Beta: Web Admin v2
First off, the new interface looks amazing! Great job.
It seems like I can't create labels that stick within the new interface. I tried with several movies and create a label, back out, refresh the page, look again and the label isn't there anymore.
However, if I switch to the legacy interface, create a label for any movie (I am creating my October Movies collection with the smart tags) they do stick and are available to select once I go back into the new V2 interface. I just can't seem to create new ones from the V2 interface.
Are you saving after adding the label? For adding a new label, you should:
  1. type out the new label
  2. hit Enter to make it a label
  3. click save in the modal to save the changes.
Type it
Hit Enter
Click Save
Yes, there is a Save button at the bottom right of the window and I entered the Label, hit save. It gives a little pop up at the bottom of the screen saying "Changes saved" but when I exit the page and go back to that Movie (I tried a different label to test) and the label isn't sticking.
EDIT: I am on Chrome browser. I will try a different browser and see if it does it differently there.
EDIT EDIT: Ok, it's working on Safari
me too and it works fine. though, it will let you 'save' if you fail to hit enter and get the X (to remove if you want)
logo please :smile:
@maddox @Shaggylive
Ok, finally got it to work on Chrome. I don't know why it wasn't before. I closed the browser and re-opened and it is now working. :person_shrugging:
Oh No! lol @mjitkop hopefully you can easily adapt your Extras for /v2
@maddox any chance of getting the option to re-record natively? (mark as not recorded)
My immediate reaction is that it seems like using the guide will finally be a pleasant experience.
ETA: Search in the guide is awesome.
Yes, I will look into it.
I am so used to the current AdminUI, and many pages fit very well and easy to ready when zoomed in.
This new version, sleeker, but some pages are hared to see, smaller text or logos and things, Have to increase zoom to see it.
Still have to get used to it.
Bit more clicks and navigation than I am used to for accessing settings.
why won't the icon populate when i bookmark the new server ui pages?
Screenshot 2026-10-03 at 2.11.31 PM
And, where is the Recordings page? DVR, Manage? To see a list of recordings.
I see a calendar view of upcoming recordings, but not the list view i want like the old UI.
I was wondering the same thing too.
There are a few posts above that mention it but I like pictures:
no that not the same. does not show just and only Recordings, that shows other things in my library that are Recently Added. No filter there to only show recordings.
I think the old commercial editor made more effective use of the screen realestate.
ip/v2/recordings
This screen isn't built yet
It's coming as the rewrite progresses.
Ah so maybe it not done yet then
No, Manage was replaced by Library. It’s explained further up in this thread.
It effectively does everything managed did before and more.
Yes, sorry, I forgot about the source too.
ah i see. have to use Episodes then source.
vs the old
As for v2 and playing with Firefox, here's what I found.
If it doesn't start playing
open the PIP view and you'll see it's paused. Hit play or skip ahead.
Screenshot 2026-10-03 133554
The Green Dot indicator in the Guide and other places when u pull up a repeat episode of something you have recorded.
In the previous UI, it meant it was Recorded, and when u open the details, it says that, with a dropdown menu to Mark as not recorded or Record again.
This is something i recorded before, but have deleted the recording long ago.
New UI, says In Your Library, and clickable, but gives a blank box page. No options as the old UI.
U can click the normal Record button, for a one time record.
Screenshot 2026-10-03 at 4.02.48 PM
