Android TV/Fire TV Beta Notes
v2025.08.09.1832
• FIXED: crash that could happen when adding server side settings for the sidebar
v2025.08.09.2152
IMPROVED: Page up/down behavior on the Guide
v4.9.4 is being released as stable
v2025.08.11.2159
• Attempt to fix crash that can happen when viewing the guide
v2025.08.23.2018
• FIXED: Crash that could happen when browsing the guide
v2025.08.23.2027
• FIXED: Crash that could happen in On Now
v2025.08.25.0131
• IMPROVED: performance of scrolling guide
v2025.11.27.0208
• IMPROVED: Enhanced library views now work with Server Side Sidebar Navigation
• FIXED: Crash that could happen when using Shortcut Keys when using Server Side Sidebar Navigation
v2026.01.18.2146
• IMPROVED: ATSC3 audio support
v2026.01.19.0342
• IMPROVED: handling of ATSC3 audio with signal reception issues
v2026.01.22.2303
• FIXED: Unusual crash that could happen
v2026.01.23.0634
• FIXED: crash that could happen in the guide
v2026.01.23.2022
• IMPROVED: performance improvements to the guide
v2026.02.01.0237
• NEW: Experimental Guide available for testing
v2026.02.02.0254
• FIXED: Issue with page up/down on Experimental Guide
v2026.02.03.2212
• FIXED: Experimental Guide now uses correct layout for channel images
• FIXED: Coming back to the guide after watching a channel for many hours now shows the guide properly
• FIXED: Experimental Guide now can accept numeric input for channel selection
• FIXED: Experimental Guide now behaves better when using page up/down
v2026.02.05.2350
• IMPROVED: Experimental Guide: scrolling behavior for page up/down
• FIXED: Experimental Guide: focus could get lost in certain situations
v2026.02.06.2040
• FIXED: Experimental Guide: pressing the down arrow and page down on the channel cell would sometimes pick the wrong focus
v2026.02.10.0457
• IMPROVED: On Later view for Events and Specials now a richer display
• IMPROVED: Experimental Guide: Page Up and Page Down will now wrap around at the top and bottom
• FIXED: Experimental Guide: Filter dropdown width now matches the column
• FIXED: Experimental Guide: focus issues
• FIXED: memory leaks
v2026.02.12.2240
• FIXED: crash from last build that would happen when going to Support items in Settings
