Thank you, how about the SNY app?
Try:
adbe.luvSZlCvQ1ev5GiqiK9toQ://live
Here's what I've assembled so far. I'm using Stream Links to launch each network's app individually, whenever possible, as opposed to just the one NBC app, used and reused for all of them.
#EXTINF:-1 channel-id="nbc" tvg-chno="6000" tvc-guide-stationid="10991",NBC
nbctve://live/nbc
#EXTINF:-1 channel-id="msnbc" tvg-chno="6050" tvc-guide-stationid="64241",MSNBC
msnbc://live/msnbc
#EXTINF:-1 channel-id="nbc-news" tvc-guide-stationid="114174",NBC News Now
nbcnews://live/nbc-news
#EXTINF:-1 channel-id="cnbc" tvg-chno="6051" tvc-guide-stationid="58780",CNBC
cnbctve://live/cnbc
#EXTINF:-1 channel-id="usa" tvg-chno="6052" tvc-guide-stationid="58452",USA
usatve://live/usa
#EXTINF:-1 channel-id="syfy" tvg-chno="6054" tvc-guide-stationid="58623",SyFy
syfytve://live/syfy
#EXTINF:-1 channel-id="e!" tvg-chno="6056" tvc-guide-stationid="61812",E!
eonlinetve://live/e
#EXTINF:-1 channel-id="bravo" tvg-chno="6058" tvc-guide-stationid="58625",Bravo
bravotve://live/bravo
#EXTINF:-1 channel-id="oxygen" tvg-chno="6060" tvc-guide-stationid="70522",Oxygen
oxygentve://live/oxygen
#EXTINF:-1 channel-id="golf" tvg-chno="6159" tvc-guide-stationid="61854",Golf
nbctve://live/golf
#EXTINF:-1 channel-id="nfl" channel-number="6192" tvc-guide-stationid="45399",NFL
nflctv://watch/nfl
Notes:
• I'm testing and using these all on tvOS only.
• Make sure you install every one of the apps ahead of time! Log them in with your provider and make sure they play, first. Hide all of them in a folder on your home screen if you prefer.
• Golf Network is not in the App Store, so it's launching NBC instead
• I included NBC News Now as well, but most of us can already integrate that channel more elegantly with Channels DVR via Samsung TV+, Pluto, Stirr, etc.
As noted above, if you prefer to deeplink to other apps, these are the known working ones so far:
Should be oxygentve:// and eonlinetve://
Those work, thanks. I could have sworn I'd tried oxygentve! Seems so obvious. I would not have guessed eonlinetve, though
I'll edit my post above.
Ive noticed some strange guide behavior with the NFL network guide ever since switching over to the apple tv nfl network streamlink.
I reindexed the whole database, but its getting info from a different channel.
Later in the guide it does pick up correct program data , then incorrect data.
Anyone else seeing this?
The channel number should be 6192 in your M3U. It's overlapping with another channel.
Golly your fast!
lol
For instance, if I wanted to create one for Bally Sports, where do I find the channel id, channel number, and TVC station id information?
channel-id: you make it up with something unique, like "ballysports"
channel-number: not needed
station-id: you can assign it afterwards:
Can someone put the streamlink for the hbo channels on prime video?
i could be wrong but I don’t believe the Prime Video app is deeplinkable in that way
Is there a list of streamlink channels that do work?
Soecifically android
Does anyone have the entry for the weather channel?
Try twcweather://
Is there a way I can also look up channel numbers?
Anybody knows how to launch the Tennis Channel app (live feed) via Stream Link? (The Xfinity TVE feed is very inconsistent). Thanks.
I found a good reference here:
No luck with this link but thanks for checking!
Is there a link for YouTubeTV for MSNBC? Running on nVidia Shield.
