Ok, I installed my new Beelink Mini S computer, and for now left it on the default Windows 11 Pro that it comes with. I ran a DB backup before moving the drive from the RP, and installed Channels as a service on the mini s, and it's running. When I did this, I moved the 4TB WD drive from the RP, and plugged it into the back USB port on the Beelink. I then did a "RESTORE" and pointed it at the drive Database folder per the migration instructions. I did a RESTORE on that last backup, and it ran through all it's motions and works.
However, for SOME reason, when it indexed everything, it doubled up the count of some of my imported tv shows. For instance, say that I only had 3 episodes in the show folder total, season and episode S01E02, S01E03, S01E04. I now show SIX episodes total, as each of those doubled-up, and they all are playable. None of them errored.
Why, and is there and easy way to fix this without going through a manually deleting every other episode?
