LinkPi encoder family
I found that by hooking your capture card up to your PC, you can check the available output resolutions and frame rates using OBS Studio. Connect the card, add the USB device as a source to the OBS interface, open the properties of the device, choose "custom" for your resolution and fps, and you can see all the available outputs from your device.
It turns out that my cheapo Vivitar device does indeed support 1080p @ 60hz.
I have done auto updates, and manual updates of the firmware through the GUI. So far, I haven't attempted to flash from a USB stick. That is the next step. Thanks for the suggestion and instructions.
Something told me that I shouldn't try it. It looks like I was right. I followed all the steps, and it was updating. At least I think that was what was displayed on the monitor.
The front display on the device had some corrupted looking image on it. It seemed like it was stuck as nothing had changed over several minutes. Eventually, I unplugged the unit. Now, it won't even power on.
I knew that there was something wrong with this unit. But, it was working as it was. I should have been happy with that and left it alone. Now, I may have to buy a new encoder...
I have had that happen when I updated the firmware and did a full reset through the GUI. Sadly, this is different. Nothing comes on when I connect the power. No display, no status light, absolutely nothing. I think that I killed it. :skull:
This is what happened. I honestly thought that it was stuck. Nothing had changed for what seemed like too long. Now it's dead. Not even a small flicker of life...sigh.
Thanks, I may have to go that route. I have never purchased anything from aliexpress. I wonder how they are regarding support and/or returns if you receive a bad unit.
I know that my unit is getting power as there is a tiny white led lit on the left front portion of the main board when I look into the air vents on the left side.
Unfortunately, no. It's not getting onto the LAN. I checked my device list through the router GUI. It's not on there.
I just wanted to note on my experience to only buy something direct/Amazon from Link Pi / YouYeeToo. These products plain work, right out of the box. Whereas I thought I could be cute and just purchase an older multi-port industrial level encoder on eBay for a great discount, it ended up being a completely wasted effort, especially for everything I had to do to make it partially work. Don't bother trying to get around this to save a few (or a lot) of bucks like I did; pay whatever price is being asked if you want to go down the HDMI capture path!
I'm not denigrating other sellers of the same product who may have a good price (I just chose Amazon in case I need to do a return); I'm just lambasting myself for buying an inferior product while trying to save money!
Does anyone know a way to disable the LED lights, and maybe turn the screen off, on these guys?
How does one go about contacting them for support? I have seen the online users guide, but do they have a support webpage also? Phone? email? blog? chat?
weird, I have 2 linkpi's and 1 shows the gear and 1 doesn't. I was looking for this on the 2nd box. they have same firmware, so I assume/hope the old factory reset fixes this. (i'll try later)
while looking for the answer I did pay more attention to this info, and found the EDID setting i'd been looking for.
https://github.com/matiaspl/LinkPi-ENCx?tab=readme-ov-file#interesting-internal-pages-not-linked
Thanks! I'm going to reach out to them about my USB flash and crash. I just found this link:
Yeah, I don't have that gear, either. There's a literal missing nav-item in that spot:
both my fac pages look identical and don't see a developer mode. also I don't recall doing the full flash (with usb right?) I seem to remember that to get the oled option a reset triggered by the front panel was the trick. :man_shrugging:
I think the warranty is 12 months. I've had this unit for about 20 months. So, I'm not expecting a replacement. However,
I'd love to get some guidance on how to resurrect this device.
@jsfullam sounds like a multi-meter & magnifying glass situation. :face_with_monocle:
@babsonnexus
I've done the full flash twice, once with just the impact updates, and once with all updates in a row. still no little gear to change the OLED
strange how I have it on one but not the other. :weary:
That may be a bit out of my league. :mag: :thinking: I was thinking more along the line of a hammer :hammer: and wastebasket :wastebasket: approach.
@jsfullam
If you do decide it is really going in the trash...Send it to me so I can experiment on it. I am more than happy to send you money for the shipping. :slightly_smiling_face: :slightly_smiling_face:
I'll keep that in mind if I can't get it back up and running. I haven't quite given up on it yet. I have been in touch with customer support and they have offered to walk me through a repair process using a USB to TTL UART adapter, or send the device to their engineers for reprogramming.
