works for me there too with my xfinity credentials
Just did a rescan of my Fubo credentials and the FS1 and FS2 channels are now gone. Can pull in via Fubo Project and ADBTuner, so not a huge issue other than I have to remap some channels.
Once you go through these troubleshooting steps TVE Troubleshooting tips, to verify you covered the bases and not waste the developers time, the last step is what you need to do.
Talking about the issue in the User Community Forum will not fix it.
Running latest pre release v2025.09.24.2222
Unable to watch FS1, FS2 and BTN
DVR log shows
[ERR] Failed to start stream for ch6197: TVE: foxsports regcode: reg_code missing
[ERR] Failed to start stream for ch6198: TVE: foxsports regcode: reg_code missing
[ERR] Failed to start stream for ch6199: TVE: foxsports regcode: reg_code missing
Logs have been submitted as f0560c9c-3853-4bdc-be99-b2c273cc79cb
Logs have been submitted as bde6378f-1630-4109-bd55-4687c0a5fa54
Should I (and others) also submit logs or is that not going to speed things up for developers?
The latest pre-release should fix that error.
Thanks!!!
Working now, thanks! Any idea what is causing this issue? Seems to have happened a couple of times recently.
This is already broken again on 09.26 pre-release. Seeing error message: not entitled: mvpd: Resource is not supported by MVPD
I don't think they can do anything about that error, it's an internal fox authentication problem. Submitted it months ago and was told that it's not something channels can fix. Unfortunately it will come and go, I was hoping that fox one fixed the problem but I guess not for TVE.
I know this doesn't help folks having issues, but I checked just now and mine is still working ... for now. YoutubeTV.
What’s odd is it works fine with the same TVE login via EPlusTV, but not through Channels TVE.
Working for me (Hulu TVE)
Agreed, but E+ may be using a different way to access than channels.
It appears Channels DVR TVE is still using foxsportsDOTcom and not foxDOTcom (Fox One)
Since you mentioned Hulu TVE,
Do you use the Hulu source without the Container stuff??
On Windows, iOS...??
Thanks for any reply, I am considering Hulu.
I've used Hulu for TVE for a long while and for the most part it's been solid.
Thanks for the reply,
- Windows, iOS ??
- With or without 2FA on your installed Hulu?
Seems these two can make a big difference on some Sources.
And no Containers?
