I have just installed a Nvidia Shield that is being used as a client. Installed the Channels DVR Client version 3.1.4. If I change to a Discovery Channel and watch for a few minutes, then go to a different Discovery Channel and watch. A third Discovery Channel results in a 403 number of streams exceeded message. Below is the log from the DVR Server.
2021/04/01 13:20:20.097734 [TVE] action=error_response type=Other error=net::ERR_UNKNOWN_URL_SCHEME
2021/04/01 13:20:20.110939 [TVE] action=version product=Chrome/76.0.3805.2 jsVersion=7.6.274 protocol=1.3 revision=@b96ff990aaa019fca0942aadc19c721d20cfa213
2021/04/01 13:20:20.110989 [TVE] action=set_cookies domains=1
2021/04/01 13:20:20.152155 [TVE] action=navigate url=https://login.discovery.com/v1/oauth2/authorize?affiliate_id=5c472fd06b66d134e101016a&asset_authz=true&auth_client_id=Spectrum&auth_client_url=&auth_ttl=&client_id=3020a40c2356a645b4b4&network_requestors=true&product.code=cook&redirect_uri=https%3A%2F%2Fwatch.cookingchanneltv.com%2Fwatch%2Fcooking-channel&response_flow=code&response_type=adobe&state=nonce%2CVC8GwFjMN5AOYbz3wE3LaU4nm80DVGKF
2021/04/01 13:20:20.154020 [TVE] action=request type=Document method=GET url=https://login.discovery.com/v1/oauth2/authorize
2021/04/01 13:20:20.626146 [TVE] action=request type=Document method=GET url=https://api.auth.adobe.com/api/v1/authenticate
2021/04/01 13:20:20.939293 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/api/v1/authenticate
2021/04/01 13:20:21.144587 [TVE] action=wait_for_page
2021/04/01 13:20:21.224744 [TVE] action=request type=Document method=POST url=https://tve.spectrum.net/openam/SSOPOST/metaAlias/charter/idp
2021/04/01 13:20:21.224795 [TVE] action=auth_domain domain=tve.spectrum.net
2021/04/01 13:20:27.092233 [TVE] action=page_ready
2021/04/01 13:20:27.092305 [TVE] action=wait_for_page done=true reason=page_ready
2021/04/01 13:20:27.092334 [TVE] action=fill_form u=rav3n8sp
2021/04/01 13:20:27.375424 [TVE] action=tvejs msg="spectrumContinue"
2021/04/01 13:20:27.395525 [TVE] action=wait_for_auth
2021/04/01 13:20:27.451014 [TVE] action=request type=Document method=POST url=https://sp.auth.adobe.com/sp/saml/SAMLAssertionConsumer
2021/04/01 13:20:27.639272 [TVE] action=request type=Document method=GET url=https://login.discovery.com/v1/oauth2/authorize/callback/adobe
2021/04/01 13:20:27.969735 [TVE] action=request type=Document method=GET url=https://watch.cookingchanneltv.com/watch/cooking-channel
2021/04/01 13:20:29.339382 [TVE] action=authed
2021/04/01 13:20:29.343510 [TVE] action=cookies num_domains=1 num_cookies=1
2021/04/01 13:20:31.155354 [TVE] stream timestamps: cooking-channel: start_at=2021-04-01T13:19:32-04:00 current_at=2021-04-01T13:19:52-04:00 end_at=2021-04-01T13:20:01-04:00
2021/04/01 13:20:31.155432 [TNR] Opened connection to TVE-Spectrum for ch6109 COOKING-CHANNEL [transcode=none]
2021/04/01 13:21:10.831829 [TNR] Error during live stream for ch6109 COOKING-CHANNEL: write tcp 192.168.101.211:8089->192.168.101.232:40864: write: broken pipe
2021/04/01 13:21:10.839266 [TNR] Closed connection to TVE-Spectrum for ch6109 COOKING-CHANNEL
2021/04/01 13:21:29.462598 [TVE] stream timestamps: animal-planet: start_at=2021-04-01T13:21:14-04:00 current_at=2021-04-01T13:21:29-04:00 end_at=2021-04-01T13:21:33-04:00
2021/04/01 13:21:29.462682 [TNR] Opened connection to TVE-Spectrum for ch6103 ANIMAL-PLANET [transcode=none]
2021/04/01 13:23:22.851476 [TNR] Error during live stream for ch6103 ANIMAL-PLANET: write tcp 192.168.101.211:8089->192.168.101.232:40878: write: broken pipe
2021/04/01 13:23:22.856875 [TNR] Closed connection to TVE-Spectrum for ch6103 ANIMAL-PLANET
2021/04/01 13:23:40.691706 [ERR] Could not start stream for TVE-Spectrum ch6105 TLC: TVE: 403 You've exceeded the maximum number of streaming sessions. To watch this program, sign out of one of your other sessions, and try again.: stream limit reached
2021/04/01 13:24:04.108880 [ERR] Could not start stream for TVE-Spectrum ch6105 TLC: TVE: 403 You've exceeded the maximum number of streaming sessions. To watch this program, sign out of one of your other sessions, and try again.: stream limit reached
2021/04/01 13:25:15.535225 [ERR] Could not start stream for TVE-Spectrum ch6105 TLC: TVE: 403 You've exceeded the maximum number of streaming sessions. To watch this program, sign out of one of your other sessions, and try again.: stream limit reached
It seems as if the Close Connection does not result in the stream being released. From a computer I then went to the watch.Spectrum.net page, viewed the channel(s) and switched to other channels. After doing that the stream limit appeared to be reset. Any ideas about what may be happening and how to fix this issue?
