.
Logs have been submitted as 04a6da5d-6250-4132-a208-a0258b3acadc .
The error @kprice is receiving is:
We couldn't log you in. Please check your email and password and try again. Or visit Find My Account if you need to reset.
Edit: fixed username. It autocompleted to the wrong username before
Still can't add Hulu as a source - says can't auth email / password. Yet I'm able to login to ABC, FOX, NBC HGTV etc - using those exact credentials. Only thing I see in the logs mentions 12s timeout , then action=auth_timed_out. No clue if this is the issue.
I've cleared browser caches, tried 4 diff browsers, stopped / started channels - everything that I've done in the past to fix this issue. Has to be a Channels issue. It seems like something from the original source Hulu is still stuck in Channels somewhere - or something has changed..
You are describing my situation exactly. I can use Hulu for TVE outside of Channels. But so far it only seems to affect me and you. I will not renew Hulu live TV and will switch to YTTV. Hulu was a better fit for our needs, but I really have no choice if I can't get Channels working with Hulu again.
I just got Hulu Live TV and I'm unable to authenticate...after reading this thread I feel like it might have been a mistake...how do you clear out your TVE in Hulu?
I don't personally use Hulu, but have seen many users that do mention removing devices in their Hulu account. Have you tried that?
Examples
There are also posts in the official Hulu Provider Topic, these being the last two
I have logged into Hulu and when I do I get the code to my email...I do NOT see where i can remove any type of sessions yet...when I attempt to login to Channels on my synology Nas through docker I just get incorrect username and password it doesnt even get to anything else
I do see devices now...but whine ones do I remove?
I know this is an on going issue in several threads. I have tried on both a dedicated bare metal Windows installation and now Docker:tve on a Synology. I have removed all web sessions on the Hulu site. I still cannot login to TV Everywhere with Channels. I can log into all the sites individually with my Hulu/Disney credentials.
Pretty sure this is still broken and not much hope for it working properly. I switched to YouTube TV and couldn't be happier....
Wrong channel set for me
2024/07/15 11:23:19.719358 [TVE] Auth starting for Hulu as xxxxx
2024/07/15 11:23:20.453090 [TVE] action=auth mvpd=Hulu requestor=nbcentertainment
2024/07/15 11:23:20.453750 [TVE] action=xvfb display=:614
2024/07/15 11:23:21.163672 [TVE] action=version product=Chrome/120.0.6099.129 jsVersion=12.0.267.10 protocol=1.3 revision=@204016af461e03117aa3858b51ba4534c7cfda81
2024/07/15 11:23:21.164683 [TVE] action=page_ready chromeVersion=120
2024/07/15 11:23:21.165250 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=Hulu&requestor_id=nbcentertainment&no_iframe=true&domain_name=adobe.com&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2024/07/15 11:23:21.169860 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/authenticate/saml
2024/07/15 11:23:24.721640 [TVE] action=request type=Document method=GET url=https://auth.hulu.com/oauth2/login redirected_from=https://sp.auth.adobe.com/adobe-services/authenticate/saml
2024/07/15 11:23:24.721698 [TVE] action=auth_domain domain=.hulu.com
2024/07/15 11:23:24.838177 [TVE] action=wait_for_page
2024/07/15 11:23:30.802203 [TVE] action=page_ready
2024/07/15 11:23:30.802261 [TVE] action=wait_for_page done=true reason=page_ready
2024/07/15 11:23:30.802320 [TVE] action=wait_for_auth timeout=12s
2024/07/15 11:23:30.802356 [TVE] action=fill_form u=xxxxx
2024/07/15 11:23:30.807986 [TVE] action=tvejs msg="hulu login not found"
2024/07/15 11:23:42.802952 [TVE] action=check_result
2024/07/15 11:23:42.807209 [TVE] action=auth_timed_out
2024/07/15 11:23:42.807263 [TVE] action=screenshot
2024/07/15 11:23:43.183068 [TVE] action=screenshot size=303873
2024/07/15 11:23:43.183749 [TVE] action=capture_html
2024/07/15 11:23:43.190319 [TVE] action=capture_html size=119543
2024/07/15 11:23:44.031692 [TVE] Auth failed for Hulu: Cable provider authentication failed
yep still broken, I dont think there is much hope of it getting better based on the changes hulu made...
Well, Disney does ruin everything
Since Hulu is fighting so hard against account sharing, part of the fight includes strict log in requirements.
My TVE needs are served best with Philo and Fubo TV for the stuff not on the docker.
I switched from Fubo. They started cutting too many channels without lowering the price
So Hulu live will not work with channels TVE?
See above
