Thanks for trying much appreciated.
Same here
It works on VLC Full Screen. No sound
4K or 1440?
change the _5 to _6 at the end for 4k
Do You get Sound ?
sound is on _7 with no video
Thanks. Did you figure out the audio?
edit.
I see your post. Thanks again.
So You either have sound or great Video not both ... That is enough experimenting ... back to Fox Sports.
I got sound by opening multiple streams ... Opened 2 Instances of VLC.
can't even get fox to work now with YTTV hmmm
Uncheck the Experimental checkbox for Stream 4K and HDR
Turning off 4k didn't fix it for me either. My Fox is totally gone. My other locals are there. I'm not that worried about it though. I have OTA. I was only using this to try to help troubleshoot.
As a followup to my post, 2023.02.11.2034 has broken YTTV authentication. I just spun up another instance running 2023.01.23.1746 and most of the channels are running now.
Edit: Known issue.
Slightly off-topic, but just a heads up to anyone who plans on watching using the Fox Sports app, the app does not support HDR on the Apple TV. I believe it works on Android TV devices that support 4K HDR (works on my TiVo Stream 4K) and Roku.
Yep, same here after disabling the Experimental 4K streaming option.
Must be because they're not requiring Provider authentication today.
[TVE] action=auth mvpd=Comcast_SSO requestor=fbc-fox
[TVE] action=authed
[ERR] Failed to start stream for ch6002: TVE: platform response: 403 Forbidden
Can you do that on the ATV4K?
