What you're showing us is Chrome on your Windows machine -- which doesn't factor into this equation.
You need to login to the Chrome instance in your Docker container. The way you get to that is using VNC. The easiest way is noVNC, which is found on port 6080.
In a browser, on this Windows machine, go to http://<insert.ip.address.here>:6080/vnc.html. That'll connect you to Chrome in the container, where there will already be 2 tabs open. Open a 3rd, and navigate to whatever site you need to login to. Do whatever you need to do to authenticate with a given site. You can then close that tab, and that tab only.
Now you're authenticated, and should be able to stream channels that use that browser authentication.
EDIT: BTW, a 3rd generation i7 is pretty marginal for this kind of thing -- so acceptable results are far from guaranteed. That chip was launched 14 years ago.
