NFL channel and Redzone channel
Noticed that the NFL network is showing the same “invalid response” message that the NFL REDZONE channel was giving last weekend.
Anyone else lose the NFL network.
Note: the redzone now authenticates again without the invalid response, but just shows stream temporarily unavailable which makes sense.
I tried on stable release and latest prerelease just now.
I can authenticate both on the TVE websites.
Yes,
As of this morning, invalid response. (Spectrum in Wisconsin)
I reported this last night and again this morning on another thread. When I look at my channel list (Vidgo), I see the RedZone (with a check mark) but for the NFL Network is see this:
Is anyone from Channels support or development looking at this? Footfall weekend is approaching.
Yes we're looking into it. You don't need to keep creating new threads.
See response on your previous thread: RedZone Playback Failed After Adding It
What about the problem with the NFL Network?
Try v2021.09.16.1925
Rescanned the NFL Channel after installing version 2021.09.16.1925 and restarting the server. Thanks
Trying to re-add since update did not help and it spins and spins.
and finally.....
Will need details... which provider for instance? Please submit diagnostics too.
Optimum
c6e9f358-8cca-4552-b52a-deab3a91378e
SlingTV - no login form found
Logs have been submitted as e944a0ea-4f72-4e91-a021-e1ff7269d1dc
I'm fixed over here in Wisconsin. Thank you very much for such a quick solution.
@tmm1
I am running Pre Release 2021.09.18.0311 and using FuboTV. I subscribe to NFL Network and NFL RedZone and I am getting the error message "No Login Form Found" for both channels. I tried rescanning with no luck. Logs have been sent.
c90711fa-3872-42f5-9855-194fb8fc09c8
Thanks will fix
Try latest build
i still cannot watch NFL Network
logged in with DirecTV:
2021/09/19 09:36:13.215019 [ERR] Failed to start stream for ch6192: TVE: no stream found
2021/09/19 09:36:13.299656 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.0.118: TVE: no stream found
2021/09/19 09:36:13.299748 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.0.118
2021/09/19 09:36:14.611651 [ERR] Failed to start stream for ch6192: TVE: no stream found
2021/09/19 09:36:14.659076 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.0.118: TVE: no stream found
2021/09/19 09:36:14.659197 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.0.118
2021/09/19 09:36:15.355169 [ERR] Failed to start stream for ch6192: TVE: no stream found
2021/09/19 09:36:15.391506 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.0.118: TVE: no stream found
2021/09/19 09:36:15.391608 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.0.118
2021/09/19 09:36:16.477313 [ERR] Failed to start stream for ch6192: TVE: no stream found
2021/09/19 09:36:16.523725 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.0.118: TVE: no stream found
2021/09/19 09:36:16.523824 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.0.118
2021/09/19 09:36:17.425780 [ERR] Failed to start stream for ch6192: TVE: no stream found
2021/09/19 09:36:17.496448 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.0.118: TVE: no stream found
2021/09/19 09:36:17.496555 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.0.118
2021/09/19 09:36:18.610313 [ERR] Failed to start stream for ch6192: TVE: no stream found
2021/09/19 09:36:18.633918 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.0.118: TVE: no stream found
2021/09/19 09:36:18.634030 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.0.118
2021/09/19 09:36:19.535067 [ERR] Failed to start stream for ch6192: TVE: no stream found
2021/09/19 09:36:19.575802 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.0.118: TVE: no stream found
2021/09/19 09:36:19.575898 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.0.118
2021/09/19 09:36:20.866681 [ERR] Failed to start stream for ch6192: TVE: no stream found
2021/09/19 09:36:20.915379 [HLS] Couldn't generate stream playlist for ch6192-dANY-ip192.168.0.118: TVE: no stream found
2021/09/19 09:36:20.915482 [HLS] Stopping transcoder session ch6192-dANY-ip192.168.0.118
here are the logs from when i tried to rescan the channel
Broken again for me. Wouldn't tune and tried to rescan and it say "no stream found".
