Local FOX channel issue TVE
Howdy, just wondering if this is a ChannelsDVR issue or something else. I am able to log into fox.com/live and i can see and stream my local fox channel. Here is the error code that is showing.
Thanks for any info.
GET: https://api3.fox.com/v2.0/liveplayer/5836e0173f93d90001ab6539?geoLatitude=43.611547196019856&geoLongitude=-116.16117178266235&epgListingId=KNIN-program-KNIN-1768509000000: 403 Forbidden: "{\"@context\":\"http://www.w3.org/ns/hydra/context.jsonld\",\"@type\":\"Error\",\"n…\":\"Invalid AccessToken Key Id\",\"detail\":\"Key Id not found or supported\"}\n"
FOX TVE hasn’t worked for the last couple years.
Thanks, to be honest I haven't even tried in the last couple of years so not surprised.
This project will bring in your local Fox station to Channels DVR using Fox One.
It will authenticate using your Provider credentials, just like CDVR TVE.
Just enable Fox One Linear channels in the latest version of the project to get these channels (if available to you at the Fox One website using your Provider credentials)
  • B1G Network
  • FOX
  • FOX Business Network
  • FOX Deportes
  • FOX News Channel
  • FS1
  • FS2
  • Fox Live Now
  • Fox Soul
  • Fox Weather
  • Masked Singer
  • MyNetwork TV
  • TMZ
You can enable/disable each channel separately
A post was merged into an existing topic: Fox TVE 6002 not working
Thank you i didn't even think about EPLusTV, that did the trick.
