Project One-Click: All-in-One Installations of Docker Extensions and CDVR Custom Channels
Thank you so much!
@bnhf Just a thought to consider.
I know your EZ Start was heading in this direction.
It would be so much easier for new users if there were a simplified two step setup for OT4C;
STEP 1 - Use a simplified docker compose with no environment variables just to get OT4C up & running.
  • Have an OT4C Settings page UI where users can add/change setting with good explanations of what each is for.
  • This Settings page could have links to online documentation.
  • Use a permanent/persistant Settings file to hold all settings, especially those not needed to create the container.
  • Once the user has made all the required settings in the Settings page UI, display a docker compose without environment variables to use in STEP 2.
STEP 2 - Create the finalized OT4C container using the compose statement displayed in STEP 1
  • This container will use the permanent/persistant Settings file instead of env vars.
  • This container will also have the same OT4C Settings page UI that accesses the permanent/persistant Settings file.
  • Keeping any settings not needed to create the container in the settings file will simplify things for the user.
I know you seem to like env vars in portainer stacks, but it's very confusing having to figure out from comments in the compose statements which env vars need to be set to what and which are required vs. optional and even samples can be confusing if a user is unfamiliar with host and domain names vs. IP addresses.
When I use Portainer stacks I like to include everything in the compose statement and eliminate environment variables not absolutely necessary.
Not even sure if this is possible, but if so I'm sure it would eliminate a lot of troubleshooting in setting up OT4C.
And if STEP 1 isn't possible in OT4C, perhaps it could just be a web page.
After all, whether the compose statement or environment variables are changed in a stack, it has to be redeployed.
The only environment variable I could imagine being needed is the host volume mapping for /config, storage of the persistant settings/config file
But a user could just modify the compose statement instead.
Or perhaps it could be a named docker volume (which I've never used, so not sure).
services:
  olivetin-bootstrap:
    # 2026.07.02
    # GitHub home for this project: https://github.com/bnhf/OliveTin
    # Docker container home for this project with setup instructions: https://hub.docker.com/r/bnhf/olivetin
    container_name: olivetin-bootstrap
    hostname: olivetin-bootstrap
    image: bnhf/olivetin:bootstrap
    ports:
      - 1337:1337
    environment:
      - OLIVETIN_COMPOSE=2026.07.02 # Do not change this value.
      - UPDATE_SCRIPTS=true # Set this to true to update all included scripts.
      - UPDATE_YAMLS=true # Set this to true to update config.yaml.
    volumes:
      - ${OLIVETIN_HOST_DIR}:/config # Change ${OLIVETIN_HOST_DIR} to the directory on your Docker host used to store OLIVETIN config and settings files, like /volume1/docker/olivetin If running on Synology docker, this directory must first be created by the user.
      - /var/run/docker.sock:/var/run/docker.sock
    restart: unless-stopped
environment variables:
OLIVETIN_HOST_DIR=/volume1/docker/olivetin
Actually OliveTin EZ-Start is fully up-and-available. It uses the same standard OliveTin Compose, and only requires two env vars:
EZ_START=-ezstart
CHANNELS_DVR_HOST=ip.address.of.your.cdvr.server
Then there's an OliveTin Action to help build a list of the variables required. More details here:
I've even taken it to the point where it'll install Portainer as well, with an OliveTin spin-up from the command line:
Just as an aside the person I was helping today in this thread is actually not a new user, but someone that had a functioning OliveTin/Project One-Click installation earlier this year. That installation became corrupted in a way I'm still trying to get to the bottom of, mostly having to do with some missteps in using Portainer I believe. We're working through it.
Ahh, OK :smile:
It may just be me. I just like the env vars filled out in the compose statement instead of having to look them up in a separate section of a stack. To each his own.
That works for simple composes, but for more advanced stacks there's a pretty significant advantage to being able to update the compose, and know the env vars won't disappear with the old compose.
In addition, everything in Project One-Click would be much more cumbersome to deal with -- if I was trying to embed user data in each compose. By separating compose from user data, there's a clean line between what's static and what's dynamic.
When you put your values directly in a compose it's much the same as hard coding values in scripts or programs. It's no big deal when you're doing it just for yourself, and it makes things easy to read without variables, but it's not a good practice for wider use.
I understand what you're saying.
Like I said, to each his own.
You have to support OT4C, I just have to thank you for it and use it :smile:
Yah, but I add more comments so I can understand what I hard coded in the compose :smile:
Would you consider moving (or copying) the environment variables comments/documentation from the compose statement to the environment variables section to make it easier since that's what we're editing?
That way we don't have to look at the compose (which you don't want us to edit) to get the definition of an environment variable that we need to change in the environment variable section of the stack.
example - My Fubo container stack environment variables
FUBO_PASS=Monkey123!                   # My Fubo account password
[email protected] # My Fubo account username (usually my email address)
HOST_PORT=7777                         # this Fubo containers host port number
TZ=America/Los_Angeles                 # My local timezone in standard linux format
This could be a good compromise. I've tested this on a limited basis in the past, but I'll dig into it a bit more and make sure there aren't any gotchas.
@jtrippe77 When you have time, I think the best option at this point is for you to use the OliveTin EZ-Start process to rebuild. This should give us a better idea of whether there's underlying issue with your Portainer installation.
Please follow the steps outlined here:
I copied everything exactly as instructed in the link you provided (IP address of my server w/o 8089) and get the following error:
> failed to deploy a stack: time="2025-07-03T17:15:58Z" level=warning msg="The \"CHANNELS_DVR2_HOST\" variable is not set. Defaulting to a blank string." time="2025-07-03T17:15:58Z" level=warning msg="The \"CHANNELS_DVR2_PORT\" variable is not set. Defaulting to a blank string." time="2025-07-03T17:15:58Z" level=warning msg="The \"CHANNELS_DVR3_HOST\" variable is not set. Defaulting to a blank string." time="2025-07-03T17:15:58Z" level=warning msg="The \"CHANNELS_DVR3_PORT\" variable is not set. Defaulting to a blank string." time="2025-07-03T17:15:58Z" level=warning msg="The \"CHANNELS_CLIENTS\" variable is not set. Defaulting to a blank string." time="2025-07-03T17:15:58Z" level=warning msg="The \"ALERT_SMTP_SERVER\" variable is not set. Defaulting to a blank string." time="2025-07-03T17:15:58Z" level=warning msg="The \"ALERT_EMAIL_FROM\" variable is not set. Defaulting to a blank string." time="2025-07-03T17:15:58Z" level=warning msg="The
Maybe there is an issue with my Portainer. I see "Deploy the Stack" but not "Update Stack" like the directions.
Deploy the stack is correct for a new stack -- I'll fix that. More importantly, could you try to capture the entire error message. What you posted is cutoff at warnings, which we're not concerned with.
Below is all I can see to copy:
failed to deploy a stack: time="2025-07-03T17:34:24Z" level=warning msg="The \"DOMAIN\" variable is not set. Defaulting to a blank string." time="2025-07-03T17:34:24Z" level=warning msg="The \"CHANNELS_DVR2_HOST\" variable is not set. Defaulting to a blank string." time="2025-07-03T17:34:24Z" level=warning msg="The \"CHANNELS_DVR2_PORT\" variable is not set. Defaulting to a blank string." time="2025-07-03T17:34:24Z" level=warning msg="The \"CHANNELS_DVR3_HOST\" variable is not set. Defaulting to a blank string." time="2025-07-03T17:34:24Z" level=warning msg="The \"CHANNELS_DVR3_PORT\" variable is not set. Defaulting to a blank string." time="2025-07-03T17:34:24Z" level=warning msg="The \"CHANNELS_CLIENTS\" variable is not set. Defaulting to a blank string." time="2025-07-03T17:34:24Z" level=warning msg="The \"ALERT_SMTP_SERVER\" variable is not set. Defaulting to a blank string." time="2025-07-03T17:34:24Z" level=warning msg="The \"ALERT_EMAIL_FROM\" variable is not set. Defaulting to a blank string." time="2025-07-03T17:34:24Z" level=warning msg="The \"ALERT_EMAIL_PASS\" variable is not set. Defaulting to a blank string." time="2025-07-03T17:34:24Z" level=warn
I cannot see anything else, scroll or drag down.
Edit:  found another way to copy the error:
Deployment error failed to deploy a stack: time="2025-07-03T17:48:38Z" level=warning msg="The "DOMAIN" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "DOMAIN" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "CHANNELS_DVR2_HOST" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "CHANNELS_DVR2_PORT" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "CHANNELS_DVR3_HOST" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "CHANNELS_DVR3_PORT" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "CHANNELS_CLIENTS" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "ALERT_SMTP_SERVER" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "ALERT_EMAIL_FROM" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "ALERT_EMAIL_PASS" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "ALERT_EMAIL_TO" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "TZ" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "PORTAINER_TOKEN" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "CHANNELS_DVR_PORT" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "CHANNELS_DVR_PORT" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "CHANNELS_DVR_PORT" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "CHANNELS_DVR2_HOST" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "CHANNELS_DVR2_PORT" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "CHANNELS_DVR2_PORT" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "CHANNELS_DVR2_PORT" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "CHANNELS_DVR3_HOST" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "CHANNELS_DVR3_PORT" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "CHANNELS_DVR3_PORT" variable is not set. Defaulting to a blank string." time="2025-07-03T17:48:38Z" level=warning msg="The "CHANNELS_DVR3_PORT" variable is not set. Defaulting to a blank string." services.olivetin.volumes array items[0,1] must be unique```
Basically the same error as before, just with different numbers between the square brackets. I think something is up with your Portainer installation -- as this is an error I've never seen before. I'll do a bit more research and get back to you.
In the meantime, you might see about updating Portainer, as 2.27.9 is the current version.
I just followed the instructions exactly on updating Portainer, and now I cannot use it. I'm about at the end of the rope with Portainer. I may just stick with the containers I currently have but now I cannot update them.
I understand your frustration, but among the issues that come up on this forum, functional problems with Portainer are very rare. It's a solid piece of software, and once you get things on track, I think you'll find it a pleasure to use.
Obviously up to you though...
I would like to keep moving, but the update just removed Portainer from my Docker completely. Then, I tried the olivetin and portainer install instructions on terminal and get zsh: command not found. It must be a user error but I'm copying everything exactly and entering the correct IP address
OK, some success. I've got portainer back by following the steps on the EZ start plus add portainer setting but then get stuck at Create an Olivetin stack in Portainer and get the following error:
JSON response from http://192.168.150.242:9000/api/stacks/create/standalone/string?endpointId=:{"message":"Invalid JWT token","details":"Unauthorized"}false
I now have an olivetin container in Docker but it won't startup and I see the EZstart container in Portainer
I'm not using that container, but I'm sure it will work.
Easy enough to inspect a container and see if the environment variables are correct.
I was thinking more about the environment variables for OT4C, since there are so many of them.
compose
services:
  olivetin: # This docker-compose typically requires no editing. Use the Environment variables section of Portainer to set your values.
    container_name: ${OLIVETIN_NAME:-olivetin}
    dns_search: ${DOMAIN:+${DOMAIN}} # For Tailscale users using Magic DNS, add your Tailnet (tailxxxxx.ts.net) to use hostnames for remote nodes, otherwise use your local domain name.
    hostname: ${OLIVETIN_NAME:-olivetin}
    image: bnhf/olivetin:${TAG:-latest} # Add the tag like latest or test to the environment variables below.
    ports:
      - ${HOST_PORT:-1337}:1337
    environment:
      - ALERT_EMAIL_FROM=${ALERT_EMAIL_FROM} # Sender address for alert e-mails.
      - ALERT_EMAIL_PASS=${ALERT_EMAIL_PASS} # SMTP "app" password established through GMail or Yahoo Mail. Do not use your everyday e-mail address.
      - ALERT_EMAIL_TO=${ALERT_EMAIL_TO} # Recipient address for alert e-mails.
      - ALERT_SMTP_SERVER=${ALERT_SMTP_SERVER} # SMTP server to use for sending alert e-mails. smtp.gmail.com:587 for example.
      - CHANNELS_CLIENTS=${CHANNELS_CLIENTS} # Space separated list of Channels DVR clients you'd like notifications sent to in the form hostname or IP.
      - CHANNELS_DVR=${CHANNELS_DVR1_HOST}:${CHANNELS_DVR1_PORT} # Add your Channels DVR server in the form CHANNELS_DVR_HOST=<hostname or ip> and CHANNELS_DVR_PORT=<port>.
      - CHANNELS_DVR_ALTERNATES=${CHANNELS_DVR_ALTERNATES} # Space separated list of alternate Channels DVR servers to choose from in the form hostname:port or ip:port.
      - OLIVETIN_COMPOSE=2025.03.26 # Do not change this value.
      - PERSISTENT_LOGS=${PERSISTENT_LOGS} # Set this to true to keep log contents between restarts.
      - PORTAINER_ENV=${PORTAINER_ENV:-2} # Set this is if you're using an alternate Portainer Environment for some reason. 2 is the default.
      - PORTAINER_HOST=${PORTAINER_HOST:-$CHANNELS_DVR1_HOST} # Hostname or IP of the Docker host you're running Portainer on.
      - PORTAINER_PORT=${PORTAINER_PORT:-9443} # https port you're running Portainer on. 9443 is the default.
      - PORTAINER_TOKEN=${PORTAINER_TOKEN} # Generate via <username> dropdown (upper right of WebUI), "My account", API tokens.
      - TZ=${TZ} # Add your local timezone in standard linux format. E.G. US/Eastern, US/Central, US/Mountain, US/Pacific, etc.
      - UPDATE_SCRIPTS=${UPDATE_SCRIPTS:-true} # Set this to true to update all included scripts.
      - UPDATE_YAMLS=${UPDATE_YAMLS:-true} # Set this to true to update config.yaml.
    volumes:
      - ${DVR1_SHARE}:/mnt/${CHANNELS_DVR1_HOST}-${CHANNELS_DVR1_PORT}
      - ${DVR2_SHARE}:/mnt/${CHANNELS_DVR2_HOST}-${CHANNELS_DVR2_PORT}
      - ${DVR3_SHARE}:/mnt/${CHANNELS_DVR3_HOST}-${CHANNELS_DVR3_PORT}
      - ${DVR4_SHARE}:/mnt/${CHANNELS_DVR4_HOST}-${CHANNELS_DVR4_PORT}
      - ${DVR5_SHARE}:/mnt/${CHANNELS_DVR5_HOST}-${CHANNELS_DVR5_PORT}
      - ${DVR6_SHARE}:/mnt/${CHANNELS_DVR6_HOST}-${CHANNELS_DVR6_PORT}
      - ${DVR7_SHARE}:/mnt/${CHANNELS_DVR7_HOST}-${CHANNELS_DVR7_PORT}
      - ${HOST_DIR}/olivetin:/config                                                 # Add the parent directory on your Docker you'd like to use.
      - ${LOGS1_SHARE}:/mnt/${CHANNELS_DVR1_HOST}-${CHANNELS_DVR1_PORT}_logs
      - ${LOGS2_SHARE}:/mnt/${CHANNELS_DVR2_HOST}-${CHANNELS_DVR2_PORT}_logs
      - ${LOGS3_SHARE}:/mnt/${CHANNELS_DVR3_HOST}-${CHANNELS_DVR3_PORT}_logs
      - ${LOGS4_SHARE}:/mnt/${CHANNELS_DVR4_HOST}-${CHANNELS_DVR4_PORT}_logs
      - ${LOGS5_SHARE}:/mnt/${CHANNELS_DVR5_HOST}-${CHANNELS_DVR5_PORT}_logs
      - ${LOGS6_SHARE}:/mnt/${CHANNELS_DVR6_HOST}-${CHANNELS_DVR6_PORT}_logs
      - ${LOGS7_SHARE}:/mnt/${CHANNELS_DVR7_HOST}-${CHANNELS_DVR7_PORT}_logs
      #- ${TUBEARCHIVIST1_SHARE}:/mnt/${CHANNELS_DVR1_HOST}-${CHANNELS_DVR1_PORT}_ta
      #- ${TUBEARCHIVIST2_SHARE}:/mnt/${CHANNELS_DVR2_HOST}-${CHANNELS_DVR2_PORT}_ta
  static-file-server:
    container_name: static-file-server
    dns_search: ${DOMAIN}
    image: halverneus/static-file-server:latest
    ports:
      - ${HOST_SFS_PORT}:8080
    environment:
      - DEBUG=false
      - FOLDER=${FOLDER}
    volumes:
      - ${HOST_DIR}/olivetin/data:${FOLDER}
[email protected]
ALERT_EMAIL_PASS=Monkey123!
[email protected]
ALERT_SMTP_SERVER=smtp.provider.tld:587
CHANNELS_CLIENTS=
CHANNELS_DVR1_HOST=192.168.1.4
CHANNELS_DVR1_PORT=8489
CHANNELS_DVR2_HOST=192.168.1.4
CHANNELS_DVR2_PORT=8089
CHANNELS_DVR3_HOST=192.168.1.4
CHANNELS_DVR3_PORT=8189
CHANNELS_DVR4_HOST=192.168.1.4
CHANNELS_DVR4_PORT=8190
CHANNELS_DVR5_HOST=192.168.1.4
CHANNELS_DVR5_PORT=8289
CHANNELS_DVR6_HOST=192.168.1.4
CHANNELS_DVR6_PORT=8389
CHANNELS_DVR7_HOST=192.168.1.4
CHANNELS_DVR7_PORT=8090
CHANNELS_DVR_ALTERNATES=192.168.1.4:8089 192.168.1.4:8189 192.168.1.4:8190 192.168.1.4:8289 192.168.1.4:8389 192.168.1.4:8090
DOMAIN=local
DVR1_SHARE=/volume1/ChDVR8489
DVR2_SHARE=/volume1/ChDVR8089
DVR3_SHARE=/volume1/ChDVR8189
DVR4_SHARE=/volume1/ChDVR8190
DVR5_SHARE=/volume1/ChDVR8289
DVR6_SHARE=/volume1/ChDVR8389
DVR7_SHARE=/volume1/ChDVR8090
FOLDER=/web
HOST_PORT=1337
HOST_SFS_PORT=8088
LOGS1_SHARE=/volume1/docker/channels-dvr-8489
LOGS2_SHARE=/volume1/docker/channels-dvr-8089
LOGS3_SHARE=/volume1/docker/channels-dvr-8189
LOGS4_SHARE=/volume1/docker/channels-dvr-8190
LOGS5_SHARE=/volume1/docker/channels-dvr-8289
LOGS6_SHARE=/volume1/docker/channels-dvr-8389
LOGS7_SHARE=/volume1/docker/channels-dvr-8090
PERSISTENT_LOGS=true
PORTAINER_ENV=2
PORTAINER_HOST=192.168.1.4
PORTAINER_PORT=9443
TAG=latest
TUBEARCHIVIST1_SHARE=
TUBEARCHIVIST2_SHARE=
UPDATE_SCRIPTS=true
UPDATE_YAMLS=true
I've got portainer and olivetin back up through EZstart. However, I get this error when trying to add multiview:
> {"message":"A valid authorization token is missing","details":"Unauthorized"}
> false
In the interest of making sure no issues have crept into the OliveTin EZ-Start process on a Mac -- I stepped through it this morning -- and everything worked as expected.
I also had Portainer and OliveTin previously installed on this system, and here are the steps I followed -- so you can compare them to what you did.
In Portainer, I stopped the OliveTin stack, followed by removing the OliveTin Stack.
Next, for good measure, I deleted the OliveTin image in Portainer.
And, from the Mac Terminal, I stopped Portainer and then removed Portainer:
slayer@mac-mini-m2 ~ % docker stop portainer
portainer
slayer@mac-mini-m2 ~ % docker rm portainer
portainer
Finally, I deleted the Portainer data volume:
slayer@mac-mini-m2 ~ % docker volume rm portainer_data
portainer_data
From there, I followed the steps as detailed here, making sure to check for successful execution of each. When configuring the OliveTin env vars, I used the defaults, with these exceptions specific to the Mac:
HOST_DIR=/Users/slayer/data
DVR_SHARE=/Users/slayer/channels-data
LOGS_SHARE=/Users/slayer/Library/Application Support/ChannelsDVR
With Portainer and OliveTin reinstalled from scratch, I successfully added Pluto and Multichannel View to test Project One-Click.
I'm not seeing anything wrong with the processes, either EZ-Start or Project One-Click.
