How to force Channels DVR to reload 'custom' override comskip.ini
#1
In order to experiment with changes to my custom override comskip.ini I would like to rerun comskip with new parameters on some recordings by using this method.
How do I force Channels DVR to read in and use my custom override comskip.ini in the data directory after I've modified it to change the parameters, before I recomskip the recording?
#2
It will use the ini from ./data when comskip runs.
#3
Thanks, indeed it does!
#4
Is this considered the data directory?
41%20PM
#5
No, the data directory is where the software is installed. You will see a message in the Log like "Starting Channels DVR xxxxxxx in /path/to/data"
