Xfinity won't add as source...Not In Subscription
I cannot add xfinity as a source. I've read a few different forums and have already done the following:
  1. Turned off Auto-Authentication on Xfinity accout
  2. Turned off 2FA
  3. logged into incog browsers, and logged into nbc.com/live and my xfinity.com account also.
  4. cleared cookies and passwords for all browsers
  5. closed and reopened the server several times.
Something to note...I decided to see what would happen if I just typed jibberish for login and password, so I typed "asdfasdf" and "ajksjdif" (and other variations) --> and instead of giving me authentication failed, I STILL got "not in subscription". Makes me feel like it's not even connecting to the xfinity services or something.
Please help! Thanks!
Also make sure your Chrome is up to date. See Support, Troubleshooting on the server Admin UI.
You need to disable auto auth on the ISP account
I did disable auto auth on the on Xfinity. That was one of the first things i tried. Other sources have worked when i tried like DirecTV. Only Xfinity does this.
The question is why would auto auth matter though when i provide junk credentials to test it...I put in username "asdfg" and password "ahdghjj" and it still says not in subscription. Shouldn't it say auth failed or something like that?
I am able to watch with the login at nbc.com/live and also stream on Xfinity website. Tried all that also, including logging in with incognito browser and trying to scan while logged in.
I did the troubleshooting and it passed the browser check, i will triple check for any chrome updates though... But i think I'm up to date.
You're changing it on the wrong account
There is only 1 acount. Another thing i forgot to mention is that I'm using T-Mobile home Internet but Xfinity tv.
I will double check with Xfinity to make sure there isn't another account.
The issue you're describing happens when the dvr is connecting via Comcast internet
I understand... That's what's weird. I am 100 percent sure I do not have Comcast internet only tv at this location. I use tmobile home Internet. If I'm putting junk in the login credentials your would it even know what account and whether auto auth is in or off? It's not a real account in that case. That's why it seems like it's not even getting to login... Cuz would it not says auth failed instead?
I will check with Xfinity and see if there are multiple accounts for some reason. But the login works at nbc.com/live so i think I've got the right credentials and I verified auto auth is off for those credentials.
Thanks so much for your help btw.
If you go to ipchicken.com on the dvr PC does it say T-Mobile or Comcast
It doesn't really say either, just the IP, but when I do whois on the IP it is T-Mobile. See images
Comcast states that there is no way to stream other than from the xfinity app...However, I don't think I believe that - most likely just someone who is trained (or not trained well enough lol)
They also confirmed that my internet and tv are under the same account.
That is partially true that using their app you can stream all their Channels ... TVE is just another vehicle to watch certain Channels and you need to use their credentials.
Yeah, that's what I pretty much know to be true also...just was wondering if maybe somehow they found a way to reject any connections not coming from their app. Because I don't see any kind of authentication failure when i use jibberish for credentials...it just says "not in subscription" but how could username "jkjsdf" even have any subscription.
Something must be wrong with your setup I am om Comcast/XFINITY and my TVE is working ... did you submit the logs or trouble shoot in the web page ? See troubleshooting below.
I've run the troubleshooting a couple times. Looks good...I don't really care about remote access.
I will upload logs next.
can't figure out how to upload the full log file...but here is most of the last attempt to add xfinity...
Support Trouble shooting scroll down you where see where to send the logs.
