Lots of people here have been emailing AE to ask them to add live streams for several months. They said it was coming soon. First they added it to their Roku app. Then they added it to their website, and someone found the new links. Once it was on their website we added it to our DVR.
I found a app that logs connections of apps. there is 4 ip address and what it resolves to listed, after logging in with Philo creds and launching live tv stream.
not sure if this is usefull at all. or if there is some other app that can detect far more connections that this random one i found in the Play store.
I know it is possible to raw capture VOD and live tv stream from the DF go app, as, while back, couple years ago now, someone was doing that to make rips of certain shows and shorts off of there, using ffmpeg on PC. i was shown that u have to break the HTTPS connection at some point, the app then spits a error with the full video stream urls and DRM key?..and put that into ffmpeg and it can pull the data. I even was successful doing it myself once. However, i did not keep that info
Hi all,
Jumping back into Channels now that I have a newer, faster Synology NAS...
I have everything installed correctly except for integrating Philo/TVe into the mix.
I add it as a source, enter in mu email to et the link for verification but get a "Context Cancelled" message. What do I do to fix that?
Thanks in advance. I am sure it's something dumb I forgot to do in setup somewhere but any help would be appreciated
(P.S. If I added this in the wrong forum, my apologies -- again, a re-newbie of sorts here...
That worked perfectly
Thank you!
I've seen posted in here a few places that Nickelodeon doesn't do TVE, but the Streamable site says otherwise - https://thestreamable.com/tv-everywhere-apps/nick-app Anyone had luck getting this to work in Channels DVR from any streaming service? I have Philo, so posting here.
Nick only has on-demand, no live stream.
NickJR is the only one with a TVE stream.
I have been unable to get Philo to work as a TVE source. I have successfully added Sling as a TV source, but Philo fails with a authn: Error 401. Not authorized message. I found Philo as a source in the Add TV Anywhere dialog box and submitted it. It requested my email address and I submitted that. I checked my mail account and clicked the link to approve the request. I was then advised that it was authorizing the account and it eventually failed with the above message. Here is the log of the attempt:
2020/07/12 04:18:56.716464 [TVE] Auth starting for Philo as [redacted]
2020/07/12 04:18:56.716464 [TVE] action=auth mvpd=Philo requestor=AMC
2020/07/12 04:18:57.152678 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=Philo&requestor_id=AMC&no_iframe=true&domain_name=adobe.com&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2020/07/12 04:18:57.153678 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/authenticate/saml
2020/07/12 04:19:59.724203 [TVE] action=request type=Document method=GET url=https://idp.philo.com/idp/sso
2020/07/12 04:19:59.724203 [TVE] action=auth_domain domain=idp.philo.com
2020/07/12 04:21:20.036251 [TVE] action=request type=Document method=GET url=https://idp.philo.com/idp/submit
2020/07/12 04:21:20.107333 [TVE] action=wait_for_page
2020/07/12 04:21:30.376953 [TVE] action=request type=Document method=POST url=https://sp.auth.adobe.com/sp/saml/SAMLAssertionConsumer
2020/07/12 04:21:50.109203 [TVE] action=wait_for_page err=timeout
2020/07/12 04:21:50.109203 [TVE] action=fill_form u=[redacted]
2020/07/12 04:22:30.527936 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/completePassiveAuthentication
2020/07/12 04:22:30.527936 [TVE] action=authed
2020/07/12 04:22:30.589185 [TVE] action=cookies num_domains=2 num_cookies=9
2020/07/12 04:22:30.806767 [TVE] Auth failed for Philo: authn: 401 Unauthorized: Data not found
(I have redacted my email address).
I should add that the Fire TV Philo app DOES work and Philo also shows up as a source in FireTV's "Live" tab.
Apparently the problem was using Brave with no scripts allowed on a different machine than the one Channels DVR server was installed. The clue was the test you suggested. It was coming up with a black screen when I first tried it.
It's working now. Thanks.
Hello everyone,
I am new to Channels and I have read just about every post on this board (several times) regarding Philo and getting their stations to work with the Channels DVR.
I do have several channels/networks working, so itās not the āwholeā Philo service thatās not working. (I have the exact issue with Sling too! Iāve removed them both and added only one or the other back with the same result.)
The āissueā is that there are several channels that we regularly watch that are not available as this is currently setup. A few of them are HGTV, Discovery, TBS, TCM, DIY, Hallmark, HallmarkMM, Food, and others that Iām not so concerned with. As Iāve read through the posts discussing channels that will work with Channels DVR, I believe most of these are included as āworkingā?
Here is what Iāve done so far:
- Rebooted server/ computer
- Upgraded Channel DVR app to latest version (2020.10.16.1640)
- Deleted and added Philo app (and Sling) several times (logged in/verified with code each time)
- Used the āEdit button to check networks available, and rescanned the individual missing channels
- Again, read all the Philo posts several times
The message I have next to the missing channels is ānotAuthorizedā
Can anyone help me with this? I donāt know what else to doā¦ā¦ Iām at my wits end and ready to drop the Channels app if I canāt get this fixed (which I do NOT want to do!
) Iām trying to cut the Spectrum cord at the beginning of November, so trying to get this working.
Thank you!! I appreciate any assistance that you can provide!!!
TBS,TCM, FOOD or any Warner media channel TVE is not supported by Sling or any other live Streaming service.
I started testing moving Channels DVR from Qnap to windows, I setup Philo and it scanned 99 channels (two more then my QNAP and one extra local channel). So I hit rescan on my QNAP install of DVR and now it has 66 channels. The channels I'm supposed to have either say Login not Authorized, or Login not supported.
Now neither install of Channels DVR has all the channels (one has 62 and the other 60) and all the semi-premium channels are locked out. Is this a IP blocking issue from Philo or the TVE provider? How can I reset what I did and get one, working, Channels DVR with 90+ channels.
I've deleted and readded philo as a provider, rebooted, etc.. I'm missing recordings until I get it fixed. Please help @tmm1
Which channels aren't you getting
20/10/23 12:13:46.868836 [TVE] Channel scan 1/209 CSPAN failed: login not supported
2020/10/23 12:13:46.918965 [TVE] Channel scan 2/209 CSPAN2 failed: login not supported
2020/10/23 12:13:46.977859 [TVE] Channel scan 3/209 CSPAN3 failed: login not supported
2020/10/23 12:13:47.252112 [TVE] Channel scan 4/209 CC failed: notAuthorized: Your Philo plan does not include access to this. For assistance visit help.philo.com
2020/10/23 12:13:47.545882 [TVE] Channel scan 5/209 CCP failed: notAuthorized: Your Philo plan does not include access to this. For assistance visit help.philo.com
2020/10/23 12:13:47.761976 [TVE] Channel scan 6/209 MTV failed: notAuthorized: Your Philo plan does not include access to this. For assistance visit help.philo.com
2020/10/23 12:13:47.972660 [TVE] Channel scan 7/209 MTVP failed: notAuthorized: Your Philo plan does not include access to this. For assistance visit help.philo.com
2020/10/23 12:13:48.203418 [TVE] Channel scan 8/209 VH1 failed: notAuthorized: Your Philo plan does not include access to this. For assistance visit help.philo.com
2020/10/23 12:13:48.384021 [TVE] Channel scan 9/209 VH1P failed: notAuthorized: Your Philo plan does not include access to this. For assistance visit help.philo.com
2020/10/23 12:13:48.639845 [TVE] Channel scan 10/209 CMT failed: notAuthorized: Your Philo plan does not include access to this. For assistance visit help.philo.com
2020/10/23 12:13:48.735255 [TVE] Channel scan 11/209 CMTP failed: notAuthorized: Your Philo plan does not include access to this. For assistance visit help.philo.com
2020/10/23 12:13:49.006151 [TVE] Channel scan 12/209 BET failed: notAuthorized: Your Philo plan does not include access to this. For assistance visit help.philo.com
2020/10/23 12:13:49.257014 [TVE] Channel scan 13/209 BETP failed: notAuthorized: Your Philo plan does not include access to this. For assistance visit help.philo.com
2020/10/23 12:13:49.337275 [TVE] Channel scan 14/209 TVLAND failed: notAuthorized
2020/10/23 12:13:49.482517 [TVE] Channel scan 15/209 TVLANDP failed: notAuthorized
2020/10/23 12:13:49.568022 [TVE] Channel scan 16/209 PARAMOUNT failed: notAuthorized
2020/10/23 12:13:49.632983 [TVE] Channel scan 17/209 PARAMOUNTP failed: notAuthorized
2020/10/23 12:13:49.733571 [TVE] Channel scan 18/209 LOGO failed: notAuthorized
2020/10/23 12:13:49.793589 [TVE] Channel scan 19/209 LOGOP failed: notAuthorized
2020/10/23 12:13:49.879130 [TVE] Channel scan 20/209 NICKJR failed: notAuthorized
2020/10/23 12:13:49.934105 [TVE] Channel scan 21/209 NICKJRP failed: notAuthorized
2020/10/23 12:13:49.969418 [TVE] Channel scan 22/209 CNN failed: login not supported
2020/10/23 12:13:49.994237 [TVE] Channel scan 23/209 HLN failed: login not supported
2020/10/23 12:13:50.039661 [TVE] Channel scan 24/209 CNNI failed: login not supported
2020/10/23 12:13:50.064457 [TVE] Channel scan 25/209 TBS failed: login not supported
2020/10/23 12:13:50.114492 [TVE] Channel scan 26/209 TBSP failed: login not supported
2020/10/23 12:13:50.185093 [TVE] Channel scan 27/209 TNT failed: login not supported
2020/10/23 12:13:50.230348 [TVE] Channel scan 28/209 TNTP failed: login not supported
2020/10/23 12:13:50.255153 [TVE] Channel scan 29/209 TRU failed: login not supported
2020/10/23 12:13:50.300606 [TVE] Channel scan 30/209 TRUP failed: login not supported
2020/10/23 12:13:50.325560 [TVE] Channel scan 31/209 TCM failed: login not supported
2020/10/23 12:13:50.370817 [TVE] Channel scan 32/209 TOON failed: login not supported
2020/10/23 12:13:50.395627 [TVE] Channel scan 33/209 TOONP failed: login not supported
2020/10/23 12:13:50.481169 [TVE] Channel scan 34/209 AETV failed: notAuthorized
2020/10/23 12:13:50.536118 [TVE] Channel scan 35/209 HISTORY failed: notAuthorized
2020/10/23 12:13:50.616361 [TVE] Channel scan 36/209 FYI failed: notAuthorized
2020/10/23 12:13:50.676572 [TVE] Channel scan 37/209 LIFETIME failed: notAuthorized
2020/10/23 12:13:50.716660 [TVE] Channel scan 38/209 MSNBC failed: login not supported
2020/10/23 12:13:50.837183 [TVE] Channel scan 39/209 CNBC failed: login not supported
2020/10/23 12:13:50.877257 [TVE] Channel scan 40/209 USA failed: login not supported
2020/10/23 12:13:50.897368 [TVE] Channel scan 41/209 USAP failed: login not supported
2020/10/23 12:13:51.010509 [TVE] Channel scan 42/209 SYFY failed: login not supported
2020/10/23 12:13:51.083237 [TVE] Channel scan 43/209 SYFYP failed: login not supported
2020/10/23 12:13:51.128094 [TVE] Channel scan 44/209 E failed: login not supported
2020/10/23 12:13:51.148148 [TVE] Channel scan 45/209 EP failed: login not supported
2020/10/23 12:13:51.188365 [TVE] Channel scan 46/209 BRAVO failed: login not supported
2020/10/23 12:13:51.208401 [TVE] Channel scan 47/209 BRAVOP failed: login not supported
2020/10/23 12:13:51.276674 [TVE] Channel scan 48/209 OXYGEN failed: login not supported
2020/10/23 12:13:51.477867 [TVE] Channel scan 49/209 OXYGENP failed: login not supported
2020/10/23 12:13:51.544807 [TVE] Channel scan 50/209 SPROUT failed: login not supported
2020/10/23 12:13:51.569622 [TVE] Channel scan 51/209 SPROUTP failed: login not supported
2020/10/23 12:13:51.609731 [TVE] Channel scan 52/209 NGC failed: login not supported
2020/10/23 12:13:51.629807 [TVE] Channel scan 53/209 NGCP failed: login not supported
2020/10/23 12:13:51.669967 [TVE] Channel scan 54/209 NGWILD failed: login not supported
2020/10/23 12:13:51.690024 [TVE] Channel scan 55/209 FNC failed: login not supported
2020/10/23 12:13:51.730128 [TVE] Channel scan 56/209 FBN failed: login not supported
2020/10/23 12:13:51.805705 [TVE] Channel scan 57/209 FX failed: login not supported
2020/10/23 12:13:51.850569 [TVE] Channel scan 58/209 FXP failed: login not supported
2020/10/23 12:13:51.910860 [TVE] Channel scan 59/209 FXX failed: login not supported
2020/10/23 12:13:52.026662 [TVE] Channel scan 60/209 FXXP failed: login not supported
2020/10/23 12:13:52.076661 [TVE] Channel scan 61/209 FXM failed: login not supported
2020/10/23 12:13:52.161626 [TVE] Channel scan 62/209 SUNDANCE failed: notAuthorized
2020/10/23 12:13:52.237183 [TVE] Channel scan 63/209 AMC failed: notAuthorized
2020/10/23 12:13:52.317425 [TVE] Channel scan 64/209 BBCA failed: notAuthorized
2020/10/23 12:13:52.397746 [TVE] Channel scan 65/209 IFC failed: notAuthorized
2020/10/23 12:13:52.508349 [TVE] Channel scan 66/209 WETV failed: notAuthorized
2020/10/23 12:13:52.598429 [TVE] Channel scan 67/209 HALLMARK failed: notAuthorized
2020/10/23 12:13:52.673571 [TVE] Channel scan 68/209 HALLMARKMM failed: notAuthorized
2020/10/23 12:13:52.748962 [TVE] Channel scan 69/209 HALLMARKDRAMA failed: notAuthorized
2020/10/23 12:13:52.793796 [TVE] Channel scan 70/209 OVATION failed: login not supported
2020/10/23 12:13:52.829209 [TVE] Channel scan 71/209 WEATHER failed: login not supported
2020/10/23 12:13:52.874067 [TVE] Channel scan 72/209 REELZ failed: login not supported
2020/10/23 12:13:53.019939 [TVE] Channel scan 73/209 OWN failed: notAuthorized
2020/10/23 12:13:53.094819 [TVE] Channel scan 74/209 DISCOVERY failed: notAuthorized
2020/10/23 12:13:53.180394 [TVE] Channel scan 75/209 FOOD failed: notAuthorized
2020/10/23 12:13:53.255373 [TVE] Channel scan 76/209 ANIMAL-PLANET failed: notAuthorized
2020/10/23 12:13:53.371068 [TVE] Channel scan 77/209 HGTV failed: notAuthorized
2020/10/23 12:13:53.501513 [TVE] Channel scan 78/209 TLC failed: notAuthorized
2020/10/23 12:13:53.571754 [TVE] Channel scan 79/209 TRAVEL failed: notAuthorized
2020/10/23 12:13:53.636678 [TVE] Channel scan 80/209 INVESTIGATION-DISCOVERY failed: notAuthorized
2020/10/23 12:13:53.742329 [TVE] Channel scan 81/209 DIY failed: notAuthorized
2020/10/23 12:13:53.807274 [TVE] Channel scan 82/209 COOKING-CHANNEL failed: notAuthorized
2020/10/23 12:13:53.912919 [TVE] Channel scan 83/209 SCIENCE failed: notAuthorized
2020/10/23 12:13:53.997934 [TVE] Channel scan 84/209 AHC failed: notAuthorized
2020/10/23 12:13:54.073459 [TVE] Channel scan 85/209 DESTINATION-AMERICA failed: notAuthorized
2020/10/23 12:13:54.138389 [TVE] Channel scan 86/209 DISCOVERY-LIFE failed: notAuthorized
2020/10/23 12:13:54.314273 [TVE] Channel scan 87/209 MOTORTREND failed: notAuthorized
2020/10/23 12:13:54.349111 [TVE] Channel scan 88/209 DISNEY failed: login not supported
2020/10/23 12:13:54.384521 [TVE] Channel scan 89/209 DISNEYP failed: login not supported
2020/10/23 12:13:54.419352 [TVE] Channel scan 90/209 DISNEYJR failed: login not supported
2020/10/23 12:13:54.454860 [TVE] Channel scan 91/209 DISNEYJRP failed: login not supported
2020/10/23 12:13:54.504940 [TVE] Channel scan 92/209 DISNEYXD failed: login not supported
2020/10/23 12:13:54.545085 [TVE] Channel scan 93/209 DISNEYXDP failed: login not supported
2020/10/23 12:13:54.660288 [TVE] Channel scan 94/209 FREEFORM failed: login not supported
2020/10/23 12:13:54.740688 [TVE] Channel scan 95/209 FREEFORMP failed: login not supported
2020/10/23 12:13:54.770569 [TVE] Channel scan 96/209 ESPN1 failed: login not supported
2020/10/23 12:13:54.805972 [TVE] Channel scan 97/209 ESPN2 failed: login not supported
2020/10/23 12:13:54.840818 [TVE] Channel scan 98/209 ESPNU failed: login not supported
2020/10/23 12:13:54.876226 [TVE] Channel scan 99/209 ESPNEWS failed: login not supported
2020/10/23 12:13:54.911068 [TVE] Channel scan 100/209 SEC failed: login not supported
2020/10/23 12:13:54.976569 [TVE] Channel scan 101/209 LONGHORN failed: login not supported
2020/10/23 12:13:55.021449 [TVE] Channel scan 102/209 ESPNDEPORTES failed: login not supported
2020/10/23 12:13:55.086968 [TVE] Channel scan 103/209 ACC failed: login not supported
2020/10/23 12:13:55.131803 [TVE] Channel scan 104/209 MSG failed: login not supported
2020/10/23 12:13:55.167231 [TVE] Channel scan 105/209 MSGPLUS failed: login not supported
2020/10/23 12:13:55.212104 [TVE] Channel scan 106/209 TENNIS failed: login not supported
2020/10/23 12:13:55.247496 [TVE] Channel scan 107/209 MARQUEESPORTS failed: login not supported
2020/10/23 12:13:55.292350 [TVE] Channel scan 108/209 GOLF failed: login not supported
2020/10/23 12:13:55.327767 [TVE] Channel scan 109/209 OLYMPICS failed: login not supported
2020/10/23 12:13:55.558520 [TVE] Channel scan 110/209 NBCSN failed: login not supported
2020/10/23 12:13:55.598710 [TVE] Channel scan 111/209 SNY failed: login not supported
2020/10/23 12:13:55.643577 [TVE] Channel scan 112/209 NESN failed: login not supported
2020/10/23 12:13:55.678982 [TVE] Channel scan 113/209 NBCSN-CHICAGO failed: login not supported
2020/10/23 12:13:55.723853 [TVE] Channel scan 114/209 NBCSN-WASHINGTON failed: login not supported
2020/10/23 12:13:55.844797 [TVE] Channel scan 115/209 NBCSN-BOSTON failed: login not supported
2020/10/23 12:13:55.924549 [TVE] Channel scan 116/209 NBCSN-BAYAREA failed: login not supported
2020/10/23 12:13:55.959946 [TVE] Channel scan 117/209 NBCSN-CALIFORNIA failed: login not supported
2020/10/23 12:13:56.004780 [TVE] Channel scan 118/209 NBCSN-NORTHWEST failed: login not supported
2020/10/23 12:13:56.054994 [TVE] Channel scan 119/209 NBCSN-PHILLYPLUS failed: login not supported
2020/10/23 12:13:56.095096 [TVE] Channel scan 120/209 NBCSN-PHILLY failed: login not supported
2020/10/23 12:13:56.130513 [TVE] Channel scan 121/209 NESNPLUS failed: login not supported
2020/10/23 12:13:56.175391 [TVE] Channel scan 122/209 NFLREDZONE failed: login not supported
2020/10/23 12:13:56.210803 [TVE] Channel scan 123/209 P12NAT failed: login not supported
2020/10/23 12:13:56.255664 [TVE] Channel scan 124/209 P12MTN failed: login not supported
2020/10/23 12:13:56.384608 [TVE] Channel scan 125/209 P12ORG failed: login not supported
2020/10/23 12:13:56.426281 [TVE] Channel scan 126/209 P12LAX failed: login not supported
2020/10/23 12:13:56.461689 [TVE] Channel scan 127/209 P12WAS failed: login not supported
2020/10/23 12:13:56.506522 [TVE] Channel scan 128/209 P12ARZ failed: login not supported
2020/10/23 12:13:56.541952 [TVE] Channel scan 129/209 P12BAY failed: login not supported
2020/10/23 12:13:56.586808 [TVE] Channel scan 130/209 NFL failed: login not supported
2020/10/23 12:13:56.622220 [TVE] Channel scan 131/209 MLBTV failed: login not supported
You probably need to remove and readd Philo
