Kids Fire tablet missing movies and episodes
Any new insight into the issue, possible tests, or fixes?
I am not demanding priority, but request at least some sort of timeline for looking at the diagnostics. @tmm1 @maddox
Nothing popped out in diagnostics unfortunately. We are still investigating.
I tried updating the beta and installed the alpha, but they all act similar.
Seems like DVR recorded shows will show 1 episode, the next up episode.
Imported tv shows show no episodes at all.
Movies section is totally blank.
Do I have too many movies and shows for a fire tablets memory?
Is there an settings in the tablet or app I could try to test or toggle?
I am still in limbo, my kids are the main reason I subscribe with channels. Really need to solve this. @tmm1 @maddox
Sorry. Can you find an older beta apk which still works? That may help us understand when/why things broke.
I am not sure this answer was for my issue... I am not sure how I find alternate beta pack APKs nor how to load them. Please give more detailed instructions, to find and load alternate versions. I am only aware to use the fire store or your own app to load channels versions.
Please provide me with additional details how to get and install older versions and I will gladly help to pinpoint the issue.
To download the apk for a specific beta, find the version and use this url:
https://cdn.channelsdvr.net/apk-beta/v2024.01.01.1010
In what tool? I cant browse that url... How do I download an apk or install it?
Follow this guide and use this tool to download APKs and install them.
https://www.aftvnews.com/sideload-apk-app-amazon-fire-tv-stick-lite-cube-edition-firestick-downloader/
Find older builds and their build numbers on the beta release thread:
@DriVeR the issue is that your DVR library is quite big, and the Fire tablet device is running out of memory while downloading the list of episodes and movies. This is why it appears empty. Then the client receives updates about content and downloads those updates individually, which makes them start to appear.
We will need to investigate further how to mitigate this issue for large DVRs.
I have tried the beta loads near, either before or after the last 4-5 stable load going back to v2023.09.11.2351, and they all act the same.
I was just about to ask if I could try the same thing for my Server DVR, that I host on a Sysology NAS. Would need advice on getting the beta load files onto it, to see if rolling that back would help. Let me know if I should try that.
I did note I have a large library a few days ago, I must say I am surprised as there is over 500meg of memory available on the tablets and it says Channels is only requesting/using ~75megs.
Is there a setting to allow the app to use more memory? As I checked in developer mode and there is over 500megs free..
I take it forcing kids mode did not limit the memory pull, to only kids tagged movies and shows?
Any advice for what "quite big" is? Is it just number of recordings, ie each episode of a show = a movie?
Would it be of value to try and slim my library down?
To what target 1000, 10000, 32k recordings?
I think you're looking at storage space but the error is a OutOfMemory error due to RAM usage
You could try spinning up a test dvr with only kids content as a way to slim things down
I am sure it was RAM 500Meg left of the 2GB. Required developer mode to see it.
Appreciate the idea, but I am not that SW skilled. Need a few more details on how I would you spin up a Test DVR? Can you have 2 Instances running at once on the same computer/NAS?
You can install a copy on another computer or NAS. Or on an existing NAS you could use Docker to setup another installation.
I started up your docker image in bridge mode, with port 8088 linked to 8089, and can get to it from web browser at IP:8088, but how do i get the tablets to connect? They cant find the bridge IP nor the use a different port.
The main DVR is at the same IP:8089, so the tablet chooses that one...
This is supposed to work:
Settings > [Channels Logo] > At Home > IP:PORT
I might have found an additional bug then in the FIRE version. In my case it cannot find the docker when I specify the IP:PORT. Yet I can get to it via a web browser on a windows computer on the same network.
