Fubo TV project
Last time i looked at FUbo tv i did see HLS streams but also saw some mpd streams.
They have apparently made some changes to the API i suspect.
Just tested a few major channels. Still working for me over here.
:crossed_fingers:t3::cold_sweat:
This is what I'm seeing, have removed, reinstalled, rebooted NAS, stopped and restarted. Been using this setup for years, and today it just blew up. Any pointers would be appreciated.
File "/usr/local/lib/python3.12/site-packages/flask/app.py", line 882, in full_dispatch_request
    rv = self.handle_user_exception(e)
  File "/usr/local/lib/python3.12/site-packages/flask/app.py", line 880, in full_dispatch_request
    rv = self.dispatch_request()
  File "/usr/local/lib/python3.12/site-packages/flask/app.py", line 865, in dispatch_request
    return self.ensure_sync(self.view_functions[rule.endpoint])(**view_args)  # type: ignore[no-any-return]
  File "/app/pywsgi.py", line 72, in playlist
    stations, err = providers[provider].channels()
  File "/app/fubo.py", line 144, in channels
    for elem in user_data.get('recurly').get('purchased_packages', {"fubotv-basic"}):
AttributeError: 'NoneType' object has no attribute 'get'
[2025-04-30 21:53:52,187] ERROR in app: Exception on /fubo/playlist-mpeg.m3u [GET]
  File "/usr/local/lib/python3.12/site-packages/flask/app.py", line 1473, in wsgi_app
    response = self.full_dispatch_request()
[2025-04-30 22:12:47,003] ERROR in app: Exception on /fubo/playlist-hls.m3u [GET]
[2025-04-30 22:40:28,268] ERROR in app: Exception on /fubo/playlist-hls.m3u [GET]
[2025-04-30 23:16:00,690] ERROR in app: Exception on /fubo/playlist-hls.m3u [GET]
I haven't used Fubo for awhile, but remember seeing that error (recurly and purchased_packages) when Fubo changed their API and new subscribers couldn't get all their package channels using this "rescued" container. Only those users that had existing subscriptions or were grandfathered in when they changed the API.
This container is on life support and no developer is updating it.
Search the topic. Search results for 'recurly topic:37533 order:latest' - Channels Community
This method still works: Fubo TV project - #580 by sportman09
you can still access the channels that work though. Play the channel from the fubo site, inspect the page & identify fubos channel ID for said channel then copy a url from a channel that the docker has pulled & swap out the channel IDs.
As an example the url for the stream of NFL RedZone I am able to recreate & use is http://serverip:7777/fubo/watch-hls/75963 with 75963 being Fubos channel ID that I was able to find & replace from a working stream URL but when I download or plug in my playlist RedZone doesnt download or import from http://serverip:7777/fubo/playlist-hls.m3u
I did this for each channel I cared about having but was missing from the docker pull, created my own playlist for the missing channels & just added them separately
SEEMS like this would be a good possible add on for PLM.
Like what is done with PBS except set up a box where you can force the channel id with the docker running.
Thanks for sharing.
Mine just dropped to zero channels. This has worked for many months and I've made no changes.
Is Fubo gone forever, or is someone looking to look into this?
Last time i went to the website with my stream finder Chrome extention, i saw mpd links along side the hls streaming.
You just have to go to the page and see if it is getting the m3u.
The original Fubo bridge was broken when they changed the playlists that represent the packages.
When the api changes, your docker is broken. Depends on the account you have.
After a couple days of sweating and an inevitable docker restart, I've now experienced the same. Zero channels. I'm seeing all of those same errors in the logs.
Bummer.
[Sigh.] It sure was good while it lasted! Tuning channels via this Fubo-VLC-Bridge has always been the quickest, most seamless and gave me the largest selection of channels. So this feels like a setback.
Ah well. The only constant in life, is change.
But wait! I just tried this with MSNBC and, well, it's working! Brilliant. Thank you! I'll set up a few more custom channels for the ones I watch, at least the ones that have dropped TVE support, over the new few days.
Thanks for discovering this workaround and sharing it! Awesome, this made my day. In your time since invoking the workaround, have you seen the channel IDs change? If so, how often?
Fofer,
This may help.
These are the ID's (except local/rsn) I had early last year (Jan '24) when I subbed to their Elite package.
FuboChanID GuideName
    104589 AccuWeather
    139932 ACL Cornhole TV
    123265 africanews
    127430 Alien Nation by DUST
     90696 American Heroes Channel
     80124 Animal Planet
    141981 At Home with Family Handyman
    137849 AXS TV NOW
    119429 beIN La Liga
     88749 beIN SPORTS
    105107 beIN SPORTS 4
    105103 beIN SPORTS 5
    105101 beIN SPORTS 6
    105102 beIN SPORTS 7
    105100 beIN SPORTS 8
     88754 beIN SPORTS En EspaƱol
    127712 beIN SPORTS Xtra
    134321 beIN SPORTS Xtra En EspaƱol
     75572 BET
     73952 BET Her
     30419 BET Jams
     18718 BET Soul
     71605 Big Ten Network
     84686 Big Ten Network Alternate
     94683 Big Ten Network Alternate
     94684 Big Ten Network Alternate
    135138 Billiard TV
    137400 BLEAV Football
    137399 BLEAV Sports
    138563 Bloomberg Originals
     83287 Bloomberg Television
     73067 Bounce
    139931 Boxing TV
     85639 Bravo
1239200001 CBS 4K
    118793 CBS News
     69495 CBSSN
    114796 Cheddar News
    148063 ChessTV
    130949 Circle Country
    124684 CleoTV
     69697 CMT
     68971 CNBC
     26849 CNBC World
     75486 Comedy Central
    130049 Comedy Dynamics
    110223 Comet
     79312 Cooking Channel
    123605 Court TV
    137506 Court TV Legendary Trials
    135843 Crackle
    150076 Crime and Punishment
    125430 Curiosity Channel
    120762 Dabl West
    143350 Dark Matter
     70835 Destination America
     92410 Discovery
     78969 Discovery Family Channel
    104830 Discovery Life
    124902 Dove Channel
    104147 E! Entertainment Television
    126128 EarthX TV
     76019 ESTRELLA National
     19039 euronews
    135881 Fail Army
    127467 FamilyTime
     94206 Food Network HD
    134759 Forensic Files
    123918 FOX 4K
     68900 FOX Business Network
    133875 FOX LiveNOW
     70522 FOX News Channel
    133868 FOX Soul
     94653 FOX Sports 1
     69553 FOX Sports 2
    135986 FOX Weather
    123917 FS1 4K
    131622 fubo Movie Network
1238521113 Fubo Radio 1 - Hits Radio
1238521122 Fubo Radio 10 - The 2000s
1238521114 Fubo Radio 2 - Hip-Hop One
1238521115 Fubo Radio 3 - Top Country
1238521116 Fubo Radio 4 - Classic Rock
1238521117 Fubo Radio 5 - Dinner Party
1238521118 Fubo Radio 6 - Coffee Time
1238521119 Fubo Radio 7 - Ɖxitos Latinos
1238521120 Fubo Radio 8 - The 80s
1238521121 Fubo Radio 9 - 90s Alternative
    120123 fubo Sports Network
1238520002 fubo Sports Network 2
     79698 Galavisión
     80167 Game Show Network
     94674 getTV
    131359 GLORY Kickboxing
    129134 Great American Adventures
    103351 Great American Faith & Living
     95030 Great American Family
     89922 GRIT
    125634 Gusto
     77355 Hallmark Channel
    119725 Hallmark Drama
     46730 Hallmark Movies & Mysteries
     99621 HGTV HD
    116116 i24NEWS
    144256 INFAST
     11066 INSP
     76327 Investigation Discovery
    144254 INWONDER
     18633 ION
    123651 ION Mystery
    117518 ION Plus
     16604 JTV
    133890 Judge Nosey
     90742 Justice Central
    131621 Lacrosse Sports Network
    109553 Law & Crime
    113594 Local Now
    110114 Logo
     78575 Magnolia Network
1283550001 Marquee Sports Network (National)
     72650 MLB Network
    139933 MotoAmerica TV
     31046 MotorTrend
     75083 MSNBC
     75524 MTV
    104879 MTV Classic
     49175 MTV Live
     86781 MTV2
     44229 MTVU
    113781 Mystery Science Theater
     45537 NBA TV
    128770 NBC News NOW
    123916 NBC Sports 4K
    104468 NBC Universo
    128875 NBCLX
    131568 News 12 New York
     97163 Newsmax
    103625 NewsNation
    124843 NewsNet
     45409 NFL Network
     68871 NHL Network
     99645 Nick Jr.
     75478 Nickelodeon
     30418 NickMusic
     30420 Nicktoons
    133889 Nosey
    139513 Origin Sports Network
    128911 Outside
     81808 OWN
     85680 Oxygen True Crime
     69429 Paramount Network
    137212 People Are Awesome
    128628 Perfect Game TV
    127399 PFL
    146769 Pickleball TV
    118464 pocket.watch
    138963 PokerGO
     80136 POP
    135844 Popcornflix
     70566 QVC
    135874 Real Madrid TV
    134013 RetroCrush
    128187 Revry
    130712 Revry News
    135835 ROI TV
    118462 Ryan and Friends
     67508 Science
    120010 Scripps News
    132319 Sensical Gaming
    132317 Sensical Jr.
    132320 Sensical Makers
    111132 Shout! Factory
     94823 Smithsonian Channel
     80496 Sony Movie Channel
    132889 SPEEDVISION
    132746 Sports News Highlights
    143989 SportStak
    122695 Start TV
    137124 Swerve Combat
     76634 Syfy
    137752 T2
    121191 Tastemade
    139922 Tastemade Home
    135019 Tastemade Travel
    110217 TeenNick
     70668 Tennis Channel
    141477 TG Jr
    143912 The Big Dish
    129089 The Bob Ross Channel
    132722 The Design Network
    114934 The First
     72411 The Golf Channel
    135842 The Pet Collective
     69008 The Weather Channel
    121623 The Young Turks
     91887 TLC
    141441 Toon Goggles
     75410 Travel Channel HD
    134761 True Crime
    120802 True Crime Now
     88839 TUDN
    126876 TUDNxtra 1
    126889 TUDNxtra 10
    126890 TUDNxtra 11
    126878 TUDNxtra 2
    126879 TUDNxtra 3
    126881 TUDNxtra 4
    126882 TUDNxtra 5
    126883 TUDNxtra 6
    126884 TUDNxtra 7
    126885 TUDNxtra 8
    126888 TUDNxtra 9
     85788 TV Land
     81646 Universal Kids
    134762 Unsolved Mysteries
     85678 USA Network
     75529 VH1
    135384 Washington Post Television
    141948 WeatherSpy
    144954 Whoa! That was Wild!
    139332 Women's Sports Network
    126463 Zona Futbol
Yes, extremely helpful! Thank you so much! :beers:
EDIT TO ADD: Just compared the major channels and their current ID's. Fantastic news: they haven't changed.
I'm getting the below error when I try and download the hls and mpeg m3u streams:
Internal Server Error
The server encountered an internal error and was unable to complete your request. Either the server is overloaded or there is an error in the application.
If that's coming from Channels DVR, check the container log and look at the previous posts here from the last couple days.
I can still access when I manually add each channel. Pasting my list of channels (the local channels and regional sports channels won't work for most, but sharing for those that want to try and quick solution). This assumes your docker and channels server are on the same machine BTW
Just add a new custom channel, use HLS format and text entry and then paste this in:
#EXTM3U
#EXTINF:-1 channel-id="11523" tvg-id="WHP" group-title="fubotv-basic" tvg-logo="https://imgx.fubo.tv/station_logos/whp_c.png" tvc-guide-stationid="11523",CBS (WHP-Harrisburg/Lancaster/ Lebanon/York PA)
http://127.0.0.1:7777/fubo/watch-hls/11523
#EXTINF:-1 channel-id="76019" tvg-id="ESTRLLA" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/estrellatv_c.png" tvc-guide-stationid="65064",ESTRELLA National
http://127.0.0.1:7777/fubo/watch-hls/76019
#EXTINF:-1 channel-id="11782" tvg-id="WPMT" group-title="fubotv-basic" tvg-logo="https://imgx.fubo.tv/station_logos/wpmt_c.png" tvc-guide-stationid="11782",FOX (WPMT-TV – Harrisburg PA)
http://127.0.0.1:7777/fubo/watch-hls/11782
#EXTINF:-1 channel-id="25544" tvg-id="WGAL" group-title="fubotv-basic" tvg-logo="https://imgx.fubo.tv/station_logos/wgal_c.png" tvc-guide-stationid="25544",NBC (WGAL- Lancaster-Harrisburg-Lebanon-York PA)
http://127.0.0.1:7777/fubo/watch-hls/25544
#EXTINF:-1 channel-id="131568" tvg-id="N12NY" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/News12_c.png" tvc-guide-stationid="116946",News 12 New York
http://127.0.0.1:7777/fubo/watch-hls/131568
#EXTINF:-1 channel-id="10239" tvg-id="TELE" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/telemundo_c.png" tvc-guide-stationid="10239",Telemundo (TELE-East Coast)
http://127.0.0.1:7777/fubo/watch-hls/10239
#EXTINF:-1 channel-id="69887" tvg-id="MASNHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/masn-baltimore_c.png" tvc-guide-stationid="69887",MASN (Baltimore)
http://127.0.0.1:7777/fubo/watch-hls/69887
#EXTINF:-1 channel-id="77584" tvg-id="MASN2HD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/masn-2-logo-black.png" tvc-guide-stationid="77584",MASN2 (Washington DC)
http://127.0.0.1:7777/fubo/watch-hls/77584
#EXTINF:-1 channel-id="109261" tvg-id="NBCSPA" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/nbc-sports-philadelphia_c.png" tvc-guide-stationid="17596",NBC Sports Philadelphia
http://127.0.0.1:7777/fubo/watch-hls/109261
#EXTINF:-1 channel-id="101207" tvg-id="NBCSPP" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/nbc-sports-philadelphia-plus_c.png" tvc-guide-stationid="88829",NBC Sports Philadelphia Plus
http://127.0.0.1:7777/fubo/watch-hls/101207
#EXTINF:-1 channel-id="49925" tvg-id="ATTPTHD" group-title="fubotv-basic" tvg-logo="https://imgx.fubo.tv/station_logos/Sportsnet-Pittsburg_c.png" tvc-guide-stationid="49882",SportsNet Pittsburgh
http://127.0.0.1:7777/fubo/watch-hls/49925
#EXTINF:-1 channel-id="16590" tvg-id="ATTPTHDALT" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/sportsnetplus_stack_black.png" tvc-guide-stationid="16590",SportsNet Pittsburgh (Alternate)
http://127.0.0.1:7777/fubo/watch-hls/16590
#EXTINF:-1 channel-id="139932" tvg-id="CRNHOLE" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/ACL-Cornhole-TV_c.png" tvc-guide-stationid="125196",ACL Cornhole TV
http://127.0.0.1:7777/fubo/watch-hls/139932
#EXTINF:-1 channel-id="137849" tvg-id="AXSTNST" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/axstv_c.png" tvc-guide-stationid="123156",AXS TV NOW
http://127.0.0.1:7777/fubo/watch-hls/137849
#EXTINF:-1 channel-id="104589" tvg-id="ACUWTHH" group-title="fubotv-basic" tvg-logo="https://imgx.fubo.tv/station_logos/accuweather_c.png" tvc-guide-stationid="120551",AccuWeather
http://127.0.0.1:7777/fubo/watch-hls/104589
#EXTINF:-1 channel-id="134109" tvg-id="ALWFV" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/af__1080x1080-logo-color.png" tvc-guide-stationid="134109",Always Funny
http://127.0.0.1:7777/fubo/watch-hls/134109
#EXTINF:-1 channel-id="73973" tvg-id="BETHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/BET21_c.png" tvc-guide-stationid="63236",BET
http://127.0.0.1:7777/fubo/watch-hls/73973
#EXTINF:-1 channel-id="159918" tvg-id="BKFCTV" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/bkfc--logo_black.png" tvc-guide-stationid="159918",BKFCTV (VOD2LIVE)
http://127.0.0.1:7777/fubo/watch-hls/159918
#EXTINF:-1 channel-id="137400" tvg-id="BLVF" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/bleav-football_c.png" tvc-guide-stationid="137400",BLEAV Football
http://127.0.0.1:7777/fubo/watch-hls/137400
#EXTINF:-1 channel-id="71605" tvg-id="BTN" group-title="fubotv-basic" tvg-logo="https://imgx.fubo.tv/station_logos/bigten_2020_c.png" tvc-guide-stationid="58321",Big Ten Network
http://127.0.0.1:7777/fubo/watch-hls/71605
#EXTINF:-1 channel-id="84686" tvg-id="BTN2" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/bigten_2020_c.png" tvc-guide-stationid="73115",Big Ten Network Alternate
http://127.0.0.1:7777/fubo/watch-hls/84686
#EXTINF:-1 channel-id="94683" tvg-id="BTN3" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/bigten_2020_c.png" tvc-guide-stationid="82572",Big Ten Network Alternate
http://127.0.0.1:7777/fubo/watch-hls/94683
#EXTINF:-1 channel-id="94684" tvg-id="BTN4" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/bigten_2020_c.png" tvc-guide-stationid="82573",Big Ten Network Alternate
http://127.0.0.1:7777/fubo/watch-hls/94684
#EXTINF:-1 channel-id="152974" tvg-id="BIKEMAG" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/bike-white_b.png" tvc-guide-stationid="152974",Bike Mag
http://127.0.0.1:7777/fubo/watch-hls/152974
#EXTINF:-1 channel-id="135138" tvg-id="BILSTR" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/BilliardTV_c.png" tvc-guide-stationid="120469",Billiard TV
http://127.0.0.1:7777/fubo/watch-hls/135138
#EXTINF:-1 channel-id="83287" tvg-id="BLOOM" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/bloombergTV_c.png" tvc-guide-stationid="71799",Bloomberg Television
http://127.0.0.1:7777/fubo/watch-hls/83287
#EXTINF:-1 channel-id="73067" tvg-id="BOUNCE" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/bounce_c.png" tvc-guide-stationid="73067",Bounce
http://127.0.0.1:7777/fubo/watch-hls/73067
#EXTINF:-1 channel-id="139931" tvg-id="BOXING" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/boxingtv_c.png" tvc-guide-stationid="125195",Boxing TV
http://127.0.0.1:7777/fubo/watch-hls/139931
#EXTINF:-1 channel-id="68797" tvg-id="BVO" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/bravo_c.png" tvc-guide-stationid="58625",Bravo
http://127.0.0.1:7777/fubo/watch-hls/68797
#EXTINF:-1 channel-id="118793" tvg-id="CBSN" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/cbsnews247_500x500_color.png" tvc-guide-stationid="104846",CBS News 24/7
http://127.0.0.1:7777/fubo/watch-hls/118793
#EXTINF:-1 channel-id="69495" tvg-id="CBSSN" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/cbs_sports_network_2021_c.png" tvc-guide-stationid="59250",CBSSN
http://127.0.0.1:7777/fubo/watch-hls/69495
#EXTINF:-1 channel-id="69697" tvg-id="CMTVHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/cmt_c.png" tvc-guide-stationid="59440",CMT
http://127.0.0.1:7777/fubo/watch-hls/69697
#EXTINF:-1 channel-id="68971" tvg-id="CNBC" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/cnbc-logohd-72-dpi-1440-x-1080-4-3-1.png" tvc-guide-stationid="58780",CNBC
http://127.0.0.1:7777/fubo/watch-hls/68971
#EXTINF:-1 channel-id="102148" tvg-id="CHARGE" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/charge_black.png" tvc-guide-stationid="102148",Charge!
http://127.0.0.1:7777/fubo/watch-hls/102148
#EXTINF:-1 channel-id="124684" tvg-id="CLEOHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/CLEOTV_c.png" tvc-guide-stationid="110289",CleoTV
http://127.0.0.1:7777/fubo/watch-hls/124684
#EXTINF:-1 channel-id="73033" tvg-id="CCHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/comedy_central_c.png" tvc-guide-stationid="62420",Comedy Central
http://127.0.0.1:7777/fubo/watch-hls/73033
#EXTINF:-1 channel-id="130049" tvg-id="COMCLN" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Comedy-dynamics_c.png" tvc-guide-stationid="115447",Comedy Dynamics
http://127.0.0.1:7777/fubo/watch-hls/130049
#EXTINF:-1 channel-id="110223" tvg-id="COMET" group-title="fubotv-basic" tvg-logo="https://imgx.fubo.tv/station_logos/comet_c.png" tvc-guide-stationid="97051",Comet
http://127.0.0.1:7777/fubo/watch-hls/110223
#EXTINF:-1 channel-id="123605" tvg-id="COURTST" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/courtTV_c.png" tvc-guide-stationid="123605",Court TV
http://127.0.0.1:7777/fubo/watch-hls/123605
#EXTINF:-1 channel-id="137506" tvg-id="LEGTRI" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/CTVLEGENDARYTRIALS_c.png" tvc-guide-stationid="137506",Court TV Legendary Trials
http://127.0.0.1:7777/fubo/watch-hls/137506
#EXTINF:-1 channel-id="125430" tvg-id="CSTREAM" group-title="fubotv-basic" tvg-logo="https://imgx.fubo.tv/station_logos/CuriosityChannel_c.png" tvc-guide-stationid="110951",Curiosity Channel
http://127.0.0.1:7777/fubo/watch-hls/125430
#EXTINF:-1 channel-id="120761" tvg-id="DABLHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/dabl_c.png" tvc-guide-stationid="120761",Dabl East
http://127.0.0.1:7777/fubo/watch-hls/120761
#EXTINF:-1 channel-id="143350" tvg-id="DMTV" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Dark-MatterTV_c.png" tvc-guide-stationid="128542",Dark Matter
http://127.0.0.1:7777/fubo/watch-hls/143350
#EXTINF:-1 channel-id="124902" tvg-id="DOVESTR" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Dove-Channel_c.png" tvc-guide-stationid="110480",Dove Channel
http://127.0.0.1:7777/fubo/watch-hls/124902
#EXTINF:-1 channel-id="72360" tvg-id="EE" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/e_c.png" tvc-guide-stationid="61812",E! Entertainment Television
http://127.0.0.1:7777/fubo/watch-hls/72360
#EXTINF:-1 channel-id="126128" tvg-id="EARTHX" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/EarthxTV_c.png" tvc-guide-stationid="126128",EarthX TV
http://127.0.0.1:7777/fubo/watch-hls/126128
#EXTINF:-1 channel-id="68900" tvg-id="FBNHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/foxbusiness_c.png" tvc-guide-stationid="58718",FOX Business Network
http://127.0.0.1:7777/fubo/watch-hls/68900
#EXTINF:-1 channel-id="133875" tvg-id="LIVENOW" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/fox_LiveNOW_c.png" tvc-guide-stationid="119219",FOX LiveNOW
http://127.0.0.1:7777/fubo/watch-hls/133875
#EXTINF:-1 channel-id="70522" tvg-id="FNCHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/fox_news_c.png" tvc-guide-stationid="60179",FOX News Channel
http://127.0.0.1:7777/fubo/watch-hls/70522
#EXTINF:-1 channel-id="133868" tvg-id="FOXSOUL" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/fox-soul_c.png" tvc-guide-stationid="119212",FOX Soul
http://127.0.0.1:7777/fubo/watch-hls/133868
#EXTINF:-1 channel-id="94653" tvg-id="FS1" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/fs1_c.png" tvc-guide-stationid="82547",FOX Sports 1
http://127.0.0.1:7777/fubo/watch-hls/94653
#EXTINF:-1 channel-id="69553" tvg-id="FS2" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/fs2_c.png" tvc-guide-stationid="59305",FOX Sports 2
http://127.0.0.1:7777/fubo/watch-hls/69553
#EXTINF:-1 channel-id="135986" tvg-id="FWX" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/fox-weather_c.png" tvc-guide-stationid="121307",FOX Weather
http://127.0.0.1:7777/fubo/watch-hls/135986
#EXTINF:-1 channel-id="135881" tvg-id="FLARMY" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/FailArmy_c.png" tvc-guide-stationid="133321",Fail Army
http://127.0.0.1:7777/fubo/watch-hls/135881
#EXTINF:-1 channel-id="127467" tvg-id="FT" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Familytime_c.png" tvc-guide-stationid="127467",FamilyTime
http://127.0.0.1:7777/fubo/watch-hls/127467
#EXTINF:-1 channel-id="150077" tvg-id="FLORACE" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/floracing-ignite_black1.png" tvc-guide-stationid="150077",FloRacing
http://127.0.0.1:7777/fubo/watch-hls/150077
#EXTINF:-1 channel-id="134759" tvg-id="XSLFF" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Filmrisc-Forensic-Files_c.png" tvc-guide-stationid="134759",Forensic Files
http://127.0.0.1:7777/fubo/watch-hls/134759
#EXTINF:-1 channel-id="113361" tvg-id="XMVFFM" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/filmrisefreemovies_logo_color.png" tvc-guide-stationid="113361",Free Movies
http://127.0.0.1:7777/fubo/watch-hls/113361
#EXTINF:-1 channel-id="1238521113" tvg-id="FM001" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Fubo_Radio_1_c.png",Fubo Radio 1 - Hits Radio
http://127.0.0.1:7777/fubo/watch-hls/1238521113
#EXTINF:-1 channel-id="1238521122" tvg-id="FM010" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Fubo_Radio_10_c.png",Fubo Radio 10 - The 2000s
http://127.0.0.1:7777/fubo/watch-hls/1238521122
#EXTINF:-1 channel-id="1238521114" tvg-id="FM002" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Fubo_Radio_2_c.png",Fubo Radio 2 - Hip-Hop One
http://127.0.0.1:7777/fubo/watch-hls/1238521114
#EXTINF:-1 channel-id="1238521115" tvg-id="FM003" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Fubo_Radio_3_c.png",Fubo Radio 3 - Top Country
http://127.0.0.1:7777/fubo/watch-hls/1238521115
#EXTINF:-1 channel-id="1238521116" tvg-id="FM004" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Fubo_Radio_4_c.png",Fubo Radio 4 - Classic Rock
http://127.0.0.1:7777/fubo/watch-hls/1238521116
#EXTINF:-1 channel-id="1238521117" tvg-id="FM005" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Fubo_Radio_5_c.png",Fubo Radio 5 - Dinner Party
http://127.0.0.1:7777/fubo/watch-hls/1238521117
#EXTINF:-1 channel-id="1238521118" tvg-id="FM006" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Fubo_Radio_6_c.png",Fubo Radio 6 - Coffee Time
http://127.0.0.1:7777/fubo/watch-hls/1238521118
#EXTINF:-1 channel-id="1238521119" tvg-id="FM007" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Fubo_Radio_7_c.png",Fubo Radio 7 - Ɖxitos Latinos
http://127.0.0.1:7777/fubo/watch-hls/1238521119
#EXTINF:-1 channel-id="1238521120" tvg-id="FM008" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Fubo_Radio_8_c.png",Fubo Radio 8 - The 80s
http://127.0.0.1:7777/fubo/watch-hls/1238521120
#EXTINF:-1 channel-id="1238521121" tvg-id="FM009" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Fubo_Radio_9_c.png",Fubo Radio 9 - 90s Alternative
http://127.0.0.1:7777/fubo/watch-hls/1238521121
#EXTINF:-1 channel-id="131359" tvg-id="GLORY" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/glory_c.png" tvc-guide-stationid="131359",GLORY Kickboxing
http://127.0.0.1:7777/fubo/watch-hls/131359
#EXTINF:-1 channel-id="89922" tvg-id="GRIT" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/grit_c.png" tvc-guide-stationid="89922",GRIT
http://127.0.0.1:7777/fubo/watch-hls/89922
#EXTINF:-1 channel-id="79698" tvg-id="GALAHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/galavision_c.png" tvc-guide-stationid="68367",Galavisión
http://127.0.0.1:7777/fubo/watch-hls/79698
#EXTINF:-1 channel-id="116474" tvg-id="GMSHCE" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/game_show_central_logo.png" tvc-guide-stationid="116474",Game Show Central
http://127.0.0.1:7777/fubo/watch-hls/116474
#EXTINF:-1 channel-id="80167" tvg-id="GSNHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/game-show-network_c.png" tvc-guide-stationid="68827",Game Show Network
http://127.0.0.1:7777/fubo/watch-hls/80167
#EXTINF:-1 channel-id="95030" tvg-id="GAC" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/GAC_Family2022_c.png" tvc-guide-stationid="82892",Great American Family
http://127.0.0.1:7777/fubo/watch-hls/95030
#EXTINF:-1 channel-id="125634" tvg-id="GUSTOTV" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/gustotv_c.png" tvc-guide-stationid="111140",Gusto
http://127.0.0.1:7777/fubo/watch-hls/125634
#EXTINF:-1 channel-id="77355" tvg-id="HALLHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/hallmark_channel22_c.png" tvc-guide-stationid="66268",Hallmark Channel
http://127.0.0.1:7777/fubo/watch-hls/77355
#EXTINF:-1 channel-id="119725" tvg-id="HALLDR" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/hf_logo_purpleorchid.png" tvc-guide-stationid="105723",Hallmark Family
http://127.0.0.1:7777/fubo/watch-hls/119725
#EXTINF:-1 channel-id="46730" tvg-id="HMMHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/hmyst-24_logo_lt-violet.png" tvc-guide-stationid="46710",Hallmark Mystery
http://127.0.0.1:7777/fubo/watch-hls/46730
#EXTINF:-1 channel-id="113367" tvg-id="XMVHKN" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/hellskitchenkitchennightmares_logo_color.png" tvc-guide-stationid="113367",Hell's Kitchen/Kitchen Nightmares
http://127.0.0.1:7777/fubo/watch-hls/113367
#EXTINF:-1 channel-id="144256" tvg-id="INFAST" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/infast_c.png" tvc-guide-stationid="129479",INFAST
http://127.0.0.1:7777/fubo/watch-hls/144256
#EXTINF:-1 channel-id="18633" tvg-id="ION" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/ion-logo-color-1b.png" tvc-guide-stationid="122912",ION
http://127.0.0.1:7777/fubo/watch-hls/18633
#EXTINF:-1 channel-id="123651" tvg-id="IMYSSTR" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/ion-mystery_c.png" tvc-guide-stationid="123651",ION Mystery
http://127.0.0.1:7777/fubo/watch-hls/123651
#EXTINF:-1 channel-id="117518" tvg-id="IONPSTR" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/ion_plus_logo_orange.png" tvc-guide-stationid="117518",ION Plus
http://127.0.0.1:7777/fubo/watch-hls/117518
#EXTINF:-1 channel-id="16604" tvg-id="JTV" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/jtv_c.png" tvc-guide-stationid="16604",JTV
http://127.0.0.1:7777/fubo/watch-hls/16604
#EXTINF:-1 channel-id="131621" tvg-id="LSN" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/LSN_c.png" tvc-guide-stationid="116998",Lacrosse Sports Network
http://127.0.0.1:7777/fubo/watch-hls/131621
#EXTINF:-1 channel-id="109553" tvg-id="LCSTR" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/lc-js-box-logo.png" tvc-guide-stationid="109553",Law & Crime
http://127.0.0.1:7777/fubo/watch-hls/109553
#EXTINF:-1 channel-id="113594" tvg-id="LOCALNOW" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/local_now_new_c.png" tvc-guide-stationid="99988",Local Now
http://127.0.0.1:7777/fubo/watch-hls/113594
#EXTINF:-1 channel-id="160472" tvg-id="LOSLA" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/lockedonlosangeles_color.png" tvc-guide-stationid="160472",Locked On Sports Los Angeles
http://127.0.0.1:7777/fubo/watch-hls/160472
#EXTINF:-1 channel-id="160471" tvg-id="LOSTD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/lockedonsportstoday_color.png" tvc-guide-stationid="160471",Locked On Sports Today
http://127.0.0.1:7777/fubo/watch-hls/160471
#EXTINF:-1 channel-id="75083" tvg-id="MSNBC" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/msnbc-logo-72-dpi-296-x-106-148-53-1.png" tvc-guide-stationid="64241",MSNBC
http://127.0.0.1:7777/fubo/watch-hls/75083
#EXTINF:-1 channel-id="71401" tvg-id="MTVHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/mtv_c.png" tvc-guide-stationid="60964",MTV
http://127.0.0.1:7777/fubo/watch-hls/71401
#EXTINF:-1 channel-id="159240" tvg-id="FUBOMC" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/16x9.png" tvc-guide-stationid="159240",Man Cave Movies (VOD2LIVE)
http://127.0.0.1:7777/fubo/watch-hls/159240
#EXTINF:-1 channel-id="1283550001" tvg-id="MARQN" group-title="fubotv-basic" tvg-logo="https://imgx.fubo.tv/station_logos/marquee_c.png" tvc-guide-stationid="113768",Marquee Sports Network (National)
http://127.0.0.1:7777/fubo/watch-hls/1283550001
#EXTINF:-1 channel-id="139933" tvg-id="MOTO" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/moto-americatv_c.png" tvc-guide-stationid="125197",MotoAmerica TV
http://127.0.0.1:7777/fubo/watch-hls/139933
#EXTINF:-1 channel-id="128770" tvg-id="NBCNN" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/nbc-news-now-logo-300-dpi-1440-x-1440-1-1-1.png" tvc-guide-stationid="114174",NBC News NOW
http://127.0.0.1:7777/fubo/watch-hls/128770
#EXTINF:-1 channel-id="104156" tvg-id="UNIVE" group-title="fubotv-basic" tvg-logo="https://imgx.fubo.tv/station_logos/nbc_universo_c.png" tvc-guide-stationid="91588",NBC Universo
http://127.0.0.1:7777/fubo/watch-hls/104156
#EXTINF:-1 channel-id="128875" tvg-id="LX" group-title="fubotv-basic" tvg-logo="https://imgx.fubo.tv/station_logos/LX_News_c.png" tvc-guide-stationid="114278",NBCLX
http://127.0.0.1:7777/fubo/watch-hls/128875
#EXTINF:-1 channel-id="45409" tvg-id="NFLHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/nfl_network_2020_c.png" tvc-guide-stationid="45399",NFL Network
http://127.0.0.1:7777/fubo/watch-hls/45409
#EXTINF:-1 channel-id="129307" tvg-id="NFLALT2" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/nfl_network_alternate_c.png" tvc-guide-stationid="129307",NFL Network Alternate 2
http://127.0.0.1:7777/fubo/watch-hls/129307
#EXTINF:-1 channel-id="103625" tvg-id="WGNA" group-title="fubotv-basic" tvg-logo="https://imgx.fubo.tv/station_logos/news_nation_c.png" tvc-guide-stationid="91096",NewsNation
http://127.0.0.1:7777/fubo/watch-hls/103625
#EXTINF:-1 channel-id="97163" tvg-id="NEWSMXHUS" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/newsmax_c.png" tvc-guide-stationid="97163",Newsmax
http://127.0.0.1:7777/fubo/watch-hls/97163
#EXTINF:-1 channel-id="121162" tvg-id="NSMX2" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/newsmax2.png" tvc-guide-stationid="121162",Newsmax2
http://127.0.0.1:7777/fubo/watch-hls/121162
#EXTINF:-1 channel-id="94767" tvg-id="NICJRHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/nickjr_c.png" tvc-guide-stationid="82649",Nick Jr.
http://127.0.0.1:7777/fubo/watch-hls/94767
#EXTINF:-1 channel-id="69687" tvg-id="NIKHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/nickelodeon_c.png" tvc-guide-stationid="59432",Nickelodeon
http://127.0.0.1:7777/fubo/watch-hls/69687
#EXTINF:-1 channel-id="139513" tvg-id="ORIG" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/originsports_c.png" tvc-guide-stationid="124817",Origin Sports Network
http://127.0.0.1:7777/fubo/watch-hls/139513
#EXTINF:-1 channel-id="81949" tvg-id="OXG" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/oxygen2021_c.png" tvc-guide-stationid="70522",Oxygen True Crime
http://127.0.0.1:7777/fubo/watch-hls/81949
#EXTINF:-1 channel-id="127399" tvg-id="PFLMMA" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/PFL_c.png" tvc-guide-stationid="127399",PFL
http://127.0.0.1:7777/fubo/watch-hls/127399
#EXTINF:-1 channel-id="80136" tvg-id="POP" group-title="fubotv-basic" tvg-logo="https://imgx.fubo.tv/station_logos/PopTV_Logo2020_c.png" tvc-guide-stationid="68796",POP
http://127.0.0.1:7777/fubo/watch-hls/80136
#EXTINF:-1 channel-id="69429" tvg-id="PARHD" group-title="fubotv-basic" tvg-logo="https://imgx.fubo.tv/station_logos/paramount_network_canada_c.png" tvc-guide-stationid="59186",Paramount Network
http://127.0.0.1:7777/fubo/watch-hls/69429
#EXTINF:-1 channel-id="128628" tvg-id="PG" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Perfect-Game_c.png" tvc-guide-stationid="128628",Perfect Game TV
http://127.0.0.1:7777/fubo/watch-hls/128628
#EXTINF:-1 channel-id="146769" tvg-id="PBTV" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/PickleTV23_c.png" tvc-guide-stationid="146769",Pickleball TV
http://127.0.0.1:7777/fubo/watch-hls/146769
#EXTINF:-1 channel-id="152977" tvg-id="POWDER" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/powder-white_b.png" tvc-guide-stationid="152977",Powder
http://127.0.0.1:7777/fubo/watch-hls/152977
#EXTINF:-1 channel-id="70566" tvg-id="QVCHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/QVC_c.png" tvc-guide-stationid="60222",QVC
http://127.0.0.1:7777/fubo/watch-hls/70566
#EXTINF:-1 channel-id="135874" tvg-id="RMADUSHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/realmadridtv_c.png" tvc-guide-stationid="121197",Real Madrid TV
http://127.0.0.1:7777/fubo/watch-hls/135874
#EXTINF:-1 channel-id="132889" tvg-id="SPDVSN" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Speedvision_c.png" tvc-guide-stationid="132889",SPEEDVISION
http://127.0.0.1:7777/fubo/watch-hls/132889
#EXTINF:-1 channel-id="140284" tvg-id="SNC" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/salem_news_channel_logo.png" tvc-guide-stationid="140284",Salem News Channel
http://127.0.0.1:7777/fubo/watch-hls/140284
#EXTINF:-1 channel-id="120010" tvg-id="NEWSYST" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Scripps-News_c.png" tvc-guide-stationid="96827",Scripps News
http://127.0.0.1:7777/fubo/watch-hls/120010
#EXTINF:-1 channel-id="93564" tvg-id="SHOPLCH" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/shoplc--deliveringjoy.png" tvc-guide-stationid="93564",ShopLC
http://127.0.0.1:7777/fubo/watch-hls/93564
#EXTINF:-1 channel-id="68703" tvg-id="SMITH_HD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/smithsonian_c.png" tvc-guide-stationid="58532",Smithsonian Channel
http://127.0.0.1:7777/fubo/watch-hls/68703
#EXTINF:-1 channel-id="152975" tvg-id="BOARDER" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/snbrdr_logomediakit_b4.png" tvc-guide-stationid="152975",Snowboarder
http://127.0.0.1:7777/fubo/watch-hls/152975
#EXTINF:-1 channel-id="143989" tvg-id="SPRTSTK" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/SportStak_c.png" tvc-guide-stationid="129212",SportStak
http://127.0.0.1:7777/fubo/watch-hls/143989
#EXTINF:-1 channel-id="122695" tvg-id="STRTD" group-title="fubotv-basic" tvg-logo="https://imgx.fubo.tv/station_logos/starttv_c.png" tvc-guide-stationid="109454",Start TV
http://127.0.0.1:7777/fubo/watch-hls/122695
#EXTINF:-1 channel-id="152976" tvg-id="SURFER" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/surfer-white_b.png" tvc-guide-stationid="152976",Surfer
http://127.0.0.1:7777/fubo/watch-hls/152976
#EXTINF:-1 channel-id="137124" tvg-id="SWSPRTS" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Swerve-combat23_c.png" tvc-guide-stationid="122436",Swerve Combat
http://127.0.0.1:7777/fubo/watch-hls/137124
#EXTINF:-1 channel-id="68795" tvg-id="SYFY" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/syfy_c.png" tvc-guide-stationid="58623",Syfy
http://127.0.0.1:7777/fubo/watch-hls/68795
#EXTINF:-1 channel-id="137752" tvg-id="T2" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/T2_live-tennis_c.png" tvc-guide-stationid="137752",T2
http://127.0.0.1:7777/fubo/watch-hls/137752
#EXTINF:-1 channel-id="102116" tvg-id="TBD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/tbd---black.png" tvc-guide-stationid="102116",TBD.
http://127.0.0.1:7777/fubo/watch-hls/102116
#EXTINF:-1 channel-id="88839" tvg-id="UDNHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/tudn_c.png" tvc-guide-stationid="77033",TUDN
http://127.0.0.1:7777/fubo/watch-hls/88839
#EXTINF:-1 channel-id="126876" tvg-id="TUDNX1" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/TUDNxtra1n_c.png" tvc-guide-stationid="112349",TUDNxtra 1
http://127.0.0.1:7777/fubo/watch-hls/126876
#EXTINF:-1 channel-id="126889" tvg-id="TUDNX10" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/TUDNxtra10n_c.png" tvc-guide-stationid="112362",TUDNxtra 10
http://127.0.0.1:7777/fubo/watch-hls/126889
#EXTINF:-1 channel-id="126890" tvg-id="TUDNX11" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/TUDNxtra11n_c.png" tvc-guide-stationid="112363",TUDNxtra 11
http://127.0.0.1:7777/fubo/watch-hls/126890
#EXTINF:-1 channel-id="126878" tvg-id="TUDNX2" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/TUDNxtra2n_c.png" tvc-guide-stationid="112351",TUDNxtra 2
http://127.0.0.1:7777/fubo/watch-hls/126878
#EXTINF:-1 channel-id="126879" tvg-id="TUDNX3" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/TUDNxtra3n_c.png" tvc-guide-stationid="112352",TUDNxtra 3
http://127.0.0.1:7777/fubo/watch-hls/126879
#EXTINF:-1 channel-id="126881" tvg-id="TUDNX4" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/TUDNxtra4n_c.png" tvc-guide-stationid="112354",TUDNxtra 4
http://127.0.0.1:7777/fubo/watch-hls/126881
#EXTINF:-1 channel-id="126882" tvg-id="TUDNX5" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/TUDNxtra5n_c.png" tvc-guide-stationid="112355",TUDNxtra 5
http://127.0.0.1:7777/fubo/watch-hls/126882
#EXTINF:-1 channel-id="126883" tvg-id="TUDNX6" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/TUDNxtra6_c.png" tvc-guide-stationid="112356",TUDNxtra 6
http://127.0.0.1:7777/fubo/watch-hls/126883
#EXTINF:-1 channel-id="126884" tvg-id="TUDNX7" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/TUDNxtra7n_c.png" tvc-guide-stationid="112357",TUDNxtra 7
http://127.0.0.1:7777/fubo/watch-hls/126884
#EXTINF:-1 channel-id="126885" tvg-id="TUDNX8" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/TUDNxtra8n_c.png" tvc-guide-stationid="112358",TUDNxtra 8
http://127.0.0.1:7777/fubo/watch-hls/126885
#EXTINF:-1 channel-id="126888" tvg-id="TUDNX9" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/TUDNxtra9n_c.png" tvc-guide-stationid="112361",TUDNxtra 9
http://127.0.0.1:7777/fubo/watch-hls/126888
#EXTINF:-1 channel-id="85147" tvg-id="TVLNDHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/tv_land_c.png" tvc-guide-stationid="73541",TV Land
http://127.0.0.1:7777/fubo/watch-hls/85147
#EXTINF:-1 channel-id="121191" tvg-id="TASTE" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Tastemade_c.png" tvc-guide-stationid="107076",Tastemade
http://127.0.0.1:7777/fubo/watch-hls/121191
#EXTINF:-1 channel-id="139922" tvg-id="TMHOME" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/TastemadeHome_c.png" tvc-guide-stationid="125187",Tastemade Home
http://127.0.0.1:7777/fubo/watch-hls/139922
#EXTINF:-1 channel-id="135019" tvg-id="TMTRAVEL" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/TastemadeTravel_c.png" tvc-guide-stationid="120351",Tastemade Travel
http://127.0.0.1:7777/fubo/watch-hls/135019
#EXTINF:-1 channel-id="143912" tvg-id="BIGDISH" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/TheBigDish_c.png" tvc-guide-stationid="129135",The Big Dish
http://127.0.0.1:7777/fubo/watch-hls/143912
#EXTINF:-1 channel-id="157506" tvg-id="TBSFAST" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/logo-the-boat-show.png" tvc-guide-stationid="157506",The Boat Show
http://127.0.0.1:7777/fubo/watch-hls/157506
#EXTINF:-1 channel-id="129089" tvg-id="TBRCSTR" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Bob-ross-channel_c.png" tvc-guide-stationid="114491",The Bob Ross Channel
http://127.0.0.1:7777/fubo/watch-hls/129089
#EXTINF:-1 channel-id="132722" tvg-id="TDN" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/the-design-network_c.png" tvc-guide-stationid="118087",The Design Network
http://127.0.0.1:7777/fubo/watch-hls/132722
#EXTINF:-1 channel-id="114934" tvg-id="FIRST" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/The_First_c.png" tvc-guide-stationid="114934",The First
http://127.0.0.1:7777/fubo/watch-hls/114934
#EXTINF:-1 channel-id="72411" tvg-id="GLFC" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/GOLF_PGAT_c.png" tvc-guide-stationid="61854",The Golf Channel
http://127.0.0.1:7777/fubo/watch-hls/72411
#EXTINF:-1 channel-id="147367" tvg-id="THENEST" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/the-nest---blue.png" tvc-guide-stationid="147367",The Nest
http://127.0.0.1:7777/fubo/watch-hls/147367
#EXTINF:-1 channel-id="135842" tvg-id="PETCOLL" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/The-Pet-Collective23_c.png" tvc-guide-stationid="110356",The Pet Collective
http://127.0.0.1:7777/fubo/watch-hls/135842
#EXTINF:-1 channel-id="69008" tvg-id="WEATHHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/the_weather_channel22_c.png" tvc-guide-stationid="58812",The Weather Channel
http://127.0.0.1:7777/fubo/watch-hls/69008
#EXTINF:-1 channel-id="152978" tvg-id="SKATE" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/twskate-white_b3.png" tvc-guide-stationid="152978",Transworld Skateboarding
http://127.0.0.1:7777/fubo/watch-hls/152978
#EXTINF:-1 channel-id="134761" tvg-id="XSLFRTC" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/TrueCrime_c.png" tvc-guide-stationid="134761",True Crime
http://127.0.0.1:7777/fubo/watch-hls/134761
#EXTINF:-1 channel-id="68602" tvg-id="USAN" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/usa-network2021_c.png" tvc-guide-stationid="58452",USA Network
http://127.0.0.1:7777/fubo/watch-hls/68602
#EXTINF:-1 channel-id="855130001" tvg-id="UNIMHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/unimas2021_c.png" tvc-guide-stationid="73882",UniMƔs
http://127.0.0.1:7777/fubo/watch-hls/855130001
#EXTINF:-1 channel-id="81646" tvg-id="SPR" group-title="fubotv-basic" tvg-logo="https://imgx.fubo.tv/station_logos/universal_kids_c.png" tvc-guide-stationid="70225",Universal Kids
http://127.0.0.1:7777/fubo/watch-hls/81646
#EXTINF:-1 channel-id="792940001" tvg-id="UNIHD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/univision_c.png" tvc-guide-stationid="68049",Univision Network
http://127.0.0.1:7777/fubo/watch-hls/792940001
#EXTINF:-1 channel-id="134762" tvg-id="XSLUM" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Filmrise-Unsolved-Mysteries_c.png" tvc-guide-stationid="134762",Unsolved Mysteries
http://127.0.0.1:7777/fubo/watch-hls/134762
#EXTINF:-1 channel-id="70365" tvg-id="VH1HD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/vh1_c.png" tvc-guide-stationid="60046",VH1
http://127.0.0.1:7777/fubo/watch-hls/70365
#EXTINF:-1 channel-id="12345001" tvg-id="WNBAOU1" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/wnba_ion_horiz_fire.png" tvc-guide-stationid="12345001",WNBA on ION
http://127.0.0.1:7777/fubo/watch-hls/12345001
#EXTINF:-1 channel-id="139332" tvg-id="WSN" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/wsnlogocolor_1920x1080.png" tvc-guide-stationid="124636",Women's Sports Network
http://127.0.0.1:7777/fubo/watch-hls/139332
#EXTINF:-1 channel-id="159241" tvg-id="FUBOXO" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/xoxo_keyart_ntwk_series_16x9.jpg" tvc-guide-stationid="159241",XOXO Fubo (VOD2LIVE)
http://127.0.0.1:7777/fubo/watch-hls/159241
#EXTINF:-1 channel-id="119429" tvg-id="BEIN2" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/bein-laliga_c.png" tvc-guide-stationid="102850",beIN La Liga
http://127.0.0.1:7777/fubo/watch-hls/119429
#EXTINF:-1 channel-id="88749" tvg-id="BEIN1HD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/bein_sports_english_c.png" tvc-guide-stationid="76950",beIN SPORTS
http://127.0.0.1:7777/fubo/watch-hls/88749
#EXTINF:-1 channel-id="105107" tvg-id="BEIN4" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/bein_connect_4_c.png" tvc-guide-stationid="92443",beIN SPORTS 4
http://127.0.0.1:7777/fubo/watch-hls/105107
#EXTINF:-1 channel-id="105103" tvg-id="BEIN5" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/bein_connect_5_c.png" tvc-guide-stationid="92439",beIN SPORTS 5
http://127.0.0.1:7777/fubo/watch-hls/105103
#EXTINF:-1 channel-id="105101" tvg-id="BEIN6" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/bein_connect_6_c.png" tvc-guide-stationid="92437",beIN SPORTS 6
http://127.0.0.1:7777/fubo/watch-hls/105101
#EXTINF:-1 channel-id="105102" tvg-id="BEIN7" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/bein_connect_7_c.png" tvc-guide-stationid="92438",beIN SPORTS 7
http://127.0.0.1:7777/fubo/watch-hls/105102
#EXTINF:-1 channel-id="105100" tvg-id="BEIN8" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/bein_connect_8_c.png" tvc-guide-stationid="92436",beIN SPORTS 8
http://127.0.0.1:7777/fubo/watch-hls/105100
#EXTINF:-1 channel-id="88754" tvg-id="BEIN2HD" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/bein_sports_spanish_c.png" tvc-guide-stationid="76943",beIN SPORTS En EspaƱol
http://127.0.0.1:7777/fubo/watch-hls/88754
#EXTINF:-1 channel-id="127712" tvg-id="BEINXTRA" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/beINSportsXtra_c.png" tvc-guide-stationid="120375",beIN SPORTS Xtra
http://127.0.0.1:7777/fubo/watch-hls/127712
#EXTINF:-1 channel-id="134321" tvg-id="BEIXE" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/beINSportsXtra_n_c.png" tvc-guide-stationid="119661",beIN SPORTS Xtra En EspaƱol
http://127.0.0.1:7777/fubo/watch-hls/134321
#EXTINF:-1 channel-id="131622" tvg-id="FMOVTV" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/fubo-movies23_c.png" tvc-guide-stationid="116999",fubo Movie Network
http://127.0.0.1:7777/fubo/watch-hls/131622
#EXTINF:-1 channel-id="120123" tvg-id="FNETTV" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/fubo-sports23_c.png" tvc-guide-stationid="106100",fubo Sports Network
http://127.0.0.1:7777/fubo/watch-hls/120123
#EXTINF:-1 channel-id="1238520002" tvg-id="FNETTV2" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/Fubo_Sports_2_c.png" tvc-guide-stationid="125447",fubo Sports Network 2
http://127.0.0.1:7777/fubo/watch-hls/1238520002
#EXTINF:-1 channel-id="94674" tvg-id="GETTV" group-title="fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/getTV_c.png" tvc-guide-stationid="82563",getTV
http://127.0.0.1:7777/fubo/watch-hls/94674
#EXTINF:-1 channel-id="123916" tvg-id="FNBCS4K" group-title="4k-screen;fubotv-basic" tvg-logo="https://images.fubo.tv/station_logos/NBCS4K_c.png" tvc-guide-stationid="117038",NBC Sports 4K
http://127.0.0.1:7777/fubo/watch-hls/123916
#EXTINF:-1 channel-id="127430" tvg-id="DUST" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/alien-nation-logo-black.png" tvc-guide-stationid="112881",Alien Nation by DUST
http://127.0.0.1:7777/fubo/watch-hls/127430
#EXTINF:-1 channel-id="141981" tvg-id="ATHFHM" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/AtHome_c.png" tvc-guide-stationid="127174",At Home with Family Handyman
http://127.0.0.1:7777/fubo/watch-hls/141981
#EXTINF:-1 channel-id="73952" tvg-id="BHERHD" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/bet_her_c.png" tvc-guide-stationid="63220",BET Her
http://127.0.0.1:7777/fubo/watch-hls/73952
#EXTINF:-1 channel-id="30419" tvg-id="BETJ" group-title="fubo-extra-lite" tvg-logo="https://imgx.fubo.tv/station_logos/bet_jams_c.png" tvc-guide-stationid="30419",BET Jams
http://127.0.0.1:7777/fubo/watch-hls/30419
#EXTINF:-1 channel-id="18718" tvg-id="BETSOUL" group-title="fubo-extra-lite" tvg-logo="https://imgx.fubo.tv/station_logos/bet_soul_c.png" tvc-guide-stationid="18718",BET Soul
http://127.0.0.1:7777/fubo/watch-hls/18718
#EXTINF:-1 channel-id="113452" tvg-id="BUZZRST" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/buzzr_logo_color.png" tvc-guide-stationid="113452",BUZZR
http://127.0.0.1:7777/fubo/watch-hls/113452
#EXTINF:-1 channel-id="120491" tvg-id="BAYW" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/baywatch_logo_image_color_640x260.png" tvc-guide-stationid="120491",Baywatch
http://127.0.0.1:7777/fubo/watch-hls/120491
#EXTINF:-1 channel-id="26849" tvg-id="CNBCWLD" group-title="fubo-extra-lite;news-plus" tvg-logo="https://images.fubo.tv/station_logos/cnbc_world_c.png" tvc-guide-stationid="26849",CNBC World
http://127.0.0.1:7777/fubo/watch-hls/26849
#EXTINF:-1 channel-id="124916" tvg-id="XMVCH" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/cheaters_logo_color.png" tvc-guide-stationid="124916",Cheaters
http://127.0.0.1:7777/fubo/watch-hls/124916
#EXTINF:-1 channel-id="148063" tvg-id="CHESSTV" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/chesstv_c.png" tvc-guide-stationid="148063",ChessTV
http://127.0.0.1:7777/fubo/watch-hls/148063
#EXTINF:-1 channel-id="130949" tvg-id="XCIRCLE" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/CircleCountry_c.png" tvc-guide-stationid="116338",Circle Country
http://127.0.0.1:7777/fubo/watch-hls/130949
#EXTINF:-1 channel-id="113364" tvg-id="XMVFCT" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/filmriseclassictv_logo_color.png" tvc-guide-stationid="113364",Classic TV
http://127.0.0.1:7777/fubo/watch-hls/113364
#EXTINF:-1 channel-id="1355160001" tvg-id="NSYCONF" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/NoseyConfess_c.png" tvc-guide-stationid="1355160001",Confess by Nosey (G)
http://127.0.0.1:7777/fubo/watch-hls/1355160001
#EXTINF:-1 channel-id="150076" tvg-id="CRMPUN" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/crime_and_punishment_dark.png" tvc-guide-stationid="150076",Crime and Punishment
http://127.0.0.1:7777/fubo/watch-hls/150076
#EXTINF:-1 channel-id="147688" tvg-id="DOGWHSP" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/tdw_logo_black.png" tvc-guide-stationid="147688",Dog Whisperer
http://127.0.0.1:7777/fubo/watch-hls/147688
#EXTINF:-1 channel-id="120205" tvg-id="ESTVSTR" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/ESTV_c.png" tvc-guide-stationid="120205",ESTV
http://127.0.0.1:7777/fubo/watch-hls/120205
#EXTINF:-1 channel-id="138686" tvg-id="FFCL" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/familyfeudclassic_channel_logo_horizontal_color.png" tvc-guide-stationid="138686",Family Feud Classic
http://127.0.0.1:7777/fubo/watch-hls/138686
#EXTINF:-1 channel-id="129134" tvg-id="GADV" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/GA_Adventures_c.png" tvc-guide-stationid="129134",Great American Adventures
http://127.0.0.1:7777/fubo/watch-hls/129134
#EXTINF:-1 channel-id="103351" tvg-id="GACLHD" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/GreatAmerican-Faith_Living23_c.png" tvc-guide-stationid="90858",Great American Faith & Living
http://127.0.0.1:7777/fubo/watch-hls/103351
#EXTINF:-1 channel-id="135379" tvg-id="HWNEST1" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/History-Warfare_c.png" tvc-guide-stationid="135379",History & Warfare Now
http://127.0.0.1:7777/fubo/watch-hls/135379
#EXTINF:-1 channel-id="11066" tvg-id="INSP" group-title="fubo-extra-lite" tvg-logo="https://imgx.fubo.tv/station_logos/insp2022_c.png" tvc-guide-stationid="82773",INSP
http://127.0.0.1:7777/fubo/watch-hls/11066
#EXTINF:-1 channel-id="161323" tvg-id="INSITRA" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/intravel_logo_portrpngt_color.eps" tvc-guide-stationid="161323",INTRAVEL
http://127.0.0.1:7777/fubo/watch-hls/161323
#EXTINF:-1 channel-id="144254" tvg-id="INSIWON" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/InWonder_c.png" tvc-guide-stationid="129477",INWONDER
http://127.0.0.1:7777/fubo/watch-hls/144254
#EXTINF:-1 channel-id="133890" tvg-id="RLNOSEY" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/JudgeNosey_c.png" tvc-guide-stationid="119234",Judge Nosey
http://127.0.0.1:7777/fubo/watch-hls/133890
#EXTINF:-1 channel-id="90742" tvg-id="JUST" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/Justice-CentralTV_c.png" tvc-guide-stationid="78850",Justice Central
http://127.0.0.1:7777/fubo/watch-hls/90742
#EXTINF:-1 channel-id="110114" tvg-id="LOGOHD" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/logo_c.png" tvc-guide-stationid="96971",Logo
http://127.0.0.1:7777/fubo/watch-hls/110114
#EXTINF:-1 channel-id="1245810001" tvg-id="LOVEST" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/Love-StoriesTV_c.png" tvc-guide-stationid="1245810001",Love Stories TV (G)
http://127.0.0.1:7777/fubo/watch-hls/1245810001
#EXTINF:-1 channel-id="72650" tvg-id="MLBHD" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/MLB_Network_c.png" tvc-guide-stationid="62081",MLB Network
http://127.0.0.1:7777/fubo/watch-hls/72650
#EXTINF:-1 channel-id="104879" tvg-id="MTVCLHD" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/mtv_classic_c.png" tvc-guide-stationid="22561",MTV Classic
http://127.0.0.1:7777/fubo/watch-hls/104879
#EXTINF:-1 channel-id="49175" tvg-id="MTVLIVE" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/mtv_live_c.png" tvc-guide-stationid="49141",MTV Live
http://127.0.0.1:7777/fubo/watch-hls/49175
#EXTINF:-1 channel-id="86781" tvg-id="MTV2HD" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/mtv2_c.png" tvc-guide-stationid="75077",MTV2
http://127.0.0.1:7777/fubo/watch-hls/86781
#EXTINF:-1 channel-id="44229" tvg-id="MTVU" group-title="fubo-extra-lite" tvg-logo="https://imgx.fubo.tv/station_logos/mtvU_c.png" tvc-guide-stationid="44228",MTVU
http://127.0.0.1:7777/fubo/watch-hls/44229
#EXTINF:-1 channel-id="134814" tvg-id="MAGUTC1" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/MGTVNow_c.png" tvc-guide-stationid="119209",Magellan
http://127.0.0.1:7777/fubo/watch-hls/134814
#EXTINF:-1 channel-id="1215340001" tvg-id="MBLC" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/maverick_black_cinema_c.png" tvc-guide-stationid="1215340001",Maverick Black Cinema (G)
http://127.0.0.1:7777/fubo/watch-hls/1215340001
#EXTINF:-1 channel-id="113781" tvg-id="MST3K" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/MysteryScienceTheater_c.png" tvc-guide-stationid="113781",Mystery Science Theater
http://127.0.0.1:7777/fubo/watch-hls/113781
#EXTINF:-1 channel-id="1421090001" tvg-id="MYTH247" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/Mythical247_c.png" tvc-guide-stationid="1421090001",Mythical 24/7 (G)
http://127.0.0.1:7777/fubo/watch-hls/1421090001
#EXTINF:-1 channel-id="45537" tvg-id="NBATV" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/nba_tv_c.png" tvc-guide-stationid="45526",NBA TV
http://127.0.0.1:7777/fubo/watch-hls/45537
#EXTINF:-1 channel-id="68871" tvg-id="NHLNET" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/NHL_Network_c.png" tvc-guide-stationid="58690",NHL Network
http://127.0.0.1:7777/fubo/watch-hls/68871
#EXTINF:-1 channel-id="30418" tvg-id="NMZK" group-title="fubo-extra-lite" tvg-logo="https://imgx.fubo.tv/station_logos/teen_music_c.png" tvc-guide-stationid="30418",NickMusic
http://127.0.0.1:7777/fubo/watch-hls/30418
#EXTINF:-1 channel-id="30420" tvg-id="NIKTON" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/nicktoons_c.png" tvc-guide-stationid="82654",Nicktoons
http://127.0.0.1:7777/fubo/watch-hls/30420
#EXTINF:-1 channel-id="151830" tvg-id="NS90S" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/ns90s_logos_color_square-copy.png" tvc-guide-stationid="151830",Non-Stop ā€˜90s
http://127.0.0.1:7777/fubo/watch-hls/151830
#EXTINF:-1 channel-id="133889" tvg-id="NOSEY" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/nosey_c.png" tvc-guide-stationid="119233",Nosey
http://127.0.0.1:7777/fubo/watch-hls/133889
#EXTINF:-1 channel-id="128911" tvg-id="OTVSTR" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/outside_tv_logo_color.png" tvc-guide-stationid="68295",Outside TV
http://127.0.0.1:7777/fubo/watch-hls/128911
#EXTINF:-1 channel-id="137212" tvg-id="PAAFRUS" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/PeopleAreAwesome_c.png" tvc-guide-stationid="122524",People Are Awesome
http://127.0.0.1:7777/fubo/watch-hls/137212
#EXTINF:-1 channel-id="138963" tvg-id="PKGFAST" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/pocker-go_c.png" tvc-guide-stationid="124268",PokerGO
http://127.0.0.1:7777/fubo/watch-hls/138963
#EXTINF:-1 channel-id="134013" tvg-id="RRCRUSH" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/Retro-crush_c.png" tvc-guide-stationid="119355",RetroCrush
http://127.0.0.1:7777/fubo/watch-hls/134013
#EXTINF:-1 channel-id="128187" tvg-id="REVRY" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/Revrynew_c.png" tvc-guide-stationid="113603",Revry
http://127.0.0.1:7777/fubo/watch-hls/128187
#EXTINF:-1 channel-id="157959" tvg-id="RIGTV" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/rig-tv-logo-colour.png" tvc-guide-stationid="157959",Rig TV
http://127.0.0.1:7777/fubo/watch-hls/157959
#EXTINF:-1 channel-id="132319" tvg-id="SENGMG" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/Sensical_Gaming_c.png" tvc-guide-stationid="132319",Sensical Gaming
http://127.0.0.1:7777/fubo/watch-hls/132319
#EXTINF:-1 channel-id="132317" tvg-id="SENJR" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/SensicalJr1_c.png" tvc-guide-stationid="132317",Sensical Jr.
http://127.0.0.1:7777/fubo/watch-hls/132317
#EXTINF:-1 channel-id="132320" tvg-id="SENMKRS" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/Sensical_MAKERS_c.png" tvc-guide-stationid="132320",Sensical Makers
http://127.0.0.1:7777/fubo/watch-hls/132320
#EXTINF:-1 channel-id="111132" tvg-id="SFTVSTR" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/shoutTV_c.png" tvc-guide-stationid="111132",Shout! Factory
http://127.0.0.1:7777/fubo/watch-hls/111132
#EXTINF:-1 channel-id="80496" tvg-id="SONYHD" group-title="fubo-extra-lite" tvg-logo="https://imgx.fubo.tv/station_logos/sony-movie-channel_c.png" tvc-guide-stationid="69091",Sony Movie Channel
http://127.0.0.1:7777/fubo/watch-hls/80496
#EXTINF:-1 channel-id="1353800001" tvg-id="SSNEST1" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/Space-Science_c.png" tvc-guide-stationid="1353800001",Space Science Now (G)
http://127.0.0.1:7777/fubo/watch-hls/1353800001
#EXTINF:-1 channel-id="121598" tvg-id="SPRSWP" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/sms_logo_horizontal_color.png" tvc-guide-stationid="121598",Supermarket Sweep
http://127.0.0.1:7777/fubo/watch-hls/121598
#EXTINF:-1 channel-id="1242210001" tvg-id="TED" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/TED_channel_c.png" tvc-guide-stationid="1242210001",TED (G)
http://127.0.0.1:7777/fubo/watch-hls/1242210001
#EXTINF:-1 channel-id="110217" tvg-id="TNCKHD" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/teen_nick_c.png" tvc-guide-stationid="97047",TeenNick
http://127.0.0.1:7777/fubo/watch-hls/110217
#EXTINF:-1 channel-id="70668" tvg-id="TENISHD" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/tennis-channel_c.png" tvc-guide-stationid="60316",Tennis Channel
http://127.0.0.1:7777/fubo/watch-hls/70668
#EXTINF:-1 channel-id="124329" tvg-id="JOL" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/jamie-oliver_channel_logo_stacked_color.png" tvc-guide-stationid="124329",The Jamie Oliver Channel
http://127.0.0.1:7777/fubo/watch-hls/124329
#EXTINF:-1 channel-id="124310" tvg-id="TPIR60" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/tpir_color_logo.png" tvc-guide-stationid="124310",The Price is Right: Barker Era
http://127.0.0.1:7777/fubo/watch-hls/124310
#EXTINF:-1 channel-id="120802" tvg-id="TCNT" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/TrueCrimeNow_c.png" tvc-guide-stationid="120802",True Crime Now
http://127.0.0.1:7777/fubo/watch-hls/120802
#EXTINF:-1 channel-id="1292090001" tvg-id="MOJOTV" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/watchmojo_c.png" tvc-guide-stationid="1292090001",WatchMojo (G)
http://127.0.0.1:7777/fubo/watch-hls/1292090001
#EXTINF:-1 channel-id="141948" tvg-id="WTHRSPY" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/WeatherSpy_c.png" tvc-guide-stationid="127141",WeatherSpy
http://127.0.0.1:7777/fubo/watch-hls/141948
#EXTINF:-1 channel-id="124405" tvg-id="XMVFW" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/filmrisewestern_logo_color.png" tvc-guide-stationid="124405",Western
http://127.0.0.1:7777/fubo/watch-hls/124405
#EXTINF:-1 channel-id="144954" tvg-id="WHOA" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/WhoaThatWasWild_c.png" tvc-guide-stationid="144954",Whoa! That was Wild!
http://127.0.0.1:7777/fubo/watch-hls/144954
#EXTINF:-1 channel-id="1353820001" tvg-id="WNNEST1" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/wildoceans_color.png" tvc-guide-stationid="1353820001",Wild Oceans (G)
http://127.0.0.1:7777/fubo/watch-hls/1353820001
#EXTINF:-1 channel-id="149167" tvg-id="XMVWPV" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/worldswildestpolicevideos_fullcolor_logo.png" tvc-guide-stationid="149167",World's Wildest Police Videos
http://127.0.0.1:7777/fubo/watch-hls/149167
#EXTINF:-1 channel-id="1402500001" tvg-id="XS" group-title="fubo-extra-lite" tvg-logo="https://images.fubo.tv/station_logos/XplorationStation_c.png" tvc-guide-stationid="1402500001",Xploration Station (G)
http://127.0.0.1:7777/fubo/watch-hls/1402500001
#EXTINF:-1 channel-id="126463" tvg-id="ZONFUT" group-title="fubo-extra-lite" tvg-logo="https://imgx.fubo.tv/station_logos/zona-futbol_new_c.png" tvc-guide-stationid="111945",Zona Futbol
http://127.0.0.1:7777/fubo/watch-hls/126463
#EXTINF:-1 channel-id="138563" tvg-id="QUICKTK" group-title="news-plus" tvg-logo="https://images.fubo.tv/station_logos/BBOriginals_c.png" tvc-guide-stationid="123870",Bloomberg Originals
http://127.0.0.1:7777/fubo/watch-hls/138563
#EXTINF:-1 channel-id="114796" tvg-id="CHEDDAR" group-title="news-plus" tvg-logo="https://images.fubo.tv/station_logos/cheddarNEWS_c.png" tvc-guide-stationid="107241",Cheddar News
http://127.0.0.1:7777/fubo/watch-hls/114796
#EXTINF:-1 channel-id="135835" tvg-id="WROI" group-title="news-plus" tvg-logo="https://images.fubo.tv/station_logos/ROI-TV_c.png" tvc-guide-stationid="135835",ROI TV
http://127.0.0.1:7777/fubo/watch-hls/135835
#EXTINF:-1 channel-id="130712" tvg-id="RVRYNWS" group-title="news-plus" tvg-logo="https://images.fubo.tv/station_logos/RevryNews_c.png" tvc-guide-stationid="116102",Revry News
http://127.0.0.1:7777/fubo/watch-hls/130712
#EXTINF:-1 channel-id="121623" tvg-id="TYT" group-title="news-plus" tvg-logo="https://images.fubo.tv/station_logos/TYTlogo_c.png" tvc-guide-stationid="107478",The Young Turks
http://127.0.0.1:7777/fubo/watch-hls/121623
#EXTINF:-1 channel-id="135384" tvg-id="WAPOTV" group-title="news-plus" tvg-logo="https://images.fubo.tv/channel-config-ui/station-logos/on-white/wapotv_logo_bw-1920x1080px.jpg" tvc-guide-stationid="135384",Washington Post Television
http://127.0.0.1:7777/fubo/watch-hls/135384
#EXTINF:-1 channel-id="123265" tvg-id="AFNEWS" group-title="news-plus" tvg-logo="https://images.fubo.tv/station_logos/Africanews_c.png" tvc-guide-stationid="109016",africanews
http://127.0.0.1:7777/fubo/watch-hls/123265
#EXTINF:-1 channel-id="19039" tvg-id="EURNEWS" group-title="news-plus" tvg-logo="https://imgx.fubo.tv/station_logos/euronews23_c.png" tvc-guide-stationid="19039",euronews
http://127.0.0.1:7777/fubo/watch-hls/19039
#EXTINF:-1 channel-id="116116" tvg-id="I24NEHD" group-title="news-plus" tvg-logo="https://images.fubo.tv/station_logos/i24news_c.png" tvc-guide-stationid="102309",i24NEWS
http://127.0.0.1:7777/fubo/watch-hls/116116
I'm building my list off of your template, and I'm making good progress. I have 2 questions.
  1. Where do you get the "tvc-guide-stationid" from?
  2. Can you have comments in the middle of the list?
You can look them up on the olive tin container
I have never installed or used Olive Tin. Can you point me to some installation instructions?
The Fubo Docker created the file I pasted before whatever change happened that no longer allows it to be created. Luckily I had downloaded a copy previously. There was a way to get the station ID from Zap2It, I'm assuming you can do the same with the gracenote alternative (lookup the channel on their guide, right click on the channel logo and look for the 5 digit in the image link and use that).
No clue on the comments, it's not my code, I'm just pasting what was created.
I discovered that it was simpler to create a custom m3u file and then add it to Stream Link Manager. I only selected the channels that I genuinely wanted. Since the channels were already set up in Stream Link Manager, all I had to do was define the source. I only chose about 10 channels from Fubo that I truly desired. I already have the others or have them through other sources because Fubo doesn’t carry certain networks.
