Updated to a new mini pc. Glad I already have ram and hard drives sitting around. Its an Intel Ultra 7 356H. This also brought on other challenges due to how new the hardware is and needed a very new kernel for the Intel Chip, Graphics, and Realtek nic. So I only had a few options to pick from for the OS. Ubuntu 26.04 and Fedora 44. But either way I ran into the same issue since I have brand new Intel Graphics chip onboard. When trying to install the container it stalls when using the --device /dev/dri:/dev/dri. From what I gather it seems what ever is used for the container doesn't allow MESA to work correctly without an INTEL_FORCE_PROBE which I don't know if I can do anything to make it work. I would assume other folks running the latest driver for Xe3 graphics will run into this as well, if their kernel gets upgraded to use the latest intel graphics driver. I am not sure if there is a workaround outside of only using the CPU.
Here is the screenshot from the Container Logs.
