The Prime receives QAM on the coax line from IP (Xfinity IP)
QAM uses the same 6 MHz bandwidth as ATSC, using a standard known as [ITU-Recommendation J.83 Annex B ("J.83b") which is used to deliver digital cable channels which are encoded and transmitted via cable provider (IP).
Hence, in my setup cable provider (Xfinity) also delivers TVE (Xfinity)- all on the same coax line. But to receive TVE (Xfinity) I also have to subscribe to Xfinity TV
So is that clearer for an unknown (maybe novice) user? My posts are usually in response to same unless I know the poster, but your 1st post was really 2 parts: (1) âMetronet is installing fibre In order to use TVE I would need to subscribe to one of their TV packages, wouldnât I?â (2) âmy HDHR Primes would be useless since they donât support cable card
â Even though you didnât pose as a question my response was intended to answer both.
To be precise I could have posted (1) No, but you would need to subscribe to MetroNet as your Internet Provider (IP) and (2) Your Prime can still be used for all TVE providers, including MetroNet and/or YouTube (TV), Hulu, etc.
BUT: Wasnât it you who asked for more info on the process, How does that work, Debbie?â, hence I assumed that you were not a technical user and I didnât know exactly what more info you wanted.
The posting is not muddy as it stands without all the whereas and wherefors. However, since you think it is muddy I will gladly revisit tomorrow and read it again for clarity. Were you just kidding or tongue in cheek?
BTW: Did you really read my 1st segment ?:
âPrime uses both CC and TVE via coax connect to IP Provider (in my case...Xfinity)
Prime also supports TVE from other Providers (Hulu, YouTube TV, etc.) but via IP Provider (Fios, Xfinity, and hopefully...Metronet, etc.)â
Then, sorry if I was wrong.
