Level-Up Your Game with a Multi-Gig LAN Switch - NETGEAR Blog
Hard-Wired or Go Home
Despite the most recent advancements in WiFi technology, most gamers choose to hard-wire their PC or Console to the router. Hard-wiring your network is the only way to ensure that the network is not to blame if you crash and burn. With a hardwired connection, you can be assured that you are getting the absolute fastest speeds and the lowest latency with no lag from your internet connections. But that’s not all – you’ll want to get some super-fast lanes on that switch!
The only question is - why is it relevant to Channels?
