Directv stream not working as a TVE Source
Does Directv Stream work as a source using TVE? I've tried multiple times to add it and it just fails to authenticate.
DTV authentication is a bit quirky at times. Try adding it as DirecTV instead of DirecTV Stream.
I added mine as directv and it took right away.
so far so good.
It's weird. Sometimes one will work, sometimes the other, sometimes both. I added both...just in case one has problems. Occasionally, I lose a channel, or more, from one source or the other, and have to manually rescan to get them back.
12 posts were split to a new topic: DirecTV not working
since this may be relevant and yet to be discussed, what version are you running?
Upgrading to a pre-release fixed the issue.
