I have the exact same behavior. I hate it when my fox panel is missing.
I am watching on Fox Sports APP not Fox Now everything is great undisputed in 4K. I will keep using Fox Sports app want to enjoy the game not spend time messing with TVE,
Same here. Also with YouTube tv. I toggled locals and now FOX TVE doesn't show up in my list of channels.
I have three TVE channels. One doesn't work, which is local Tampa channel. One is 1080 and the other is 720. I have the 4k box checked in the Channels web settings.
Edit
If I uncheck the 4K box, the local TV Fox channel does work. If I record with with the 4k box checked, it produces a 0 bytes file.
I see they just released a FIX for TVE Fox.
Looks like I just lost FOX. Cannot get it back unchecked Locals and rechecked not working.
New Release ...
2023/02/12 08:52:23.253908 [TVE] action=navigate url=https://www.foxsports.com/live
2023/02/12 08:52:23.254684 [TVE] action=request type=Document method=GET url=https://www.foxsports.com/live
2023/02/12 08:52:23.254684 [TVE] action=auth_domain domain=www.foxsports.com
2023/02/12 08:52:23.254684 [TVE] action=foxsportsauth step=start
2023/02/12 08:52:23.377364 [TVE] action=request type=Document method=GET url=https://www.foxsports.com/nfl-2023-super-bowl-lvii
2023/02/12 08:52:23.410346 [TVE] action=wait_for_page
2023/02/12 08:52:28.640615 [TVE] action=page_ready
2023/02/12 08:52:28.640615 [TVE] action=wait_for_page done=true reason=page_ready
2023/02/12 08:52:28.653122 [TVE] action=click_interstitial
2023/02/12 08:52:28.656703 [TVE] action=tvejs msg="foxSportsSelect: path=/nfl-2023-super-bowl-lvii"
2023/02/12 08:52:28.656703 [TVE] action=wait_for_interstitial timeout=12s
2023/02/12 08:53:28.665789 [TVE] action=wait_for_interstitial err=timeout
With the new release still can’t get Fox to show up when checking the TV Everywhere box. This is what is in the log…
2023/02/12 10:54:44.997981 [TVE] action=version product=HeadlessChrome/109.0.5414.119 jsVersion=10.9.194.10 protocol=1.3 revision=@772095164c7d5d4e73160f858efed3b5e87eca83
2023/02/12 10:54:44.998839 [TVE] action=navigate url=https://www.foxsports.com/live
2023/02/12 10:54:45.000975 [TVE] action=request type=Document method=GET url=https://www.foxsports.com/live
2023/02/12 10:54:45.000992 [TVE] action=auth_domain domain=www.foxsports.com
2023/02/12 10:54:45.001013 [TVE] action=foxsportsauth step=start
2023/02/12 10:54:45.230197 [TVE] action=request type=Document method=GET url=https://www.foxsports.com/nfl-2023-super-bowl-lvii
2023/02/12 10:54:45.260886 [TVE] action=wait_for_page
2023/02/12 10:54:50.563669 [TVE] action=page_ready
2023/02/12 10:54:50.563848 [TVE] action=wait_for_page done=true reason=page_ready
2023/02/12 10:54:50.575007 [TVE] action=click_interstitial
2023/02/12 10:54:50.579334 [TVE] action=tvejs msg="foxSportsSelect: path=/nfl-2023-super-bowl-lvii"
2023/02/12 10:54:50.579418 [TVE] action=wait_for_interstitial timeout=12s
2023/02/12 10:55:50.562054 [TVE] action=wait_for_interstitial err=timeout
2023/02/12 10:55:50.564441 [TVE] action=fill_form u=
2023/02/12 10:55:50.574932 [TVE] action=screenshot
2023/02/12 10:55:53.772548 [TVE] action=screenshot size=4963112
2023/02/12 10:55:53.775735 [TVE] action=capture_html
2023/02/12 10:55:53.792897 [TVE] action=capture_html size=782296
2023/02/12 10:55:53.793568 [TVE] action=script_error err=&runtime.ExceptionDetails{ExceptionID:1, Text:"Uncaught", LineNumber:9, ColumnNumber:5, ScriptID:"50", URL:"", StackTrace:(*runtime.StackTrace)(0x14000a39a00), Exception:(*runtime.RemoteObject)(0x14002024f30), ExecutionContextID:0, ExceptionMetaData:easyjson.RawMessage(nil)} exp=&runtime.RemoteObject{Type:"string", Subtype:"", ClassName:"", Value:easyjson.RawMessage{0x22, 0x6e, 0x6f, 0x20, 0x6c, 0x6f, 0x67, 0x69, 0x6e, 0x20, 0x66, 0x6f, 0x72, 0x6d, 0x20, 0x66, 0x6f, 0x75, 0x6e, 0x64, 0x22}, UnserializableValue:"", Description:"", WebDriverValue:(*runtime.WebDriverValue)(nil), ObjectID:"", Preview:(*runtime.ObjectPreview)(nil), CustomPreview:(*runtime.CustomPreview)(nil)} exp_value="no login form found"
2023/02/12 10:55:53.872868 [TVE] action=fox_station err="no login form found"
Lost 6002 here. YTTV is my provider. Getting EOF error.
Local fox will not appear until they fix this, right now you can't login with TVE providers.
2023/02/12 11:04:22.737679 [TNR] Closed connection to TVE-YouTubeTV for ch6002 WZTV
2023/02/12 11:04:27.461546 [TVE] stream timestamps: fox: start_at=2023-02-12T11:03:50-06:00 end_at=2023-02-12T11:04:18-06:00 live_delay=6.547542001s
2023/02/12 11:04:27.461703 [TNR] Opened connection to TVE-YouTubeTV for ch6002 WZTV
2023/02/12 11:04:28.060692 [TNR] Error during live stream for ch6002 WZTV: astits: fetching next packet failed: astits: fetching next packet from buffer failed: astits: building packet failed: astits: parsing packet adaptation field failed: astits: fetching next bytes failed: astikit: slice length is 188, offset 215 is invalid
2023/02/12 11:04:28.060797 [SNR] Buffer statistics for 10.0.0.12 (Living Room ATV) for ch6002 WZTV: buf=0% drop=0%
2023/02/12 11:04:28.080641 [TNR] Closed connection to TVE-YouTubeTV for ch6002 WZTV
I was under the impression that there would be no need for TV Everywhere to watch the Superbowl.
The channel does authenticate when I scan for it. Has the check mark.
Correct. You can watch in their app without login. That has nothing to do with our TVE integration.
You can. He just posted that same sentiment.
Unchecking the 4K box got my local working again.
Probably need the app for 4k/hdr.
Unchecking the 4K box did not get my local FOX working. "403 forbidden"
Anyone get the new ChannelsDVR 4K implementation working?
This is the free stream for UHD:
Unfortunately they're using a different type of format that Channels doesn't understand.
I have plans today so this is not going to work. You may be able to feed into xteve or other type of ffmpeg based proxy which can convert this type of playlist.
If you make a .strm file with the url I think that Kodi can play it. Probably Emby too.
EDIT: seems video only, no audio. You would need to get the main playlist yourself from chrome web inspector. Or use EPLUS docker with VLC/Kodi/etc
