Confused and Lost. Need help understanding how various community projects work, and are used with Channels DVR
I am in prismcast/cc4c..how long does a4hc take to tune? What's the cheapest most reliable 1080p box? Also has anyone figured out a good ESPN baton to make linear channels?
for devices I assume the ONN streaming device or the google android tv standalone is recommended, as amazon firetv devices will be discontinued soon and I assume vega wont work as good. I have a shieldtv but use it personally and it will probably stop working by 2030.
Takes me about 9-10 secs on average to tune in ah4c using my Osprey devices.
Who is your provider for ESPN?
You can buy a New FireTv 4K Max that will continue to use Android OS.
I prefer Link Pi encoders. Get a multi-port encoder for the best experience (IMO).
It will be phased out though by 2030ish
I modified my uverse app to install on my android box and I get lots more channels on uverse over channels + cc4c
I'm seeing 350 dollars for the box. Is there a cheap dual model and what's the cheapest known working single model
I'm quite happy with my LinkPi ENC1-V3's with cheep $10 usb encoders. you only get 50fps on the usb but thats still better than TVE.
Cc4c is only 30fps, and most 60fps channels aren't even 60fps. Will a haupaugge hdpvr work are there any other good ones under 100 bucks?
V3 shows being 140 bucks. Is it better than haupaugge hdpvr? Any options under 140? My PC does cc4c/prismcast and I can do 10 streams and it was 70 bucks old stock Dell i7 pc
the hdpvr is very old.
an enc1v3 + a $10 usb capture works out to ~$75 per tuner.
How hard is it to make deep links ? I can do it on any app right? I can so vibe code something for att uverse right?
Could the haupaugge work theoretically? I'll check the other thread
What android devices are recommended besides fire sticks
Does anyone have a list of tve/android apps that support livetv streams?
What do deep links look like. Was going to have chat gpt look for them in the uverse app
Schemes are easy, you can do a dumpsys package 'pkg-name' | head -50 with adb shell and see what's supported. The trick is figuring out the exact URL syntax to kick off a channel or event.
Stuff like nbctve://live/nbc or foxone://channel/fs1, not sure if these are in the Android manifest XML or if you have to get AI to decompile the apk and figure it out.
Does anyone have a good working list of DirecTV stream to save me some time?
I think DirecTV actually has streamlinks? I have been modding the uverse app to add the functionality .
I will see if I can figure it out .it's not very easy
I am vibe coding in ai to have some channels with multiple sources to have a tiered system if one fails
Does anyone have an android tve list of channels available? Cartoon network and comedy Central, nick don't stream any more I know
So it will pull from the signed in apk through adb?
I bought the stuff I need I don't have a linkpi yet. The streamlinks trigger a load in the android device. Project one click requires Windows login? A lot of the stuff is cryptic and I'm having to use AI to understand it since no one bothers to do a setup video
Doug,
Read this topic. Install Portainer. Install Olive Tin. This gives you at least 2 ways to get to Project 1 Click.
Post your issues & questions in the correct thread. PLEASE!!!!
I used AI to scrape for the channels. I wasmt able to use Olivetin as it needs me to login to get json on windows and I dont have the login..I'll get kicked out of the apk just wanted to test it before have to use the uverse one
do you see any other deep links for channels like 6, 10, 13, 21, 42, 67, 68, 84-200 , 205, 228, 234, 265, 291, 308, 343, 467, 472-531, 545-552, 611, 614, 645, 646, 649, 676, FAST channels from 921-4721 I think there was another fast channels thread with deep links?
