LinkPi encoder family
Do you still have the two hdmi dongles to do an experiment?
Perhaps the GUI is intentionally hiding an actual hardcoded stream connection from the encoder. Sometimes, marketing people actually have engineers disable this kind of stuff to sell the higher end models.
Now this is a real long shot, but If I had a second dongle, Id send one test signal into the 1st usb dongle. By default, the play url is: http://xxx.xxx.xxx.xxx/live/stream1 > we all know that one works and it appears in the dashboard preview and stream settings in the UI.
What are the odds that if you plugged a second dongle in another USB port at the same time the first port is used for the 1st USB dongle. Then send it a different test stream , and have a look at http://xxx.xxx.xxx.xxx/live/stream2. Would we see another stream?
Its a remote possibility that this is the case, but I wish I had a 2nd dongle here for a quick test
@babsonnexus , do you have a second dongle in house for that quick test?
anyone else?
No, still have to buy a second USB-to-HDMI convertor so I can do the test; haven't gotten around to it, yet.
well, it's connected to my 2nd linkpi of course. :nerd_face:
I will see if I can give your idea a shot, but the 1st usb cam needed to have it's stream turned on at first if i remember right.
Its probably worth getting the LinkPi with more tuners at that point
You need to hook your usb dongle to a hdmi source. An onn box, etc and plug into one of the linkpi usb ports (any) make sure you are sending something, coukd be the home menu on your onn box.
Then take a second hdmi source. Make sure that is different, so you can visually see what source is what. That should come from a different onn box, or a firestick, or any active hdmi video source. Then plug that into your second dongle. Plug that into another different usb port on the linkpi.
Then first see if in the linkpi dashboard on the ui, you see two different usb previews.
If not, humor me and even if you dont see it in the dashboard preview, see if it appears on the url i suggested.
Its a longshot, but worth a quick experiment.
Thank you!
As far a “stream turned on” yes, there is a place to configure the usb stream encoding and outout in the linkpi ui. I hoping that the usb configuration that you can see in the link pi ui would be used for both.
Again- a real longshot here. Dont spend too much time on this. I can order another dongle from amazon and test here if needed.
This is hardware playground. Its worth a quick experiment before shelling out for a 5 port device, or another single uray encoder.
so plugging a 2nd usb encoder into the linkpi hijacks the usb cam input to the new one. :expressionless: had to reboot pi to get 1st one back
also I'm using my linkpi's to decode security camera's so http://10.0.0.121/live/stream2, 3, and 4 were those and I tried 5 and 6 to be sure.
Good timing. My 2nd USB HDMI dongle came in yesterday.
I was playing around today, and I got root ssh access to the linkpi.
I poked around for about an hour and did find the second USB port definitions in the LinkPi firmware after plugging the 2nd dongle into another port, but I couldnt find anywhere a hook to safely restart the actual encoder running process that attaches to the USB port without risking bricking my unit.
I didnt want to take that risk. In hindsight, I would have purchased the ENC5v2 2+ years ago.
Wanna sell me one of your spares?
I haven't had any HDMI or encoder issues happened to me. Most of my issues is usually with the onn puck or firetv device which I why I keep them awake since they can't seem to wake up at times
Get a laptop cooler and some zip ties around them and they'll be fine
Alternatively, if you like to get down and dirty you can try install some heatsinks on each of them but laptop cooler and zip ties are more easier
I had one box get stuck on 720 a while back, you could change the setting, but did not survive reboots, and only sometimes survived sleep. I had to factory reset that box. wonder if yours got stuck trying to serve a hdr feed.
@maddox
In an earlier post, you were joining us using the Link Pi Enc8 encoder. How’s it working for you? I have the 5 port version but am considering upgrading to the 8 port instead of running two 5 port encoders.
8 source inputs for $450, that's impressive if this is the device you are referring to:
https://www.amazon.com/dp/B0DRP4F3ZB
Yep. I was looking to get another 5 port and the 8 port pop’d up. If I get the 8 port, I'd only have to run 1 encoder and have a backup. For a little over $100 more, it's enticing.
if you don't need a box, bare board is only 399! that's only $50 per tuner :thinking:
FWIW, ENC5 HDMI inputs are 4k30, ENC8 HDMI inputs are 1080P60.
That's a good point but I don’t see much 4K in my viewing habits.
Me neither. Actually, I never use 4k at all. It's just something I happened to notice when I was shopping for an encoder. :person_shrugging:
Something else I considered when looking at the ENC8. It shows output (encode) at 1080P30x8. If using all eight input, does the encode really max out at 30 FPS?
stealing my job! LOL
