Recap regarding problems understanding and using anything other than the command line for managing and deploying Docker containers
For example, I use the docker command from the command line, Portainer, Tugtainer, and Dockage. Each has it's advantage.
Good in theory, but I had no end of trouble with Portainer, causing me to ditch it entirely. I can manage "docker run" because usually it's just a matter of copying and entering a command. Whenever I see instructions that use "compose," they are incomplete because they assume you pretty much know how to set it up and just need to know the particular variables to set. What I'd love to find is a list of steps, along with an indication of which parts of the commands are to be copied verbatim and which are for the user to populate with their selected options.
(I've seen a post about intro to Docker, and while I looked at it, I didn't find it useful as it left many terms undefined and assumed the reader was trying to develop and deploy interacting containers, vs. just trying to use what others have created).
Have you tried using AI?
Yes; it helped me recover from the problems Portainer created, but I decided, after that, that Portainer was more trouble than it was worth to me.
Command line gets old when you are managing a number of containers and each needs to be monitored for updates and updated. This is where Dockhand and Tugtainer shine as they check for updates and can notify and even selectively update automatically. Portainer is basically a point and click replacement for command line. What were you doing that caused issues?
I only have 2 containers (FastChannels and VLC Bridge PBS, so no real need for constant monitoring. FC tells me when it has an update, and I run an updating batch file (that someone here helped me with). the PBS bridge has much rarer updates, and I have notes on what to do with that.
I think I had initially tried to use Portainer to set up FastChannels, and had no end of trouble:
Initial setup:
Instructions said:
In Portainer, create a new stack and paste this:
Deploy the stack.
Ok, what in the world do those things mean? I had to ask around (I have some notes from AI questions, and that's where I might have gotten the answers, but although I found references to a discussion, I can't find it now, and so no longer remember how to create or deploy a stack - and what exactly is a stack anyway?)
Somehow I got those things done, though and things were working. But then I rebooted, and lost access to Portainer. It had asked me to set a password at setup, and I had dutifully one that and carefully noted what it was. Yet after the reboot when I tried to access it again, it wouldn't accept the password.
Searched around again for fixes, and they all involved installing yet another Docker container, or pages-on-pages of things to do.
I could still access FastChannels itself, but it needed an update. I had saved configuration backups, but at the time there was no easy to restore from those backups. That was much improved later, so no longer an issue. After more flailing with AI, I re -installed FastChannels from scratch, but could not find an easy way to restore from the backup, and it didn't see the saved data. I ended up with two copies of FC, one under Portainer, hiding the backup file somewhere in the bowels of Docker, and invisible to my file system.
Back to the AI and after some thrashing, got a command to send to retrieve the backup. It's buried in some of my notes somewhere. I ended up deleting Portainer and its copy of FastChannels, and decided never again to mess with Portainer when I have perfectly adequate command-line methods. Frankly, every time I need to do something new in Docker, I have to ask lots of questions and it seems to get much more complicated than I expect, sending me down multiple rabbit holes to get it sorted out. At least the AI is infinitely patient!
So that's my trip through hell via Portainer.
Ouch!
There are a lot of bad instructions out there and you probably are finding them. I don't recall what environment you are running docker in. That may be part of the issue as well. I've found the easiest way to set up docker containers is when the developer lists the command line steps and this assumes Linux docker implementation and is why I chose to run Ubuntu server as a Windows Hyper-V VM. Portainer was one of the first docker manager and it's dated. There are better and easier ones. I never had a strong enough desire to learn docker till FastChannels came along and the clear instructions provided to install via the command line is how I got it running. I don't know what AI you are using to find instructions, I find that Google searches AI sumary's provide wonderful step by step instructions. Watch a video that explains docker, there are a few of them. Once you understand the terms it will help. Also, I find that a lot of the developers provide sample yaml files yet don't define what the variables do making them very hard to understand. This is when it's time to ask what they are.
I prefer Googles Gemini A.I.. Always works out well with me and rarely makes mistakes, and when it does, I catch them quickly, tell it, and it punts and fixes it with the right answer.
"He" is just like having an expert sitting right next to you, giving you all the right answers!
