OliveTin EZ-Start: A New Way to Deploy OliveTin-for-Channels Using Just Two Environment Variables to Get Started!
Not sure what could be going on there, but you might consider deleting Portainer, along with its image and volume:
docker stop portainer
docker rm portainer
docker volume rm portainer_data
docker rmi portainer/portainer-ce:latest
And then follow the instructions here for installing Portainer and the full version of OliveTin-for-Channels using a variation on the EZ-Start process:
There'd be no need for you to install anything via the Portainer-Stacks Editor. You'd be installing EZ-Start via the command line to port 1338, and then use it to install Portainer and the full version of OliveTin-for-Channels on port 1337 using Project One-Click.
BRILLIANT!!! Worked like a charm. Thank you for helping me through that!
I am stuck :frowning:
I am running on a Mac with Docker Desktop, Portainer installed
When running OliveTin Environment Variables Generator/Tester
I get this:
Error: No such object: olivetin
cat: /config/olivetin.token: No such file or directory
I played around with Host_Dir, even setting the variable manually. It does create and update files in /Users/admin/olivetin
I created the /olivetin/config directory manually, gave full read/write to everyone on the entire olivetin folder
I have gone as far as resetting my Docker desktop back to defaults.
I can get SLM running with no issues, just not olivetin. I even tried from the command line installing olivetin -> Portainer, I hit a different error.
TAG=latest
DOMAIN=
HOST_PORT=1337
CHANNELS_DVR_HOST=192.168.144.146
CHANNELS_DVR_PORT=8089
CHANNELS_CLIENTS=
ALERT_SMTP_SERVER=
ALERT_EMAIL_FROM=
ALERT_EMAIL_PASS=
ALERT_EMAIL_TO=
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
TZ=US/Eastern
HOST_DIR=/Users/admin/
DVR_SHARE=/Users/admin/channels-data
LOGS_SHARE=/Users/admin/Library/Application Support/ChannelsDVR
TUBEARCHIVIST_SHARE=/Users/admin/channels-data
DVR2_SHARE=
LOGS2_SHARE=
TUBEARCHIVIST2_SHARE=
DVR3_SHARE=
LOGS3_SHARE=
TUBEARCHIVIST3_SHARE=
HOST_SFS_PORT=8080
FOLDER=/web
PORTAINER_TOKEN=
PORTAINER_HOST=192.168.144.146
PORTAINER_PORT=9443
PORTAINER_ENV=2
PERSISTENT_LOGS=false
Any help would be greatly appreciated!
Do you have the full version of Portainer installed? Or, did you install the Portainer extension from within Docker Desktop?
I tried first with the extension, then I also tried installing the full version using the advanced method.
Currently I am back to the extension.
The extension won't work, you need the full version.
I'd suggest clearing the decks, by deleting the extension and the full version, and then use the "next generation" version of EZ-Start to install both Portainer and the full version of OliveTin.
Be sure to delete the Docker Volume portainer_data too, or the Portainer token creation process will fail. You should probably delete any portainer or olivetin images as well, in the interest of really starting fresh.
@bnhf
Finally got around to installing Olive Tin on my test server NAS (Synology). My ultimate goal is to install Project One-Click on the Test Server then add to the Production Server.
I believe everything installed correctly but thought I'd put my Post Health Check for inspection as well as the compose and environments before I move on to the next step.
Post Health Check:
Checking your OliveTin-for-Channels installation...
(extended_check=false)
OliveTin Container Version 2025.09.26
OliveTin Docker Compose Version 2025.08.25
Checking that your selected Channels DVR server (10.0.1.194:8089) is reachable by URL:
HTTP Status: 200 indicates success...
100  1276  100  1276    0     0  1246k      0 --:--:-- --:--:-- --:--:-- 1246k
HTTP Status: 200
Effective URL: http://10.0.1.194:8089/
Checking that your selected Channels DVR server's data files (/mnt/10.0.1.194-8089) are accessible:
Folders with the names Database, Images, Imports, Logs, Movies, Streaming and TV should be visible...
total 0
d--------- 1 root   root     22 Sep 27  2023 #recycle
d--------- 1 root   root    116 Nov 13 06:00 .
drwxr-xr-x 1 root   root    106 Nov 13 11:12 ..
drwxrwxrwx 1 root   root      8 Sep 23 16:32 @eaDir
drwx------ 1 242120 242120 1320 Nov 13 05:32 Database
drwx------ 1 242120 242120  104 Nov  8 10:14 Images
drwx------ 1 242120 242120   28 Sep 26  2023 Imports
drwx------ 1 242120 242120   32 Sep 26  2023 Logs
drwx------ 1 242120 242120    4 Nov  7 20:42 Metadata
drwx------ 1 242120 242120   40 Nov 13 06:00 Streaming
drwx------ 1 242120 242120   96 Nov 13 06:00 TV
Docker reports your current DVR_SHARE setting as...
/volume1/ChannelsDVR
If the listed folders are NOT visible, AND you have your Channels DVR and Docker on the same system:
Channels reports this path as...
Checking that your selected Channels DVR server's log files (/mnt/10.0.1.194-8089_logs) are accessible:
Folders with the names data and latest should be visible...
total 4
drwxr-xr-x 1 242120 242120  200 Nov 13 05:32 .
drwxr-xr-x 1 242120 242120  154 Sep 25 17:27 2025.09.25.2220
drwxr-xr-x 1 242120 242120  154 Sep 25 20:28 2025.09.26.0118
drwxr-xr-x 1 242120 242120  154 Oct  9 15:18 2025.10.04.0225
drwxr-xr-x 1 242120 242120  134 Oct 29 13:19 2025.10.28.0018
drwxr-xr-x 1 242120 242120  134 Oct 29 21:19 2025.10.30.0047
drwxr-xr-x 1 242120 242120  154 Nov 13 05:32 2025.11.07.0832
drwxr-xr-x 1 242120 242120 1048 Nov 13 11:05 data
lrwxrwxrwx 1 242120 242120   15 Nov 13 05:32 latest -> 2025.11.07.0832
Docker reports your current LOGS_SHARE setting as...
/var/packages/ChannelsDVR/target/channels-dvr
Checking if your Portainer token is working on ports 9000 and/or 9443:
Portainer http response on port 9000 reports version 2.33.3
Portainer Environment ID for local is 2
Portainer https response on port 9443 reports version
Here's a list of your current OliveTin-related settings:
HOSTNAME=olivetin
CHANNELS_DVR=10.0.1.194:8089
CHANNELS_DVR_ALTERNATES=
CHANNELS_CLIENTS=
ALERT_SMTP_SERVER=
ALERT_EMAIL_FROM=[Redacted]@
ALERT_EMAIL_PASS=[Redacted]
ALERT_EMAIL_TO=[Redacted]@
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
PORTAINER_TOKEN=[Redacted]
PORTAINER_HOST=10.0.1.194
PORTAINER_PORT=9443
PORTAINER_ENV=2
Here's the contents of /etc/resolv.conf from inside the container:
search local
nameserver 127.0.0.11
options ndots:0
Here's the contents of /etc/hosts from inside the container:
127.0.0.1	localhost
::1	localhost ip6-localhost ip6-loopback
fe00::0	ip6-localnet
ff00::0	ip6-mcastprefix
ff02::1	ip6-allnodes
ff02::2	ip6-allrouters
172.23.0.2	olivetin
Compose:
services:
  olivetin: # This docker-compose typically requires no editing. Use the Environment variables section of Portainer to set your values.
    # 2025.08.25
    # GitHub home for this project: https://github.com/bnhf/OliveTin.
    # Docker container home for this project with setup instructions: https://hub.docker.com/r/bnhf/olivetin.
    image: bnhf/olivetin:${TAG:-latest} # Add the tag like latest or test to the environment variables below.
    container_name: ${OLIVETIN_NAME:-olivetin}${EZ_START}
    hostname: ${OLIVETIN_NAME:-olivetin}${EZ_START}
    dns_search: ${DOMAIN:+${DOMAIN}} # For Tailscale users using Magic DNS, add your Tailnet (tailxxxxx.ts.net) to use hostnames for remote nodes, otherwise use your local domain name.
    ports:
      - ${HOST_PORT:-1337}:1337
    environment:
      - OLIVETIN_COMPOSE=2025.08.25${EZ_START} # Do not change this value.
      - CHANNELS_DVR=${CHANNELS_DVR_HOST}:${CHANNELS_DVR_PORT:-8089} # Add your Channels DVR server in the form CHANNELS_DVR_HOST=<hostname or ip> and CHANNELS_DVR_PORT=<port>.
      - CHANNELS_DVR_ALTERNATES=${CHANNELS_DVR2_HOST:+${CHANNELS_DVR2_HOST}:${CHANNELS_DVR2_PORT}}${CHANNELS_DVR3_HOST:+ ${CHANNELS_DVR3_HOST}:${CHANNELS_DVR3_PORT}} # Space separated list of alternate Channels DVR servers to choose from in the form hostname:port or ip:port.
      - CHANNELS_CLIENTS=${CHANNELS_CLIENTS} # Space separated list of Channels DVR clients you'd like notifications sent to in the form hostname or IP.
      - ALERT_SMTP_SERVER=${ALERT_SMTP_SERVER} # SMTP server to use for sending alert e-mails. smtp.gmail.com:587 for example.
      - ALERT_EMAIL_FROM=${ALERT_EMAIL_FROM} # Sender address for alert e-mails.
      - ALERT_EMAIL_PASS=${ALERT_EMAIL_PASS} # SMTP "app" password established through GMail or Yahoo Mail. Do not use your everyday e-mail address.
      - ALERT_EMAIL_TO=${ALERT_EMAIL_TO} # Recipient address for alert e-mails.
      - UPDATE_YAMLS=${UPDATE_YAMLS:-true} # Set this to true to update config.yaml.
      - UPDATE_SCRIPTS=${UPDATE_SCRIPTS:-true} # Set this to true to update all included scripts.
      - TZ=${TZ} # Add your local timezone in standard linux format. E.G. US/Eastern, US/Central, US/Mountain, US/Pacific, etc.
      - PORTAINER_TOKEN=${PORTAINER_TOKEN} # Generate via <username> dropdown (upper right of WebUI), "My account", API tokens.
      - PORTAINER_HOST=${PORTAINER_HOST:-$CHANNELS_DVR_HOST} # Hostname or IP of the Docker host you're running Portainer on.
      - PORTAINER_PORT=${PORTAINER_PORT:-9443} # https port you're running Portainer on. 9443 is the default.
      - PORTAINER_ENV=${PORTAINER_ENV:-2} # Set this is if you're using an alternate Portainer Environment for some reason. 2 is the default.
      - PERSISTENT_LOGS=${PERSISTENT_LOGS:-false} # For supported Actions, log files are retained on an ongoing basis. false is the default.
    volumes:
      - ${HOST_DIR:-/unused}${HOST_DIR:+/olivetin:/config} # Add the parent directory on your Docker host you'd like to use.
      - ${DVR_SHARE:-/unused}${DVR_SHARE:+:/mnt/${CHANNELS_DVR_HOST}-${CHANNELS_DVR_PORT}} # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your Channels DVR network share.
      - ${LOGS_SHARE:-/unused}${LOGS_SHARE:+:/mnt/${CHANNELS_DVR_HOST}-${CHANNELS_DVR_PORT}_logs} # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your Channels DVR logs network share.
      - ${TUBEARCHIVIST_SHARE:-/unused}${TUBEARCHIVIST_SHARE:+:/mnt/${CHANNELS_DVR_HOST}-${CHANNELS_DVR_PORT}_ta} # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your TubeArchivist videos network share.
      - ${DVR2_SHARE:-/unused}${DVR2_SHARE:+:/mnt/${CHANNELS_DVR2_HOST}-${CHANNELS_DVR2_PORT}} # Note that these volume mounts should always be to /mnt/hostname-port or /mnt/ip-port (dash rather than a colon between).
      - ${LOGS2_SHARE:-/unused}${LOGS2_SHARE:+:/mnt/${CHANNELS_DVR2_HOST}-${CHANNELS_DVR2_PORT}_logs} # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your Channels DVR logs network share.
      - ${TUBEARCHIVIST2_SHARE:-/unused}${TUBEARCHIVIST2_SHARE:+:/mnt/${CHANNELS_DVR2_HOST}-${CHANNELS_DVR2_PORT}_ta} # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your TubeArchivist videos network share.
      - ${DVR3_SHARE:-/unused}${DVR3_SHARE:+:/mnt/${CHANNELS_DVR3_HOST}-${CHANNELS_DVR3_PORT}} # Note that these volume mounts should always be to /mnt/hostname-port or /mnt/ip-port (dash rather than a colon between).
      - ${LOGS3_SHARE:-/unused}${LOGS3_SHARE:+:/mnt/${CHANNELS_DVR3_HOST}-${CHANNELS_DVR3_PORT}_logs} # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your Channels DVR logs network share.
      - ${TUBEARCHIVIST3_SHARE:-/unused}${TUBEARCHIVIST3_SHARE:+:/mnt/${CHANNELS_DVR3_HOST}-${CHANNELS_DVR3_PORT}_ta} # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your TubeArchivist videos network share.
      - /var/run/docker.sock:/var/run/docker.sock
    restart: unless-stopped
  static-file-server:
    image: halverneus/static-file-server:latest
    container_name: ${SFS_NAME:-static-file-server}${EZ_START}
    dns_search: ${DOMAIN}
    ports:
      - ${HOST_SFS_PORT:-0}:8080
    environment:
      - FOLDER=${FOLDER:-/web}
    volumes:
      - ${HOST_DIR:-/unused}${HOST_DIR:+/olivetin/data:${FOLDER:-/web}}
#0#volumes: # Remove the #x# to enable. Use this section if you've setup a docker volume named channels-dvr, with CIFS or NFS, to bind to /mnt/dvr inside the container. Set ${DVR_SHARE} to channels-dvr (DVR_SHARE=channels_dvr) in that example.
  #1#channels-dvr:
    #1#external: true
  #2#channels-dvr-logs:
    #2#external: true
  #3#tubearchivist:
    #3#external: true
  #4#channels-dvr2:
    #4#external: true
  #5#channels-dvr2-logs:
    #5#external: true
  #6#tubearchivist2:
    #6#external: true
  #7#channels-dvr3:
    #7#external: true
  #8#channels-dvr3-logs:
    #8#external: true
  #9#tubearchivist3:
    #9#external: true
Environment Variables:
TAG=latest
DOMAIN=local
HOST_PORT=1337
CHANNELS_DVR_HOST=10.0.1.194
CHANNELS_CLIENTS=
ALERT_SMTP_SERVER=
ALERT_EMAIL_FROM=
ALERT_EMAIL_PASS=
ALERT_EMAIL_TO=
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
TZ=US/Central
HOST_DIR=/volume1/data
DVR_SHARE=/volume1/ChannelsDVR
LOGS_SHARE=/var/packages/ChannelsDVR/target/channels-dvr
TUBEARCHIVIST_SHARE=/volume1/ChannelsDVR
DVR2_SHARE=
LOGS2_SHARE=
DVR3_SHARE=
LOGS3_SHARE=
HOST_SFS_PORT=8080
FOLDER=/web
PORTAINER_TOKEN=redacted
PORTAINER_PORT=9443
PORTAINER_ENV=2
Looks good. A couple of 200 responses and the desired folders are visible. No response from Portainer on 9443 is not a show-stopper, given it's responding on 9000 via http. I'd say you're good-to-go. :slight_smile:
2 posts were split to a new topic: PSA: Recommended New Fork for Watchtower
I seems that members are getting this program to work. I currently have OliveTin running in Portainer and I can pull up the the admin panel but when I try to complete a One Click, like the the Tubi For Channels install I get:
JSON response from http://192.168.1.20:9000/api/stacks/create/standalone/string?endpointId=: {"message":"A valid authorization token is missing","details":"Unauthorized"}
false
This also happens with other One Clicks. I have a Synology NAS with Portainer under Docker installed, Olive Tin for Channels is present. My CDVR is not in the Portainer but installed as the a Synology package. I can post a health check if needed or the Env status, if needed. Any help with this is appreciated.
Project One-Click requires a valid Portainer Token to work. Since you're posting in the EZ-Start thread, I'm assuming you used that process to install the full version of OliveTin.
Go ahead and post the output from the OliveTin Post-Install Healthcheck, and we'll see where you are in the process.
OliveTin Container Version 2026.01.08
OliveTin Docker Compose Version 2025.08.25-ezstart
Checking that your selected Channels DVR server (192.168.1.20:8089) is reachable by URL:
100  1276  100  1276    0     0   623k      0 --:--:-- --:--:-- --:--:-- 1246k
HTTP Status: 200
Effective URL: http://192.168.1.20:8089/
Checking that your selected Channels DVR server's data files (/mnt/192.168.1.20-8089) are accessible:
Checking that your selected Channels DVR server's log files (/mnt/192.168.1.20-8089_logs) are accessible:
Portainer http response on port 9000 reports version 2.21.3
HOSTNAME=olivetin-ezstart
CHANNELS_DVR=192.168.1.20:8089
CHANNELS_CLIENTS=
ALERT_SMTP_SERVER=
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
PORTAINER_HOST=192.168.1.20
PORTAINER_PORT=9443
PORTAINER_ENV=2
options ndots:0
127.0.0.1	localhost
172.28.0.3	olivetin-ezstart
Standard Errorls: cannot access '/mnt/192.168.1.20-8089': No such file or directory
Error response from daemon: client version 1.52 is too new. Maximum supported API version is 1.41
ls: cannot access '/mnt/192.168.1.20-8089_logs': No such file or directory
jq: error (at <stdin>:0): Cannot index string with string "Name"
This tells us this healthcheck is from the EZ-Start container, not the full version of OliveTin which is found on port 1337 -- as described here (EZ-Start is on port 1338, and is only used to install the full version of OliveTin, Portainer, or both):
This is done. OliveTIn Channels Web Admin is up and running under 1337.
Could you post a healthcheck from the full version running on port 1337 -- so I can see where you are in the installation? It looked like you might be missing several other values...
OK I see a problem- The Healthcheck (on Actions page) is defaulting to EZStart). I do not see a Health check on the OliveTin WebPanel (One Click).
If needed, I can remove the containers and start over.
That would not be the case if your installation had proceeded in normal order. Could you post the current set of env vars being used by your olivetin stack (not olivetin-ezstart)? You can redact your e-mail related data, Tailnet domain and Portainer token (if one exists) but leave the rest.
Here's mine (captured from Portainer-Stacks - Environment variables - Advanced mode), for comparison:
TAG=latest
HOST_PORT=1337
CHANNELS_DVR_HOST=media-server8
CHANNELS_DVR2_HOST=utheater-pc
CHANNELS_DVR2_PORT=8089
CHANNELS_CLIENTS=appletv4k firestick-master
UPDATE_YAMLS=false
UPDATE_SCRIPTS=false
TZ=US/Mountain
HOST_DIR=/data
DVR_SHARE=/mnt/dvr
LOGS_SHARE=/mnt/channelsdvr
TUBEARCHIVIST_SHARE=/mnt/dvr
DVR2_SHARE=
LOGS2_SHARE=
DVR3_SHARE=
LOGS3_SHARE=
HOST_SFS_PORT=8081
FOLDER=/web
PORTAINER_HOST=htpc6
PORTAINER_PORT=9443
PORTAINER_ENV=2
Let's see if we can fix things as they sit, before resorting to reinstalling.
TAG=latest
DOMAIN=
HOST_PORT=1337
CHANNELS_DVR_HOST=192.168.1.20
CHANNELS_CLIENTS=
ALERT_SMTP_SERVER=
ALERT_EMAIL_FROM=
ALERT_EMAIL_PASS=
ALERT_EMAIL_TO=
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
TZ=
HOST_DIR=/data
DVR2_SHARE=
LOGS2_SHARE=
DVR3_SHARE=
LOGS3_SHARE=
HOST_SFS_PORT=8080
FOLDER=/web
PORTAINER_TOKEN=
PORTAINER_PORT=9443
PORTAINER_ENV=2
This is the primary problem. In Portainer, go to the username dropdown in the upper right corner and create a Portainer Token named olivetin. Save it in a safe place. Then stop your olivetin stack, and add that value to your env vars. Add your time zone (in standard Linux time zone format) after TZ= while you're at it.
Click the Update the stack button, and you should be good.
