Did a quick scan in my channel lineup for Fubo on Channels, don't see it (what channel number is it assigned to in case I missed it)? I also went to the website, but I don't see an option to login to watch live stream, so unable to confirm that way either.
If it's on Fubo you will find it by using the search box on this page
Don't see MotoGP there yet.
Not surprising since that FAST channel just launched yesterday.
I'm not seeing the NFL Network channel
I don't think you can get that via TVE anymore (could be wrong on that). I still have access to NFL Network using Fubo Project and EPlusTV to import in Channels as well as using Fubo's native application.
TVE/Fubo still works, but it is a smaller subset of channels than it used to be, and is a different set than VCL Bridge. You need both to get the most channels.
Don't forget, Fubo is adding DRM to channels on the Fubo project. I have found having the ADB Tuner connected with my ONN 4k boxes helps in getting the drm encryped channels back.
Yup, my response was specific to NFL Network as that was asked, but didn't spell out in my response. 100% agree with your clarification on the broader impact of the various solutions to get content into Channels.
Can anyone with Fubo confirm if they get History channel TVE? Thanks
No from Fubo, Yes from Philo.
As of today, ABC, Freeform and all of the ESPN channels are not working for me with my Fubo subscription and TVE integration for Channels DVR. The logs say "notAuthorized: No TV subscription found for user"
I do not believe that this is a Channels DVR issue, but a wider issue with Fubo/ABC and Fubo/ESPN TVE integration. The ABC website and ESPN website no longer work with the credentials nor does the EPlusTV container.
Hopefully it will get resolved in the near future.
I figured I would post here for visibility in case others are having this issue as well.
Seeing the same problem. I can tune via Fubo App and Website, just not via TVE right now.
Thanks for confirming you are having the issue too and it is not just me. Fubo knows about the issue and is looking into it. Hopefully it is something on their end otherwise it might take longer if it is on the network side.
I tune into NBC
perhaps via other sources though, not through TVE.
NBC, and its regional sports networks, are no longer available in Channels via TV Everywhere providers. NBC is still, and will continue to be, available via over the air antennas. NBC has adjusted their streaming technology to a format that is incompatible with Channels. This is not something that we can adapt to, and ends compatibility with Channels. My NBC channel is still working Your NBC affiliate has not migrated yet but it will within time. So while it works right now, it assuredly will…
Sorry responded from old account, Yeah during games or sports events it says DRM in docker logs, but during normal events, works like a charm, for now like you said
Wow, that's news to me. I thought NBC and it's networks were all gone from TVE across the board regardless of content. Cool! Enjoy while it lasts
Fortunately I setup ADBTuner as a backup many months ago. Occasionally have hiccups with that, but should serve as an adequate backup until this get resolved.
Still out as of 16:57 Eastern US time.
Same here. Nothing we can do but wait for Fubo and/or ABC/ESPN to fix the issue or put in a ticket with their support.
