Began losing some Xfinity TVE channels. Upgraded to 2022.01.29.2039. Deleted Xfinity source and tried to add back 5 or 6 times always failing on Provider Authorization. Submitted logs as 8b38f177-8637-4937-be60-f44af1303eb2 THANKS
I had the same problem a couple days ago.
Here's some thing to check
Finally got mine working
Thanks... I read your post earlier and tried all those items, plus a few from older posts. I can view on NBC and on Xfinity streaming. Just doesnt take my password in the Channels DVR interface...
Just added another one I had forgot about
If adding a TVE source, click and HOLD the Login button.
The only way to get past this issue is to wait a while and try again. Any changes you make during that time are inconsequential.
Hmmm... OK. Thanks.
I tried to watch cable channels last night, but saw errors and frozen pictures. I tried to fix it by re-adding the password. That didn't help. Then I removed the provider (Xfinity). But I am unable to add it back. It fails on log in (see attached sscreenshot)
. I verified that I can log into Xfinity directly and watch streaming TV channels. I ran the troubleshooter - all green check marks.
Same issue here. Eventually after trying for a couple of days I got it working again (no rhyme or reason, just trying couple times a day) about 2 days ago but can't seem to authorize any of the Disney/ESPN owned stations now. Get "Cable provider authentication failed" on those channels.
Please try again with the latest prerelease build.
Does appear to be working now on the latest prerelease build.
I'm having this same issue. Anyone else?
Resolved itself. Authentication was failing when I added xfinity but fixed now.
