Channels DVR has been able to play FS1 TVE HDR content in HDR. However, the Super Bowl is not on FS1. It's through the Fox Broadcast Network in combination with your local affiliate. So far, that combination is not available through Chanels DVR in HDR.
ah, understood
EPLUS docker can access both fox and fs1/2 in HDR. It's free and you can feed it into whatever player you want.
Thanks for the reply, but I have to say, I don't know what eplus docker is. Are any of the users here doing it that way?
Huh?
| DATE | TIME (ET) | EVENT/LEAGUE | MATCHUP/EVENT | CHANNEL |
| 12-Feb | 10:30 PM | Entertainment | Next Level Chef | FOX 4K |
Not sure if this will work, but
for 4K superbowl tomorrow.
Just to be clear, does that improvement require us to install the EPLUS docker? Or will it hopefully try to work (
) with the latest pre-release of Channels DVR on its own?
Unrelated to EPLUS docker.
Next build adds an experimental setting, so if you upgrade make sure to check the box to get the 4K/HDR. And if its buggy tomorrow you can flip it off and fallback to the regular working FOX.
Fantastic. I've updated and enabled, and will report issues, if any. Thank you!
Have any particular Fox local channels been verified working?
I don't think anything has been flagged as broadcasting in 4K HDR just yet. The college basketball games on right now are not in 4K.
They aren't in 4k, so that isn't surprising.
Only the FOX national feeds that are in 4k are affected.
Next one is Road to the Super Bowl tomorrow at Noon ET.
There is a show just an hour earlier than that starting at 11AM eastern.
Skip and Shannon: Undisputed Super Bowl Special
Does the Fox Sports app say it's in 4k?
Yes
Hmm. guess this needs updated https://support.fubo.tv/hc/en-us/articles/360011483011-What-events-in-4K-HDR-are-coming-up-on-fuboTV-
was surprised to see Next Level Chef Season Premiere will be in 4k.
Fox has done that before after the Super Bowl. Last time it was The Masked Singer.
