Channels app does not provide any tv streams in of it self.
U have to have a tuner source.
U need an antenna and a HDHR OTA tuner to get over the air stations.
There is also Locast support,but i think that is a USA only thing.
Only other tuner source would be TVE, and you would need cable or stream provider credentials for that.
We are happy to announce a new feature in public beta: TV Everywhere support!
What is TV Everywhere
TV Everywhere (https://en.m.wikipedia.org/wiki/TV_Everywhere ) is a technology that allows you to use your cable login to access cable content via apps and mobile devices. TV Everywhere support varies by cable provider, but most traditional cable companies offer wide ranging support for TVE. Newer OTT providers may or may not support TVE logins depending on the channel .
How does it work?
The vari…
This topic will contain a table of contents
Channels DVR
How much does it cost?
Channels DVR requires a subscription plan: either $8/month or $80/year
Channels DVR subscribers get access to all the Channels apps for free as long as they maintain an active subscription.
How do I cancel my subscription?
You can manage or cancel your Channels DVR subscription at any time with a simple click on getchannels.com/account
Once you cancel your subscription, you will no longer be billled however your …
