FS1 and 2 gone
Working here, too, for now. Thanks.
Unfortunately failing again, same error as before. Neither channel is working.
2025/04/27 11:17:21.443532 [ERR] Could not start stream for TVE-hotwirecommunications_auth-gateway_net ch6198 FS2: TVE: not entitled: mvpd: Resource is not supported by MVPD
I'm running the 4/23 pre-release.
Both are working try an individual Re-Scan. on them.
Just wanted to re-visit this and say that it's been working now for a few weeks. Thank you for the fixes.
I lost BTN tonight (Hulu) :upside_down_face:
It's back :joy:
I've been running verification scans every day at around 6am ET for over a week now, and it seems like the Fox sports stations are broken every other day at that time (at least one of them, that is; it's inconsistent if it's all or some). If I run the same thing just a few hours later, they come back just fine. And it's not just Channels TVE, the same thing with EPlusTV, so the issue appears to be on the Fox end.
TVE is steadily becoming unstable.
Do they do it on purpose u think? Does it effect just web viewers?
Its still BETA for a reason. You gotta enjoy the channels that still work DRM-free and hassle-free as you can. Otherwise, get a cablecard (if you can with a cable company), get Fubo and use the fubo bridge or get a HDMI encoder.
I have the fubo bridge and HDMI encoder setup. i've pretty much stopped the use of TVE.
if you have an email that was never uesd for FUBO just waiti for them to send an offer and take it.
i got one that not only gave me a month free i got Fubo for $79.99 plus regional sports.
I paied $15.99 for a month fo Fubo.
I could probably useanother email address and apply the same promo. but don't want to play with stuff.
They often send the $70.00 coupon so if you can anag one enjoy the month of savings and get setup.
Looks like FS1, FS2, and BTN are down again. Much appreciated if someone could look into it.
Logs submitted.
And... they're gone again for me after working for a little while. Same MVPD error.
I looked in the logs and my credentials are authenticated with my provider just fine, the error happens after that when channels tries to authenticate that token to Fox sports. Sometimes it works, sometimes it doesn't.
Here's one that worked:
2025/07/15 08:17:09.710860 [TVE] action=request type=Document method=POST url=https://hotwirecommunications.auth-gateway.net/saml/module.php/authSynacor/login.php
2025/07/15 08:17:12.831989 [TVE] action=request type=Document method=GET url=https://hotwirecommunications.auth-gateway.net/saml/module.php/authSynacor/DiscoveryAssociationsResume.php
2025/07/15 08:17:12.873127 [TVE] action=request type=Document method=GET url=https://hotwirecommunications.auth-gateway.net/saml/module.php/authbypass/lastbookend.php redirected_from=https://hotwirecommunications.auth-gateway.net/saml/module.php/authSynacor/DiscoveryAssociationsResume.php
2025/07/15 08:17:12.911632 [TVE] action=request type=Document method=GET url=https://hotwirecommunications.auth-gateway.net/saml/module.php/authbypass/lastbookend.php
2025/07/15 08:17:12.984736 [TVE] action=request type=Document method=POST url=https://adobe.auth-gateway.net/saml/module.php/saml/sp/saml2-acs.php/proxy_hotwirecommunications.auth-gateway.net
2025/07/15 08:17:13.174129 [TVE] action=request type=Document method=GET url=https://adobe.auth-gateway.net/saml/module.php/authSynacor/DiscoveryAssociationsResume.php
2025/07/15 08:17:13.212371 [TVE] action=request type=Document method=GET url=https://adobe.auth-gateway.net/saml/module.php/authbypass/lastbookend.php redirected_from=https://adobe.auth-gateway.net/saml/module.php/authSynacor/DiscoveryAssociationsResume.php
2025/07/15 08:17:13.251985 [TVE] action=request type=Document method=GET url=https://adobe.auth-gateway.net/saml/module.php/authbypass/lastbookend.php
2025/07/15 08:17:13.326070 [TVE] action=request type=Document method=POST url=https://sp.auth.adobe.com/sp/saml/SAMLAssertionConsumer
2025/07/15 08:17:13.446690 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/completePassiveAuthentication redirected_from=https://sp.auth.adobe.com/sp/saml/SAMLAssertionConsumer
2025/07/15 08:17:13.446690 [TVE] action=authed
2025/07/15 08:17:13.447274 [TVE] action=cookies num_domains=2 num_cookies=7
2025/07/15 08:17:16.047054 [TVE] stream timestamps: fs1: start_at=2025-07-15T08:17:17-04:00 end_at=2025-07-15T08:17:45-04:00 live_delay=15s
2025/07/15 08:17:16.047054 [TNR] Opened connection
Here's the latest that doesn't:
2025/07/18 10:30:07.107392 [TVE] action=request type=Document method=POST url=https://hotwirecommunications.auth-gateway.net/saml/module.php/authSynacor/login.php
2025/07/18 10:30:10.802357 [TVE] action=request type=Document method=GET url=https://hotwirecommunications.auth-gateway.net/saml/module.php/authSynacor/DiscoveryAssociationsResume.php
2025/07/18 10:30:10.856274 [TVE] action=request type=Document method=GET url=https://hotwirecommunications.auth-gateway.net/saml/module.php/authbypass/lastbookend.php redirected_from=https://hotwirecommunications.auth-gateway.net/saml/module.php/authSynacor/DiscoveryAssociationsResume.php
2025/07/18 10:30:10.901936 [TVE] action=request type=Document method=GET url=https://hotwirecommunications.auth-gateway.net/saml/module.php/authbypass/lastbookend.php
2025/07/18 10:30:10.997941 [TVE] action=request type=Document method=POST url=https://adobe.auth-gateway.net/saml/module.php/saml/sp/saml2-acs.php/proxy_hotwirecommunications.auth-gateway.net
2025/07/18 10:30:11.281714 [TVE] action=request type=Document method=GET url=https://adobe.auth-gateway.net/saml/module.php/authSynacor/DiscoveryAssociationsResume.php
2025/07/18 10:30:11.343595 [TVE] action=request type=Document method=GET url=https://adobe.auth-gateway.net/saml/module.php/authbypass/lastbookend.php redirected_from=https://adobe.auth-gateway.net/saml/module.php/authSynacor/DiscoveryAssociationsResume.php
2025/07/18 10:30:11.392675 [TVE] action=request type=Document method=GET url=https://adobe.auth-gateway.net/saml/module.php/authbypass/lastbookend.php
2025/07/18 10:30:11.495154 [TVE] action=request type=Document method=POST url=https://sp.auth.adobe.com/sp/saml/SAMLAssertionConsumer
2025/07/18 10:30:11.616183 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/completePassiveAuthentication redirected_from=https://sp.auth.adobe.com/sp/saml/SAMLAssertionConsumer
2025/07/18 10:30:11.616183 [TVE] action=authed
2025/07/18 10:30:11.617276 [TVE] action=cookies num_domains=2 num_cookies=7
2025/07/18 10:30:13.257777 [ERR] Could not start stream for TVE-hotwirecommunications_auth-gateway_net ch6198 FS2: TVE: not entitled: mvpd: Resource is not supported by MVPD
I've been having this issue and finally found that FS1 was listed in Spectrum and Sling and it was the Sling channel that was getting the mvpd error. When I disabled sling it started working on the Spectrum Source. So maybe it will keep working now.
Just tested on latest pre-release (2025.07.19.0550) and using Fubo TVE credentials and no issues for me. Can't confirm if I would have had issues with previous version however, I don't access FS1/2 frequently.
Actually justed turned FS1 from Sling back on and recorded something fine last night.
Bizarre it works for some and not others
Yep and weird that it works one day and not the next. It does seem to be provider specific.
I don’t actually have sling, I did a long time ago but there were some channels I could still access without a plan so I left the source in there. So if there is a subscription for FS1, I’m sure my sling account doesn’t have access.
Anyone having issues with this again? I'm getting the following error in Sources via Spectrum for both FS1 and FS2:
foxsports regcode: reg_code missing
Tried searching here for this error code and got nothing. Thoughts?
