i just discovered keyboard shortcuts for my harmony remote (and i have no clue how i missed this before), but the one i haven't been able to get working is "recordings." i have the blue button mapped to recordings, but it doesn't do anything. the button itself works, because if i change it to a different shortcut, it works...but recordings does not work.
Do you have the Recordings tab enabled on your navigation?
yup
Okay must be a bug then. I will try it out tomorrow
Fixed in beta
awesome, thanks!
