I’m running this through Docker but don’t have a stack in Portainer. How do I update?
docker pull tonywagner/eplustv:latest
will get the latest image on your device.
Then you just have to recreate you container. In Docker Desktop, just find your container and click the three dot menu and select "Recreate". Of if you are just running a "docker run" command, you can stop it and run it again, I think. Or if you use Docker compose files like me, run this command:
docker compose up eplustv --detach
Thanks. None of that worked, though. I did not see a "recreate." I ran the update script and then restarted from the three dots. Still on 4.15.6. Also tried the detach script. Running the docker pull tells me it is up to date
Edit: I just removed the container and then ran the command again to get to .16
Another option is to run something like dockwatch that is a container for managing your containers. One thing it makes easy is checking/updating container versions. I just used it tonight to update EPlusTV to the new version.
Thank you! I'll try that.
This still an issue? Football season coming up so checking back in, would be a huge loss
For EPlusTV, yes. For me? No, I'm using HDMI Encoder Native Apps:
Or you could use PrismCast. I've set them all up as possibilities for me!
Sorry I missed this. I'm not currently a subscriber, but if anyone can loan me NFL+ credentials by private message, I'd be happy to take a look!
Interesting, might send you a message on the side to learn more and not hijack this thread.
I’ll sign up for one and share it if no one else does, I didn’t keep mine over the offseason but it’s absolutely essential in season
There's already a thread:
To be clear, I don't have NFL+; I'm using a TVE Provider, if that makes a difference for what you need?
NFL+ is sick in eplus because it gives you redzone, local games, and all national broadcasts in 1 spot. Doesn’t require cable and is $15 a month
That will still be helpful. PM sent!
Not sure if this has been mentioned, but WNBA fans in the Atlanta Dream and Minnesota Lynx markets can stream their team's games with a free Victory+ account. Works in EPlusTV too.
Gotham sports is going away, even though it never works in E+
Basically sent to the DRM gods but at least FDL is there and is able to get DAZN stuff
Can confirm that I can't even get a token for NFL, when I try to authenticate I can bring up the NFL id page and the ID works and auths, but E+ never gets the token and just spins waiting. There's nothing in the logs.
Also when you get a chance, can timestamps be added to the logs? Dunno why this was never implemented.
Hey guys havent used the app since last foot all season . Is the prismcast script integrated into eplustv for espn3/ESPN+?
In my experience, the ESPN+ events are not being populated in the guide for my nonlinear EplusTV source even though I have it set up with sign in to my Disney account.
FruitDeepLinks does work with ESPN+ on prismcast, so that's an option.
Is there a guide for ESPN+ and prismcast sorry I'm not up on the latest
