Fubo TV project
https://registry.hub.docker.com/r/jgomez177/vlc-bridge-fubo/
Your the best
how do you add fubo channels to the docker? example - how would I put this in the docker?
"69687": {"StationID": "59432", "name": "Nickelodeon - NIKHD"},
"134964": {"StationID": "105893", "name": "Horse & Country - HORACOU", "TimeShift": "-2"},
It doesn't add channels, it just maps the guide data
The file fubo-gracenote.json is now location app/Config folder
-v config_dir:/app/Config
@joagomez
Might want to update your Docker Hub page docker run command with the new volume mapping
I don't have Fubo but have been following this thread.
FYI:
Let us see how things play out legally.
at this point, as long as Fubo works for Baseball, locals, and other stations, I'm good.
I got myself away from YTTV and haven't looked back.
My Closed Captions for the SyFi channel arr coming out as gibberish or sometimes, not at all. I checked several other channels and the captions were fine. If I go to Fubo.tv, subtitles are fine.
Anyone have any ideas on this?
I'm no longer using it, but do you see the issue with both HLS and MPEG-TS?
Briefly looked yesterday and did not have any issues with the SyFy CC when using CDVR (web interface and iOS came in with English subtitles) however when using Fubo's website, it did come in as what appeared to be Spanish - now today appears to be in English
The problem seems to have gone away on its own. Maybe it was a problem on the network end.
Anybody having problems tuning to any channels? It has been working fine up until today had a recording for the Dallas Mavericks on Bally and failed to record. Tried other channels same thing. Tried stopping and restarted the docker container.
Running on container v1.16.
Restarted my entire docker desktop and it’s back to normal. Very strange.
I'm using a Synology system and the Fubo tv docker is working great.
The only issue is saw today was that my local CBS channel for some reason disconnected and we got the Fubo tv screen.
I tuned TVE to kcbs and it took a little time then it came back.
The other channels seem to work great.
Question .. does the Fubo stream when using the docker count as a TV device stream or a web/mobile device stream?
Yes it does on both questions.
I just found this project and loved the idea as a very happy Fubo customer. I deployed it in Portainer with the following compose file:
version: "3.9"
services:
fubotvpr:
image: jgomez177/vlc-bridge-fubo
hostname: vlc-bridge-fubo
container_name: vlc-bridge-fubo
restart: unless-stopped
volumes:
- /home/user/fubotvproject:/app/Config
ports:
- 7777:7777
environment:
- FUBO_USER='USER'
- FUBO_PASS='PASSWORD'
The deployment worked fine and the logs just say:
⇨ http server started on [::]:7777
I was under the impression the logs would list all the available channels in our package.
It seems it logs OK but pulls nothing. When I try to curl the M3U file I get nothing either.
Any idea what I am doing wrong?
Here's a full list of docker-composes suitable for use with Portainer-Stacks. Much better to use one that's already tested: :slight_smile:
EDIT: What do you see in your browser at http://<yourdockerhost>:7777?
The log won’t list the channels. Simply review the playlist for available channels
Thank you. Certainly better than coming up with a new one, but I have not seen any obvious discrepancies from what I wrote. In any case, I tried with their script and same result.
Here is the result of curl -o - http://localhost:7777
Fubo Playlist ul{ margin-bottom: 10px; }
Fubo Playlist v1.16
Last Updated: Jan 4, 2024
Ao it seems to assume the two M3U lists are there but when I try:
curl -o - http://localhost:7777/fubo/playlist-mpeg.m3u or
curl -o - http://localhost:7777/fubo/playlist-hls.m3u
I got the same reply:
HTTP failure 400: {"error":{"code":"INVALID_REQUEST","message":"username must be in a valid email format","lc_message":"Something went wrong, please try again later"}}
My mistake was that I had quotes around the values of FUBO_USER and FUBO_PASS in the compose file. I now get the lists. Thank you.
