I have a FireTV (2017) and manual tuner addition fails. This wouldn’t be troubling, except it works on my AppleTV 4k using Channels app.
Both my FireTV and AppleTV are on the same Wifi network. The SiliconDust Prime tuner is on a different vlan/network from my devices.
I can add, watch, remove and re-add the tuner to my AppleTV Channels App and everything is fine. When I provide the same IP address of the tuner to the Channels app on the FireTV it immediately says it cannot connect.
Is this expected behavior? Most of the reason I purchased the Channels App for my Fire TV is that it’s worked so well for my AppleTV when using a tuner on a different vlan/network.
Any assistance would be appreciated.
Thank you.
