PBS Feeds
Down again? Nothing working here.
026/02/26 22:49:53 INFO PBS/WGTVDT: Open url=https://urs-anonymous-detect.pbs.org/redirect/3c3253196e494e788505fa749716237d/
2026/02/26 22:49:54 INFO STRM: Manifest successfully parsed (Periods: 1, Streams in first period: 3, Type: live)
2026/02/26 22:49:54 ERRO STRM: SendSessionMessage: License update not successful (no keys)
2026/02/26 22:49:54 ERRO STRM: Initialize failed (SingleSampleDecrypter)
2026/02/26 22:49:54 ERRO STRM: Instances: 1
2026/02/26 22:49:54 INFO PBS/WGTVDT: Close
2026/02/26 22:49:54 ERRO SRV: Server error err="open failed"
Maybe add the container log to the issue?
I don't have a login but I'm sure somebody else does, based on past history she'll get it fixed pretty quick.
It's pretty easy to override the default PBS channel in prismcast to get your local working, I added the details as a comment to the prism thread.
Yep, I quit using the VLC Bridge container since I can get my Local one from PrismCast.
Looks like docker logs have been added to the issue.
I'm considering doing the same. A single channel may be the only Prismcast task my Synology can handle.
From what I can tell, @miibeez hasn't been active on GitLab for over 6 months. I hope that she's ok...
Oh, that's not good but that was the last time we had a problem so who knows.
So based on this post, is there a way to get the actual URLs that we could plug into prismcast to get multiple PBS channels via Chrome? Assuming that PBS feeds is dead of course.
I went to the station website, rightclicked on the video and selected 'Inspect', found the video link, opened in a new tab, and copied the link.
I'm having varying success with Prism in linux so I hope this technique is fixed soon.
Thanks I'm dumb, I already have videodownloadhelper extension installed on Chrome I could have used that lol.
I'll hold off for another week and see if Millie puts in a fix.
So far PBS in prism on Windows has been working pretty well.
From the error logs it looks like PBS has blocked the anonymous login port and enabled DRM across the board. Another casualty to the DRM we want your money machine.
Paging @miibeez
Any fixes?
DRM already was implemented, but the container was working... around... it. I believe it can be updated to deal with the recent changes, but without access to the source code to know how it was done, we're basically starting at square one unless the original developer decides to come back and modify.
I am looking into something, but no promises, especially any time soon.
I think this is dead now, sadly. We always knew that it was a single person supporting it and it looks like she's moved on. Maybe someday we'll get another implementation but right now my local PBS is working fine with prismcast.
I'll miss my other regional channels but it is what it is.
Well if someone can grab the code and see what changed.
Solved pbs on this end. DRM kills stuff all the time.
The code is compiled Go. I decompiled it as best I could (and I'd rather not get into how I did so), but it's still a hot mess and not exactly revealing in what it's doing without a lot of manual work; so much so that building from scratch would be faster. Apparently, it's still working with a Mac host machine, and theoretically might in certain Linux ones (haven't test this possibility yet), but it has to do with how Widevine looks for certain things on the backend.
Millie replied that Intel Processors break it, but ARM works. Says she is going to work on it. I will try moving Docker over to one of my Pi's and see what happens.
Great news. More that miibeez is ok and doing well. Look forward to the fix.
UPDATE: I upgraded Chrome on my Intel Mac mini to latest version and PBS is working now.
